@ Untidy Shop It hurt only my ego. I was actually fortunate the car was there in the exact spot. Had it not been there, or a couple of feet further from the wall ................
Luckily the owner had a sense of humor when I unformed him that, "Some body has parked a lawn mower on your car."
By the height of your deck, You were probably fortunate the mower did not tip back on you. Been there and done that also. I had a 3/4ton pickup that i had been hauling my mower (same style but less weight to the deck as the one i parked on that car) I had a couple of aluminum ramps that I used with no problem during the first season I had used the truck. During the early winter I got a job where I would be putting a lot of fill into a tight space. I had planned to get a small dump truck, but decided the picku would work with a dump body installed. So i went that route and all went well.
In the following spring, i went back to using the same pickup for hauling my rider. The first lawn I went to, I unloaded in the same spot as always duringg the previous season. The mower went off fine, I mowed the lawn and came back to drive up the ramps. The truck body was now 4-1/2" higher than it had been before. As I got fully onto the ramps, the front end of the mower just continued going towards the sky. I did a quick calculatin and decided it would probably be a tad uncomfortable if that mower kept turning over and landed on top of me. I also realised it might be a bit messy if my head were to put a crack in the flagsone walk it was heading for. I tucked my head up and as the mower, all 500lbs of it, decended directly towards my foulded up body, my shoulders hit the walk. I somehow gave a mighty heave with arms and legs and deposited the mower about three feet of to my side. In attempting to keep my head from messing up the walk, I put a couple of tears in the ligaments that run up both sides of the front of my neck. I had a couple of sore lumps there for a couple of weeks, but no other damage to any of ME. I always figure my head is probably the least vulnerable part of my body anyhow.
When the dust had settled, I trid to turn the mower over, but it would not budge. I had to go to another job where I had another crew working. The biggest guy came with me to help my turn the mower back on its wheels. Since that little problem, i have never tried to run a riding mower up onto any truck. I went home and got my trailer (which I should have been using, but it was soooo much quicker to use the pickup with ramps
![Eek! [eek]](http://festoolownersgroup.com/Smileys/default/eek.gif)
) and have used only a trailer for hauling my riders ever since.
@ Untidy, do be careful running your rider up onto your deck. I cringe to think what could happen. Your head is probably not as hard as mine. Better you irritate your toe than to irritate your dear wife when she has to come out and peal you off the grass.
Tinker
