Pages: [1]   Go Down
  Print
Author Topic: You never know what you will find.  (Read 910 times)
JD2720
Offline Offline
« on: March 08, 2012, 10:32 AM »
I had to swap out a range hood
« Last Edit: November 21, 2012, 02:09 PM by Chris Rosenberger » Logged
Steve R
Offline Offline
« Reply #1 on: March 08, 2012, 10:46 AM »
Wow!  And people wonder why we need Code and Inspectors. I wouldn't want to be the insurance carrier covering them for fire.
Cheers,
Steve
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #2 on: March 08, 2012, 10:52 AM »
That kind of thing horrifies me  Scared  when I find it.  Makes me want to call the fire marshal before I do any further work.
 Sad
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Guy Ashley
Offline Offline
WWW
« Reply #3 on: March 08, 2012, 11:22 AM »
Dear God!!! That sort of stuff really gets me ticked!!! Angry Angry
Do these jerks not know they are risking peoples lives, or maybe they just dont care.
Dont know how it works with you guys but in the UK anything do do with residential electrics has to be carried out by a Part P qualified sparky, who puts his signature to a safety certicate issued to the householder.
Same with Gas appliances, a Gas Safe registered and qualified plumber. You try and short curcuit that legislation then be prepared to go to jail and pay a £30,000 fine!
I am sure a lot of contractors here still try and do "little things" but if they read the small print in their liability insurance there is a disclaimer.
DIPLOMACY:
EWTHeckman
Offline Offline
« Reply #4 on: March 08, 2012, 11:38 AM »
It absolutely is scary. It's amazing that there aren't more fires.
My current project is renovating a basement room. When the previous owner had finished the room, they had nailed 1x3's to the wall. Then to get sufficient depth for the outlet boxes, they cut holes in the block. These boxes were metal. The result was that the boxes were severely rusted, one to the point where half of it no longer existed!
But that wasn't the scariest part. At one point in the wiring closet, they had run the feed wire for the room behind a piece of wood, then drove nails into the wood to keep the wire in place. But instead of going in next to the wire (the obvious intent), two of the nails had gone into the wire itself!  Scared  Fortunately, they went dead center through the cable, missing the hot and neutral wires completely.
On the other hand, this house had an in-wall air conditioner that was installed in 1957, and still worked when we replaced it in 2007!
Ed "What the" Heckman
Matthew deBeaupre
Offline Offline
« Reply #5 on: March 08, 2012, 12:13 PM »
I do renovations on some of the older double brick foundation homes in Toronto.
I find stuff like this - at the point of load - bottom of the stairs. Maybe that was 2 inches left after the HVAC guys recessed a duct into the joist!
Good times.
Matthew
Matthew deBeaupre
Offline Offline
« Reply #6 on: March 08, 2012, 12:18 PM »
Notice the stress crack caused by the weight of the header framing the basement opening. This was very scarey stuff we found.
andvari
Offline Offline
« Reply #7 on: March 08, 2012, 12:24 PM »
Cheers,
Steve
We need not only inspectors but HONEST inspectors. The most frightening thing of all was the corruption of the inspection process that was found after Hurricane Andrew.
Tim Raleigh
Offline Offline
WWW
« Reply #8 on: March 08, 2012, 01:45 PM »
Matthew:
Great pictures, and I thought only Mike Holmes and Bryan Baeumler found these abominations Big Grin
BTW, great avatar picture. One of my favourite (Cdn. Sp) Carravagio's.
Tim
« Last Edit: March 08, 2012, 01:51 PM by Tim Raleigh » Logged
Ken Nagrod
Restricted
Offline Offline
« Reply #9 on: March 08, 2012, 01:47 PM »
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Good times.
Matthew
Stupid HVAC guys!  They could have recessed the duct another 1  15/16 inches.
Tinker
Offline Offline
« Reply #10 on: March 08, 2012, 03:25 PM »
Electricians and carpenters are not the only ones to ch--- Er ah  ah hem, make mistooks.  In the thirty some od years i was a mason contractor, I ran into many such short cuts.  One fireplace/chimney I lost out on, and another i had not bid on, but i was in the Voluteer Fire Department when called to fire at both houses.  The masons who built (both had left town long before the discoveries) had sort of forgotten to put flue liners into the chimneys.  Many old houses (from before 20th century)were constructed with linerless chimneys, but with great care to the brick work.  These two chimneys not only had no liners, but there were joints in the brick/block work with no mortar.  I ended up rebuilding one of those chimneys, but would not do any rebuilding until the entire chimney had been torn down and holes drilled into the footings to be sure there had been no skimping in that part.  I started bidding on another huge 3 foreplace chimney.  There were some suspicious things with the house foundation i did not like so i started measuring the foundation walls.  i found the walls were doubled up because the mason had put the first pours in the wrong place.  I would not do the estimate until exploration drilling would be performed to be sure the chimney footing was in the right place. The floor slab had already been poured, so drilling was the only way to determine The builder would not do the exploration and i walked away.  I understand there were problems with floor cracking a year or so after the house had been sold.  I stayed out of that one, but I m sure there had to be problems higher up.  By that time, i had moved to a neighboring town and was out of the gossip loops.  There are so many ways for the uninhibited to cut corners, even with inspectors supposedly doing their jobs.  The dishonest can find ways.
Tinker
Wayne H. Tinker
Pages: [1]   Go Up
  Print
Jump to:
