Author Topic: Another short easy picture insertion tutorial.  (Read 35789 times)
Offline SRSemenza
« on: January 21, 2015, 10:08 AM »
   On the create a post or topic page.
1.  Click "Attachments and other options".
2.  Place curser in the location in post that you want the picture to appear.
3.  Click "Choose File" .
4.  Choose and click to open the picture you want from your computer. The picture file info should pop into the choose file  box on FOG.
5.  Use the drop down that is adjacent to the "Choose File" box to choose insertion type that you want. Probably "In line Full Size Image". A bracketed "Attach Img.." will pop into the post.
6.  Reposition curser to locate the next picture in post.
7.  Repeat #3 - #6 for each picture. Put each picture in a separate Choose File box. Add more Choose File boxes as needed by clicking more attachments under the Choose File box.
     Note --- pictures that are very large may appear rotated or may be too large for the system and cause other anomalies.  If this happens resize to a smaller size.
« Last Edit: March 30, 2017, 11:06 AM by SRSemenza »
Offline campbellcraft
Re: Another short easy picture insertion tutorial.
« Reply #1 on: January 21, 2015, 12:55 PM »
I'll believe this actually worked when I see the post. But so far so good.I did not have a browse option. It said choose file which took me a while to figure out.
« Reply #2 on: January 21, 2015, 01:05 PM »
Thank you very much for this post. This is the first time in over seven years that I have been able to post a photo. Shane once spend some time with me, but by the time I got home I still couldn't make it work.  Some problem, such as the browse/chose file, would bring me to a screeching halt.
Again, thank you very much.
Offline SRSemenza
« Reply #3 on: January 21, 2015, 03:49 PM »
   Maybe "Choose File" appears instead of "Browse" on some operating systems?  Not sure. I'm on Windows 8. Not sure what appears on mobile devices either.
Offline neilc
« Reply #4 on: January 21, 2015, 05:33 PM »
Let's see if this works...
211419-0
This method does not work on Safari on a Mac.  The only way I can get an inline image is to use the inserting# tag.
neil
Offline Untidy Shop
« Reply #5 on: January 21, 2015, 06:33 PM »
With 'Insert as full size images', frequently after you edit the text the image will appear to have disappeared after you save.
And instead you get the message 'attachimg=1' in brackets in your post.
If this happens, refresh the page.
This experience is based on IPad and Safari.
Offline TSO Products
    • TSO Products
« Reply #6 on: November 22, 2015, 09:38 AM »
from a newbie FOG member the tutorial is really appreciated - thank you.
On the other end: how can I easily enlarge a thumbnail picture in a post without having to save it and enlarge it off-line?
TSOproducts.com
Home of the GRS-16 and GRS-16 PE  plus TPG Parallel Guide -  the MTR-18 Triangle and Work Holding solutions plus AXMINSTER UJK in the USA
Offline rst
« Reply #7 on: November 22, 2015, 09:48 AM »
Is tht the blade for the new Festool sword saw?????
Online Peter Halle
« Reply #8 on: November 22, 2015, 10:19 AM »
Try clicking on it and see if it will enlarge.
Offline HAXIT
« Reply #9 on: November 26, 2016, 08:00 PM »
Just a test for the first time attaching a picture.
[ Specified attachment is not available ]
« Last Edit: November 26, 2016, 08:05 PM by HAXIT »
Offline Woodkrafts
    • Woodkrafts
« Reply #10 on: November 26, 2016, 10:32 PM »
254536-0
testing inline expandable
Offline HAXIT
« Reply #11 on: November 27, 2016, 10:09 PM »
I was trying to send some pictures and nothing came in and I did not see any error!
testing again.
254579-0
Offline HAXIT
« Reply #12 on: November 27, 2016, 10:46 PM »
another test as full size.
Offline duc996
« Reply #13 on: December 22, 2016, 05:57 PM »
test
Online Peter Halle
« Reply #14 on: December 22, 2016, 07:21 PM »
I guess that the tutorial worked!
Offline duc996
« Reply #15 on: December 22, 2016, 10:46 PM »
Peter, thanks for the tutorial! I posted pics before but forgot and the refresher course was very helpful. Thank you.
Offline montyss
« Reply #16 on: November 05, 2017, 09:40 PM »
 just a picture test
Offline Mario Turcot
Re: TEST Another short easy picture insertion tutorial.
« Reply #17 on: January 16, 2018, 02:32 PM »
TEST
This is the mess created by the veritas router plane while cleaning the dados.
« Last Edit: January 16, 2018, 05:04 PM by SRSemenza »
Mario
Offline Major_gloom
« Reply #18 on: September 08, 2018, 10:12 AM »
