jmbfestool
Offline
« on: August 13, 2011, 06:23 AM » |
I landed on this job not to far from me. I got a call from a woman who said I was recommended by a few people who knew me which always good to hear. She said she has this joiner who is struggling at the moment to keep up in front of the other trades men because the second joiner had left because he was moving away.
Well I had a look and it's a pretty big house. I told her I'm a little busy but she said it's okay if I can just come when ever I want so it's a kinda turned into a hospital job for me.
Anyway to the point aswell as doing general joinery she wants me to do the bits she feels I should do one of them being a secret door and making some units/built ins.
I have done a few secret doors but I was wondering how other people have done secret doors. This one I believe she just wants it to look like the wall. So I was wondering what type of hinges or something else you've used in the past.
I have used a pivot point top and bottom and I have used SOSS hinges
Jmb
fatroman
Online
« Reply #1 on: August 13, 2011, 08:28 AM » |
I've watched Gary do this at a show. Assume you've seen it, too, but if not... http://www.garymkatz.com/TrimTechniques/hidden_pivot_bookcase_install.htm
Domino, RO 125, CT 22, OF 1010, LR 32, TS 55, OF 1400, Parallel Guides, Kapex, Fogtainers, MFT/3, DTS 400, CXS, MFS, RO90, Kapex cart and extensions, Domino XL, RAS, T12, Another MFT/3 ...
jmbfestool
Offline
« Reply #2 on: August 13, 2011, 08:57 AM » |
Thank you any way and yes I have seen it. I am going to suggest some sort of shelving with a surround as that is only way for it to be completely secret. I dont know untill I next time go to the job if she wants it totally secret or just discreet so just blends with the wall as she was saying she just wanted a door and said it can be made out of MDF and just painted like the wall. I didnt go into much detail at the time as she was showing me EVERYTHING around the house and I only just popped up quickly to see the job dats all as she was more bothered about doing stuff down stairs first as the plasters where coming to do down stairs but she just showed me some of the other jobs any way. I have just done a quick sketch up at the the grey are the walls of course and thats how it is alterations can be made has it has not been plasterboarded yet. Its a small opening any way and its low height door also has sloping ceiling behind the door so its not a proper access door its just another way into that area. So doing something like Gary would only make the opening even smaller and I dont think the opening can afford being any smaller you might have to then walk through it sideways lol. The Yellow section is the door and the white is the skirting (baseboard) and the red it the pivot point which is 45 mm away from the adjacent wall as I made a mistake with a secret door before! It worked brilliantly and then I fixed skirting on the wall and the door wouldnt open OOPS! So the Pivot point needs to be atleast two thickness of the baseboard away to allow for the skirting on the wall AND for the skirting on the actual door AND half the thickness of the door     JMB
« Last Edit: August 13, 2011, 09:07 AM by jmbfestool »
jmbfestool
Offline
« Reply #3 on: August 13, 2011, 09:04 AM » |
jmbfestool
Offline
« Reply #4 on: August 13, 2011, 09:31 AM » |
Any one use these before? *These*They seem perfect for the job and they move out on a gear as you turn the door how durable are they? They say they will do a 36inch door this door is only like 26 inch when I looked at it I didnt measure Also how do you remove the door? Looking at the diagram once you release the set screws the top pivot goes up because of the spring and the bottom will go down because of gravity so how would I reverse this to remove the door if I need to make minor adjustment or just need to remove the door in the future! JMB
« Last Edit: August 13, 2011, 09:33 AM by jmbfestool »
jmbfestool
Offline
« Reply #5 on: August 13, 2011, 09:45 AM » |
This seems a better option for my situation? Im talking to my self here lol! Funny! Pivot Hinge
SRSemenza
Global Moderator
Offline
« Reply #6 on: August 13, 2011, 10:08 AM » |
This seems a better option for my situation? Im talking to my self here lol! Funny! Pivot HingeGot it figured out yet ?  Seth
Festool Service 800-554-8741
jmbfestool
Offline
« Reply #7 on: August 13, 2011, 10:09 AM » |
This seems a better option for my situation? Im talking to my self here lol! Funny! Pivot HingeGot it figured out yet ?  Seth lol Im loving all the feedback and help! ---------------------------------------------------------- The last one I linked cost £77 which is alot for something so simple with no adjustment at all! A Little expensive but does look well madeA good alternative I think a lot better! If I was to get two top and bottom it would allow me to easily adjust the door the suite! and its alot cheaper I can get TWO for £36 I could do two doors with the for less than the above! Cheaper and Better?I just need to add a few washer or something to give a clearance gap on the bottom? JMB
« Last Edit: August 13, 2011, 10:13 AM by jmbfestool »
Peter Halle
Global Moderator
Offline
« Reply #8 on: August 13, 2011, 10:44 AM » |
JMB, Maybe it is because many of us have never done hidden doors. I have been doing this almost thirty years and have never done one. But it is amusing to see you talking to yourself  . Peter
jmbfestool
Offline
« Reply #9 on: August 13, 2011, 10:58 AM » |
JMB, Maybe it is because many of us have never done hidden doors. I have been doing this almost thirty years and have never done one. But it is amusing to see you talking to yourself  . Peter lol Im laughing to my self as well as talking to my self lol haahaa I have done umm 10 secret doors 3 different ways 1. SOSS hinge I think they are very expensive AND are a pain as they have no adjustment so I find the other brands which are very similar to SOSS hinges but have adjustment are better but never used them and they cost even more! 2. Got a loads of metal plates with holes and pins made especially, it was the Formans idea but I also found that very difficult to get the doors bang on especially the doors which where 2600mm high they where heavy. 3. I used normal Butt hinges and using a normal plain door I made and fixed a cupboard and shelves to it (this was my first ever secret door) what I know now I would of made if very differently but still it worked fine I built wardrobes on the other side which hide the door form the other side. Ill see if I can find pictures of these to post if any one is interested if not ill just post them and look at them my self heehee. JMB
Deansocial
Offline
« Reply #10 on: August 13, 2011, 11:36 AM » |
what about floor springs? maybe too epensive but door will shut itself
jmbfestool
Offline
« Reply #11 on: August 13, 2011, 11:39 AM » |
Link? I think I kno wa u mean I have looked at some they are about £200 or more?
« Last Edit: August 13, 2011, 11:54 AM by jmbfestool »
Deansocial
Offline
« Reply #12 on: August 13, 2011, 11:52 AM » |
yup
jmbfestool
Offline
« Reply #13 on: August 13, 2011, 11:54 AM » |
yay I have a friend to talk 2 lol!
Deansocial
Offline
« Reply #14 on: August 13, 2011, 12:00 PM » |
i'll talk to you but we'll have less of this friend business!!!
yeah they are expensive, hafele do 1 for 100quid but they discontinued half the bit by the looks of things
gckc117
Offline
« Reply #15 on: August 13, 2011, 12:05 PM » |
In terms of installing/removing pivot hinged doors- I've DIYed some pivot hinges for beveled edge doors, they were actually like giant shutters over windows but door-size and same concept. The fronts are perfectly flat/seamless and they attached through the back- mine were like 1 1/2" thick or so but you could do this on a 3/4" panel by routing out for it. I used round steel rod bent into an L, which acted as the pin and locked the door into place. I used sealed round (skateboard!) bearings set into the window sill and the bottom and top of the door. Since the appearance of the back of the door really didn't matter on mine I just attached a plate over the whole opening in the door to keep the L from swinging out when the door was opened, but I'm sure a nicer looking method could be engineered. This might sound confusing; think of one of those door bolts that flip down into a set position when locked so that they can't be shaken open. These were full size doors and worked flawlessly. Magnets for keeping them closed.
jmbfestool
Offline
« Reply #16 on: August 13, 2011, 02:13 PM » |
FINALY Thousands of photos later I found my first ever secret door! I still need to try and find the other secret doors but im a little fed up looking lol! Any way I only just finished my 2 year apprenticeship so have mercy! The Forman had left me two it on the job as he went on Holliday for a week and he gave me the keys and security code and told me all the jobs I had to do which was like a months work just for me and left me a list to let the other 6 joiners know what they needed to do if they finished what they where working on and make sure every one had all the materials they needed! It was fun! Any way! So I decided I wanted to work on this secret door well umm looking back at it I wouldnt split the door like I did I would do it like a full size door opening I dont know what I was thinking at the time! I wasn't like I am now and go on the internet researching all the time to make sure I know what I am doing and making sure Im doing it the best possible way! So I didnt have a clue how it was done back then I wish I did go on the internet and looked how other did secret doors Oh Well!! Pictures! I did everything in the bathroom I made the Units I made the secret door and built the ward drobes on the other side to hide the door.
jmbfestool
Offline
« Reply #17 on: August 13, 2011, 02:22 PM » |
« Last Edit: August 13, 2011, 02:35 PM by jmbfestool »
Sal LiVecchi
Offline
« Reply #18 on: August 13, 2011, 02:24 PM » |
JMB What a unique thing to do , It is really great the way the door opens up and it makes the bathroom look great. This was a great venture on your part. Good work as far as I a concerned.
Sal
Life is too short and the road is too long to drive anything less than a Festool
jmbfestool
Offline
« Reply #19 on: August 13, 2011, 02:37 PM » |
Sal
Thank you.
jmbfestool
Offline
« Reply #20 on: August 13, 2011, 02:44 PM » |
I did not do this bathroom but I did rip it out and built the wardrobes with a secret hatch. This bathroom was done by another joiner who worked for the company. The bathroom was umm no more than 1 month old and it was all ripped out and thrown into skip!  You can see in the corner der is a door with a little chrome knob well da is where the toilet is that stayed as they love loads of toilets as I can remember the house had 11 toilets!  Then I built this its not finished I did a little more work on it since the photo like fixing the styles in line with the walls but it never got painted it got ripped out again and burned!  as they had another change of mind and it become the landing instead of a bathroom so with in a few months it went from bathroom to walk in wardrobe to smaller dresser room/landing/ secret cupboard all walls knocked down and new studding dividing it all up I made a secret hatch to store his naughty stuff
« Last Edit: August 13, 2011, 02:46 PM by jmbfestool »
jmbfestool
Offline
« Reply #21 on: August 13, 2011, 03:06 PM » |
Just quick Vid of the secret hatch. I used the Paslode boxes as weights just to test it out as you can see it was a little heavy for me to pull down so I removed one lol  The where going to be replaced with sash weights but unfortunately it all got ripped out again and burned again!
jmbfestool
Offline
« Reply #22 on: August 13, 2011, 03:34 PM » |
I know its OFF-Topic but it was on the same job and I found these videos and pictures in the same folder so I thought I would still post it in here! I was walking into the canteen you can see it in the video in the background its a green container thing! Well you come round from the front so you can EYE the wall down and I have always noticed the wall with a bow in it BUT this time I noticed the BOW in the Wall was more I first thought nothing off it but I decided to walk over and I noticed the wall crumbling and I touched the door and it was loose and I remember it was fixed solid. I still didnt think much off it and just as the Forman past me I said do you think that wall is more bowed! He said yes! Then he panicked and told every one to get out of the building and told the ground workers to move away from the wall! One joiner ran back inside and put a acro prop under the oak truss to stop the roof going if the wall went! Watch what happens next!
The reason the wall collapsed because the grounds men where digging the ground away and dug below the footings and then when they where wackering the ground the wall started to give. So maybe I saved some peoples lives? or maybe some one else might of noticed it a few sections later who knows!
« Last Edit: August 13, 2011, 03:40 PM by jmbfestool »
jmbfestool
Offline
« Reply #23 on: August 13, 2011, 03:42 PM » |
You can see that one acro prop holding the entire roof stupid thing to do really wasnt worth risking his life for! but if it had gone it could of damage the building next to it which we had just finished making into a gym I need to find pictures of that aswell da is a nice looking gym!
JMB
jmbfestool
Offline
« Reply #24 on: August 14, 2011, 03:39 PM » |
Sorry I missed this post before! I think I understand how you have done it! Im not sure what to use yet for the push latch a magnet or non magnet I want a really strong heavy duty one but all I can find at the moment see medium duty and one heavy duty one but it looks ugly! JMB
gckc117
Offline
« Reply #25 on: August 14, 2011, 06:25 PM » |
yeah they are all totally ugly! CRL makes a decent stainless one for glass that you could epoxy to anything. The nice thing with a pivot hinge system is that they tend to swing real easily, so in my case we just used regular magnets, not too strong but they stay shut fine, and since the pivot is not all the way to the corner you could just push them open.
Tim Raleigh
Online
« Reply #26 on: August 15, 2011, 10:26 AM » |
Unbelievable! Good thing you said something. Jeesh...
fdengel
Online
« Reply #27 on: August 16, 2011, 12:13 PM » |
Secret doors are considerably less secret once documented, or when pictures are available...
Probably why good info is so hard to find?
Ken Nagrod
Restricted
Offline
« Reply #28 on: August 16, 2011, 04:19 PM » |
Same with that secret opening into the building. It aint a secret no more. So, JMB, who's picking up the tab for that disaster? Are you adding that specialty onto the side of your van? "I check walls for plumb, then run!"
woodguy7
Offline
« Reply #29 on: August 16, 2011, 04:32 PM » |
Ken, good one
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
