Author Topic: Reducing Signature Point Size.  (Read 3473 times)
Online Untidy Shop
« on: September 30, 2016, 03:48 AM »
Is there a way to reduce the point size of your Signature?
@Peter Halle @SRSemenza
Offline Peter Halle
Re: Reducing Signature Point Size.
« Reply #1 on: September 30, 2016, 07:47 AM »
@Untidy Shop
I just discovered that there is a way:
[ size=8pt]type what you want in your signature line[/size ]
You will have to omit the space between the left bracket and the word size at the beginning and also the space between the word size and the right  bracket at the end.
My signature below is 4 pt type as an example
Pater
Offline Wooden Skye
« Reply #2 on: September 30, 2016, 09:53 AM »
I don't know if you want to do this.  By reducing the size of his signature it gave Peter a new name.  Welcome Pater
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Online Untidy Shop
« Reply #3 on: September 30, 2016, 06:21 PM »
Thank you @Peter Halle for researching this. It worked to my satisfaction. Changed font size to 8pt and Font to [ Font=Arial]. Readers should remove the space before 'Font= ' for this to actually work.  [smile]
« Last Edit: September 30, 2016, 06:23 PM by Untidy Shop »
