Per Swenson
Offline
Semi Rural New Jersey, The Ruburbs
« Reply #90 on: August 04, 2008, 09:38 PM » |
Tell me what is this sin tax? P.
Party like its 1929. It's the American way. There outta be a law banning sesquipedalianism on internet forums. www.swensonz.com
Tom Bellemare
Festool Dealer
Offline
« Reply #91 on: August 04, 2008, 09:48 PM » |
I've used the TS 75 (w/ standard blade) and MFT 800 to turn 10/4 mahogany into square table legs that need almost no sanding.
If you think about it, you have to have at least one flat surface on the slab before you start ripping because you need a reference surface for the guide rail. It doesn't have to be perfect - just enough coplanar parts that the guide rail can sit on them as you make the series of cuts. The bottom of the rough piece has to have enough touch points to have, at the very least, one point touching the table for each leg piece. Then, those cuts will all be parallel and the pieces cut off can be used to support the guide rail as you run out of real estate for the guide rail to sit on.
As you cut the first piece, put it at the uncut end and continue that until you make the last cut. This way the guide rail will remain in the same configuration from first cut to last cut. If you cut a piece that didn't have a touch point as discussed in the first paragraph, don't use it as fill in support.
Now that you have a series of parallel cuts, you can easily make the cuts that are normal to the first two cuts on each piece.
The guide rail, when properly supported, will ensure either TS cuts straight and normal to the rail.
« Last Edit: August 05, 2008, 12:21 AM by Tom Bellemare »
Brice Burrell
Offline
Remodeling Contractor
« Reply #92 on: August 04, 2008, 10:10 PM » |
Nils, sorry to hear you are having problems with your MFT. If you're looking for help with these problems check out Per's link to the search and if you don't find the answers to your questions there post your questions in the All Tools and Accessories section. The members here are very helpful and I'm sure they'll be able to answer any questions you might have. If you don't want help with the your problems and you've decided to try the EZ system by all means go for it. I have no experience with the EZ system so I can't offer any advice. However, some of the members here have it and maybe they could help you, post your EZ questions in the Other Tools and Accessories section. If the members here can't help you can try posting over at Sawmill Creek in the EurekaZone (EZ-Smart System) section. This is a section on the Saw Mill site that is dedicated to the EZ system, I'm sure you will find all the answers you need there. Good Luck. To all other FOG members there has been too many negative posts on this site lately. Please try to keep your post more positive and constructive or maybe don't post at all if you don't have any quality content to add to the discussion. If you think a poster is a troll why reply at all to their posts, ignore them and they will go away.
This site was known for its friendly, helpful members, as of late we have worked very hard to try to change that perception. How about if we try to regain that reputation.
« Last Edit: August 05, 2008, 07:03 AM by Brice Burrell »
Nisse
Offline
« Reply #93 on: August 04, 2008, 10:11 PM » |
hard to understand what Ikea has to do with Festool MFT and its malfunction
or Roadrunner06 and his IP address nonsense
why cant you people concentrate on the hard facts and only facts?
some time ago I needed to use the MFT fence in the upward position and guess what I discovered,
it wasn't perpendicular to the table top
sure, I made my own fence but all this made me to consider the EurekaZone rails and their powerbench
still like my TS75, so just wanted to get some serious opinion about the EurekaZone product line
above I stipulated a few serious question about the Festool MFT and its malfunction and the honorable members of this forum just try to explain to me how bad woodworker I am, please give me some constructive facts, tell me the alu side profiles and the fence are perpendicular not about the Ikea and Kamprad and Tetra Pak and Rausing and other mambo jumbo
now both the Rausing and Kamprad are extremly competent people but it hardly helps me to get some perpendicular cuts
or let me know immediately if I am wrong?
it would be much better to put some pressure on Festool to construct better MFT and replace all the bad ones out there
Nils
d.epstein
OfflineMember Since: Feb 2007
« Reply #94 on: August 04, 2008, 10:45 PM » |
If you think about it, you have to have at least one flat surface on the slab before you start ripping because you need a reference surface for the guide rail. It doesn't have to be perfect - just enough planar parts that the guide rail can sit on them as you make the series of cuts. The bottom of the rough piece has to have enough touch points to have, at the very least, one point touching the table for each leg piece. Then, those cuts will all be parallel and the pieces cut off can be used to support the guide rail as you run out of real estate for the guide rail to sit on.
Tom, Nice post. You nailed one of the problems. david.
Julian Tracy
Offline
« Reply #95 on: August 04, 2008, 11:03 PM » |
Sure sounds like an imposter to me....
only three posts and all about Eureka zone? Sounds like Dino's new gorilla marketing program in action to me.
Julian
d.epstein
« Reply #96 on: August 04, 2008, 11:49 PM » |
Julian
Julian. Read Brice's post. If you can't help Nils, don't attack Dino. d,
Daviddubya
Offline
Arizona, USA
« Reply #97 on: August 05, 2008, 01:02 AM » |
Nils,
I hope you got some good information from the search that Per provided as well as the post from Tom.
I'm a little confused about how you are using the MFT to rip 2" strips from a 4' 9" board (or is it 3 to 5 meters?). The MFT1080, which is what I assume you have, is 45" long. So I guess you are using the MFT as a support for your work piece, and using a guide rail clamped to the work piece to make the cut. It would be impossible to cut a 4' 9" piece using the MFT fence and guide rail, even if the fence were positioned parallel to the short side of the MFT. There are some threads here on the FOG about ways to rip narrow stock using guide rails and a TS55 or TS75. Per's search should have pointed you to some of those. The main point in many of those threads is the need to provide adequate support under the work piece on both sides of the cut and under the guide rail, making certain the guide rail is flat on the piece being cut.
I'm also confused about your comment saying you "needed to use the MFT fence in the upward position". I am having trouble envisioning what you were doing, and what you expected from the rail in a vertical position. The way the MFT guide rail is attached to the bracket, I cannot see how you would expect the rail to be perpendicular to the table top in the raised or vertical position.
Perhaps you could post some photographs of your setup so we can offer some advice to you on your specific applications?
I hope you will focus on the hard facts yourself, and provide us with some more information about the specifics of what you are doing, so that we can help you.
David W. Falkenstein in Cave Creek, AZ, USA
greg mann
Offline
« Reply #98 on: August 05, 2008, 09:41 AM » |
Nils,
I agree with Dave on this. Post some pictures of the setup that is not working for you and there are any number of folks that can give you advice on what is going wrong. Also that way, if any of us have misjudged you, and your intentions, you will get the last laugh.
Greg Mann Oakland, Michigan
Nisse
Offline
« Reply #99 on: August 05, 2008, 10:05 AM » |
Nils,
hi Daviddubya, most of that search path of Per was known to me already sure, when ripping 3-5m long planks you have to use rails only and clamp them to the wood that will be ripped, the problem is you need perfect support on the left side under the rail and even then it works only in theory now, the fence and the rail not sure if you are using the MFT yourself or not, but the fence can be applied on the table so it is only 10 mm or so high or you can rise it 90 degree and the alu profile will now be approximately 30 mm high when using it in this high position it is not perpendicular to the MDF table top also, when you try to adjust it for square against the rail its almost certain you'll bend it why do you want me to have the rail in the upward position? I am talking about the fence in the upward position when suddenly you convert my fence to the rail in the vertical position? then again, the alu profiles along the sides of the MFT are not perpendicular either ripping same width or less of solid wood as above but shorter lengths of 20" to 40" on the Festool bridge always require different kind of support and jigs and most likely it still won't be perpendicular and square my intention is to get a better rail system for my Festool TS75 circular saw and square and perpendicular cuts why are some people so upset over the idea of using a Festool TS75 on EurekaZone rails? is EurekaZone rails a bad product or are some of Festool users just afraid of getting a better rails for TS75? if bad, please tell me what's bad with it, same way I described the malfunctions of my Festool MFT Nils
Daviddubya
Offline
Arizona, USA
« Reply #100 on: August 05, 2008, 10:54 AM » |
Nils,
Yes, "Nils", I am an experienced MFT user. Search the threads here and you will see that. I am sorry that I misunderstood your question about turning the MFT fence. I have never used the fence that way.
You have convinced me that you are either Dino masquerading as Nils or one of Dino's buddies that has come here to disrupt our forum. Your use of the term "Festool bridge" gave you away. Goodbye.
« Last Edit: August 05, 2008, 11:01 AM by Daviddubya »
Bob Swenson
Offline
Location: The Hub of Morris County, NJ Member Since: Jan 2007
« Reply #101 on: August 05, 2008, 11:11 AM » |
Pictures Nisse, Pictures. It's hard to believe that you are the only one with a 75 and a guide rail that can't cut a board square. Every thing about your post is hard to believe. If your so desperate to to buy that EZ thing do it, but I suggest you go back to carpentry 101 before you waste your money. Do you really think that Festool has grown into a giant company making tools that don't work? Tell Dino that we love the Festool rail system so much that we now own 45 feet of square cutting rail.
Nisse, your post rings like a cracked bell.
Bob
Brice Burrell
Offline
« Reply #102 on: August 05, 2008, 11:54 AM » |
Nils, it would seem you don't want to find answers to the problems you are experiencing with your Festool rails. You have been directed to where you can find the info you need to help with your MFT/guide rail problems and to where you can get all the info you could ever want on the EZ system. It is becoming clear you only want to disrupt this forum, if I have misjudged your intentions please forgive me. I think you'll find antagonizing the members here isn't the best way to ask for help, not to mention you aren't representing yourself very well at all with this type of behavior. I do hope you find a way to be a member contributing positively to this forum in future.
FOG members, please don't post comments that could be taken as antagonistic, insulting or with unnecessary speculation about the a member's identity. That kind of behavior really isn't needed on this site.
Nisse
Offline
« Reply #103 on: August 05, 2008, 11:59 AM » |
Nils,
dear David, why speculate in my relation to Dino, I don't speculate in your relation to Festool, who know, you could very easily be paid by Festool or some marketing company in charge of promoting Festool products if you are a long time user of Festool MFT then it should not be to difficult to confirm at least my statements regarding the perpendicularity of Festool MFT alu fence and the alu side profiles btw, how could it be that you never observed that MFT is equipped with a cross cutting bridge on the top its great idea but it just doesn't work when using solid wood, probably its because it is not fixed on one side and the rail is to easily bend to the right/left when plunging and pushing the saw forward that's where I see some major differences on the EurekaZone rails one other thing that made me consider EurekaZone is Dino himself, he is carpenter and when you talk to him his head is full of solutions. Compare that to my long discussion with the Festool service people who's standard answer is "we can't do that", "its not possible" and like. David, if you cant confirm the above perpendicularity maybe you could tell me why you are so anti-Dino? I have not tried his products yet but it seems like it should be great in combination with my TS75 Nils
greg mann
Offline
« Reply #104 on: August 05, 2008, 12:13 PM » |
Please pass the popcorn, Per.
Rey Johnson
Offline
Fine Sawdust Maker
« Reply #105 on: August 05, 2008, 12:42 PM » |
I found a new feature: ...for immediate implementation
TS55|AT65|TDK15.6|OF1400|PS300|RO150E|MFS700|MFS400|FS2700|FS1400|FS1080|FS800|MFT3(2)|MFT1080(2)|MFT800(2)|CT33E(2)|Kapex|RS2E|ETS150/3|Domino
greg mann
Offline
« Reply #106 on: August 05, 2008, 01:14 PM » |
I found a new feature: [ ERROR: SPECIFIED ATTACHMENT MISSING ] You are aware, Rey, that everything you have documented in your "A Festool MFT/TS55 Retrospective" thread has been determined to be impossible by the OP of this thread.  Come clean, Rey. All of those wonderful shots with nice square and parallel dadoes, grooves, tongues, and half-laps must have been staged in the Nevada desert where they did all the fake moon-landing shots. Did Bob Swenson help you out? ...for immediate implementation
Roger Savatteri
Offline
« Reply #107 on: August 05, 2008, 01:26 PM » |
Nils, If you are serious in having your questions answered, by the good folks on this forum, go to the "Additional Options..." button (I noted below) in the message window, with your photos of your MFT/Rails and your TS75 set up......and download those PHOTOS. That way there could be no misunderstanding of your issues or misinterpretations of your intentions. We will all still be here and wait patiently while you take those photos. R. P.S. As to downloading photos onto the Fog site their are excellent tutorials available thru the SEARCH button, and if you have any issues with that I'm sure any long time members here would be available to assist you upon the asking.
« Last Edit: August 05, 2008, 03:30 PM by Roger Savatteri »
Los Angeles, California
JJ Wavra
Offline
« Reply #108 on: August 05, 2008, 03:30 PM » |
Nisse
when you say the guide is in the up position are you talking about the rail raised on the mft to accept thicker stock. I think that the maximum stock thickness is somewhere in the 3 inch range. If this is what you are talking about then yes the rail will flex if it is not supported and that will give you a cut that is not perpendicular to the mft top. The height of the rail should always be on top of the work piece and if there is not sufficient support for the rail it probably will twist or distort resulting in a less than perpendicular cut( the saws have enough weight to do this). In other words the guide rail height on the mft should always be positioned on the stock and not just left at the maximum height for all cuts. if you are at max height and don't have enough material to support the rail a spacer is needed to prevent the rail from distorting(which actually applies for all heights).
I hope this what you were after.
JJ
d.epstein
« Reply #109 on: August 05, 2008, 10:14 PM » |
Nils,
David, Dino is lucky to have you as a friend.  If you're searching for the ez challenge ( from the closed thread-ez-duzit) Click here: http://sawmillcreek.org/showthread.php?t=88662Nils come here for help and advice. Your actions are keeping others from doing the same. What the (....) Dino haves to do with this? Is this your PT job? To discourage festool owners from posting their problems and the same time to attack Dino? Starting a fight ( ez-duzit ) and at the end asking Dino to post his challenge at his forum, that is moderated by the SMC stuff, so you can attack again? Good luck with the challenge. You may notice at the end that Dino is challenging his own ideas., even if his invention works. Try that for few days. Challenge your thoughts before you next attack. Go ahead. Call me Dinoe if you like. Yo Dino... Have some respect for the man. david.
« Last Edit: August 05, 2008, 10:15 PM by d.epstein »
Rey Johnson
Offline
Fine Sawdust Maker
« Reply #110 on: August 06, 2008, 01:05 PM » |
You are aware, Rey, that everything you have documented in your "A Festool MFT/TS55 Retrospective" thread has been determined to be impossible by the OP of this thread.  Come clean, Rey. All of those wonderful shots with nice square and parallel dadoes, grooves, tongues, and half-laps must have been staged in the Nevada desert where they did all the fake moon-landing shots. Did Bob Swenson help you out?  Area 51 was the place, and there were these little green dudes all around. They had little domino eyes and transported themselves on rails. I believe the leader of the little green dudes was called keoshhde_KAPEX_djdkdksdsds. Only the middle part of his name was pronounceable. So whenever he was summoned, you would only here "mighty lord Kapex" we have brought you another subject to eat. We serve at your pleasure.
« Last Edit: August 06, 2008, 01:05 PM by Rey Johnson »
Bob Marino
Festool Dealer
Offline
« Reply #111 on: August 06, 2008, 09:45 PM » |
Nils,
David, Dino is lucky to have you as a friend.  If you're searching for the ez challenge ( from the closed thread-ez-duzit) Click here: http://sawmillcreek.org/showthread.php?t=88662Nils come here for help and advice. Your actions are keeping others from doing the same. What the (....) Dino haves to do with this? Is this your PT job? To discourage festool owners from posting their problems and the same time to attack Dino? Starting a fight ( ez-duzit ) and at the end asking Dino to post his challenge at his forum, that is moderated by the SMC stuff, so you can attack again? Good luck with the challenge. You may notice at the end that Dino is challenging his own ideas., even if his invention works. Try that for few days. Challenge your thoughts before you next attack. Go ahead. Call me Dinoe if you like. Yo Dino... Have some respect for the man. david. David, I really try to stay waaaaaaaaaaaaaaaaaaaay afield of the EZ stuff. But, with all due respect, if "Nils" was genuinely looking for information, rather than controversy, he would have been met with a much more positive response. And, I will be perfectly honest here; I personally doubt "Nils" whole story, even doubt his identity. I have been around the Festool - EZ stuff since the beginning and can and will tell you Dino has posted anonymously asking things like like "hey did anyone hear about the EZ system?"as a way of getting a discussion started about his system. And when Festool won some award and EZ didn't, posted to the effect "OK - Festool advertises big $$ in mag, Festool wins ward. Ez doesn't advertises there; no award - hhhmmm?"Terrible insinuation. I have met Dino personally (both of us live in NJ and attended the NJ WW shows) spoke to him on the phone and emailed him. Nice guy, but don't like his marketing tactics. Let the products speak for themselves; don't tear down another's to make yours look good. I have often remarked on the forums, I couldn't imagine another CEO/owner behaving this way - can you see Rob Lee of Lee Valley knocking Tom Lie Nielson's products? I can't. Enough old history. I think by and very large, the FOG members are willing to help anyone come up with a better way to work - just look at the responses, manuals, tutorials that are available here. But when someone, in this case, "Nils" seems to have another agenda in mind, stoking the Festoll-EZ feud, it's a good probability, he's going to be called on it, by the folks that are not looking for a fight, but by those who have been down this road too many times before. At the risk of attaining Bad Karma, I feel this one time, I needed to chime in. No worries, no more. Bob Bob
d.epstein
« Reply #112 on: August 06, 2008, 10:48 PM » |
Nils,
David, Dino is lucky to have you as a friend.  If you're searching for the ez challenge ( from the closed thread-ez-duzit) Click here: http://sawmillcreek.org/showthread.php?t=88662Nils come here for help and advice. Your actions are keeping others from doing the same. What the (....) Dino haves to do with this? Is this your PT job? To discourage festool owners from posting their problems and the same time to attack Dino? Starting a fight ( ez-duzit ) and at the end asking Dino to post his challenge at his forum, that is moderated by the SMC stuff, so you can attack again? Good luck with the challenge. You may notice at the end that Dino is challenging his own ideas., even if his invention works. Try that for few days. Challenge your thoughts before you next attack. Go ahead. Call me Dinoe if you like. Yo Dino... Have some respect for the man. david. David, I really try to stay waaaaaaaaaaaaaaaaaaaay afield of the EZ stuff. But, with all due respect, if "Nils" was genuinely looking for information, rather than controversy, he would have been met with a much more positive response. And, I will be perfectly honest here; I personally doubt "Nils" whole story, even doubt his identity. I have been around the Festool - EZ stuff since the beginning and can and will tell you Dino has posted anonymously asking things like like "hey did anyone hear about the EZ system?"as a way of getting a discussion started about his system. And when Festool won some award and EZ didn't, posted to the effect "OK - Festool advertises big $$ in mag, Festool wins ward. Ez doesn't advertises there; no award - hhhmmm?"Terrible insinuation. I have met Dino personally (both of us live in NJ and attended the NJ WW shows) spoke to him on the phone and emailed him. Nice guy, but don't like his marketing tactics. Let the products speak for themselves; don't tear down another's to make yours look good. I have often remarked on the forums, I couldn't imagine another CEO/owner behaving this way - can you see Rob Lee of Lee Valley knocking Tom Lie Nielson's products? I can't. Enough old history. I think by and very large, the FOG members are willing to help anyone come up with a better way to work - just look at the responses, manuals, tutorials that are available here. But when someone, in this case, "Nils" seems to have another agenda in mind, stoking the Festoll-EZ feud, it's a good probability, he's going to be called on it, by the folks that are not looking for a fight, but by those who have been down this road too many times before. At the risk of attaining Bad Karma, I feel this one time, I needed to chime in. No worries, no more. Bob Bob Bob, I talked to Dino few times about the "war" We must first learn ALL the facts before we can judge anyone. When the admin of FOG is posting in other forums ... - You read Matthew's post about eurekazone providing false claims. I think  Nils owes to the forum a proof. I hope his Karma will get better.  I was going to give you a minus at first but you just received your +8.  I don't vote for Nils yet. David received my minus. If I can vote for me... plus another minus.
« Last Edit: August 06, 2008, 10:51 PM by d.epstein »
Daviddubya
Offline
Arizona, USA
« Reply #113 on: August 06, 2008, 11:40 PM » |
Bob - Thanks for chiming in. d.epstein - Perhaps over time your perspective will change.
John Langevin
Offline
Location: Springfield, Massachusetts Member Since: Jan 2007
Springfield, MA
« Reply #114 on: August 07, 2008, 12:22 PM » |
[quote Nisse btw, how could it be that you never observed that MFT is equipped with a cross cutting bridge on the top its great idea but it just doesn't work when using solid wood, probably its because it is not fixed on one side and the rail is to easily bend to the right/left when plunging and pushing the saw forward[/quote] Nisse, one of us is confused  Aren't you using the guide rail support bracket on the front of the table (the side where you stand)? If you could post a pic of your setup and the results you are getting, I am positive a solution can be found; if you really want one.
Practicing Mediocrity Never Begets Perfection
Dino
OfflineMember Since: Jul 2008
« Reply #115 on: August 07, 2008, 01:21 PM » |
Nils,
David, Dino is lucky to have you as a friend.  If you're searching for the ez challenge ( from the closed thread-ez-duzit) Click here: http://sawmillcreek.org/showthread.php?t=88662Nils come here for help and advice. Your actions are keeping others from doing the same. What the (....) Dino haves to do with this? Is this your PT job? To discourage festool owners from posting their problems and the same time to attack Dino? Starting a fight ( ez-duzit ) and at the end asking Dino to post his challenge at his forum, that is moderated by the SMC stuff, so you can attack again? Good luck with the challenge. You may notice at the end that Dino is challenging his own ideas., even if his invention works. Try that for few days. Challenge your thoughts before you next attack. Go ahead. Call me Dinoe if you like. Yo Dino... Have some respect for the man. david. David, I really try to stay waaaaaaaaaaaaaaaaaaaay afield of the EZ stuff. But, with all due respect, if "Nils" was genuinely looking for information, rather than controversy, he would have been met with a much more positive response. And, I will be perfectly honest here; I personally doubt "Nils" whole story, even doubt his identity. I have been around the Festool - EZ stuff since the beginning and can and will tell you Dino has posted anonymously asking things like like "hey did anyone hear about the EZ system?"as a way of getting a discussion started about his system. Bob. The whole story and not parts. I posted 0ne or twice with without using my name. The reasons was given to you after I received your email. I may even have it. At least of the moderators at the one forum that I posted, was acting Very Anti-ezsmart and I needed to find the answers before I can asked him to stop spreading BS at the forum. J.B. was the "contractor/associate" and you know that. If you had the power to get my IP and use it against me because I was doing what had to be done, that shows your strong relation with the same forum/administrator.I can find the thread and the emails and make them public if you like. On the other hand I have never call anyone to offer him free tools ot to tell them to shut-up. Keith, the owner of SMC posted ( after he saw a demonstration ) that the ez is superior to Festool and he received few calls not to do it again. ( you know the callers better than me)And when Festool won some award and EZ didn't, posted to the effect "OK - Festool advertises big $$ in mag, Festool wins ward. Ez doesn't advertises there; no award - hhhmmm?"Terrible insinuation. I have met Dino personally (both of us live in NJ and attended the NJ WW shows) spoke to him on the phone and emailed him. Nice guy, but don't like his marketing tactics. Let the products speak for themselves; don't tear down another's to make yours look good. I have often remarked on the forums, I couldn't imagine another CEO/owner behaving this way - can you see Rob Lee of Lee Valley knocking Tom Lie Nielson's products? I can't. Enough old history. About the FHB "review". It was 100% fake. I told them to leave the ez out of it and the responce was that they have to compare the ez vs the merits of others without looking at the entire system. The title of the review was: Can A straight edge guide the tablesaw? In order to replace the tablesaw you need to haveat least two major capabilities. A. Narrow clamping. B. Repeatability.
Nothing was mentioned at the "Review" about the repeaters and the Smart clamping system. I think by and very large, the FOG members are willing to help anyone come up with a better way to work - just look at the responses, manuals, tutorials that are available here. But when someone, in this case, "Nils" seems to have another agenda in mind, stoking the Festoll-EZ feud, it's a good probability, he's going to be called on it, by the folks that are not looking for a fight, but by those who have been down this road too many times before. At the risk of attaining Bad Karma, I feel this one time, I needed to chime in. No worries, no more.
Bob
Bob
Anyway, I hope I win the Karma race.  With my best regards and few facts. You have a good day and a good Karma race.
Matthew Schenker
Offline
« Reply #116 on: August 07, 2008, 01:35 PM » |
Good Afternoon, OK, the FOG has been very generous to EZ associates. Now, three hours and counting till lock down. Matthew
Bob Marino
Festool Dealer
Offline
« Reply #117 on: August 07, 2008, 02:02 PM » |
Dino,
This is the reason I try and stay away from this particualr area. Did I say you posted more than once ir twice? Once was enough, in my book. I don't know to whom you are referring, but I have never offered anyone free tools or told anyone to shut up. I don't know who called or didn't call Keith, but can assure you it was no-one, even remotely, employed by Festool. I also don't know any "J.B" associate/contractor anywhere.
As to reviews, we can all find fault with reviews, especially if the tool we like doesn't "win top honors". Personally, tool reviews are just a starting point, not an end point, for purchasing a tool. It was not the results of the mag tool test that's at issue, it was your very strong insinuation that the reason Festool won was due to their advertising there that I found, and still find offensive. Ok, I have said what I had to and promise to all, no further responses will be comin' from me.
Bob
« Last Edit: August 07, 2008, 02:07 PM by Bob Marino »
woodtradesman
Offline
« Reply #118 on: August 07, 2008, 02:10 PM » |
So how disruptive does one need to be before some one hits the ban button?
By the way Dino don't speculate that a select few have "the power to" get your IP, anybody's IP can be traced very easily so don't be surprised if every single entity in which you have left you tracks have taken notice of your and Burt's IPs as I strongly suspect that your marketing tactics are very strongly disliked.
« Last Edit: August 07, 2008, 02:27 PM by woodtradesman »
People who have no trust in others base those fears on knowing themselves.
Matthew Schenker
Offline
« Reply #119 on: August 07, 2008, 02:15 PM » |
So how disruptive does one need to be before some one hits the ban button? Not too much more! The ban list on this forum is really short. Only one person has ever been banned. Is that number about to double, perhaps triple? Matthew
