Author Topic: Gentleman Farmer  (Read 795 times)
Offline David
  • Author/speaker/advisor to entrepreneurial experts.
    • A few pieces that I’ve built
Gentleman Farmer
« on: June 30, 2018, 07:17 PM »
Just bought 61 acres. Keeping very busy.
Fifth book (less interesting than woodworking) at http://www.expertise.is
Offline ProCarpenterRVA
Re: Gentleman Farmer
« Reply #1 on: June 30, 2018, 07:54 PM »
Sweet tractor and mower rig! What is the tractor? Looks like a bigger Kubota? I had a 3430 HSTC with the LA723 loader about ten years ago. I loved running that thing.
Sent from my Pixel XL using Tapatalk
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #2 on: June 30, 2018, 10:20 PM »
What are your plans for the land, cattle/crops/both?  Any natural water sources?  Is it already fenced?  Will you be building a house or is there already one available?
Either way, you have your work cut out for you.....
Cliff
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline David
« Reply #3 on: June 30, 2018, 11:02 PM »
It's a Kubota M5-111. The rotary cutter is a Land Pride 15' that will go through 3.5" of tree. :)
Offline David
« Reply #4 on: June 30, 2018, 11:04 PM »
Cliff
About three-quarters of the land is open--but very hilly--pasture. It would be suitable for hay or cattle or horses, I suspect. For now we'll just be haying enough to qualify for the agricultural exemption. There's a river just off the edge of the property, but not on it. There's a nice home, a 30 x 60' barn, and a detached three-car garage. The lower part of that will be my shop and the upper part will be my office. The house has an attached two-car garage, too.
