Author Topic: An improved leg vise  (Read 2702 times)
Offline derekcohen
    • In The Woodshop
« on: May 15, 2019, 09:05 AM »
This is an accessory for a leg vise to prevent the chop racking. There are other ways to do this - a deck of playing cards is easier - but I wanted to build it in, and not have to look for an accessory. Your bench may offer the same opportunity.
This is the anti-racking at work ...
How is this done? Alongside the leg is a "depth stop" built from a screw. It can be adjusted for the desired length ...
I designed and built this a few years ago. Rob Lee came to visit, and commented that the design needed extra reinforcement to prevent being bent back. He was correct, and I have now used angle sections to attach it to the leg. Solid as a rock ...
Online ear3
Re: An improved leg vise
« Reply #1 on: June 08, 2019, 08:20 PM »
Thanks for posting derek. The form factor definitely beats the vise shims! https://www.woodpeck.com/one-time-tools/vise-shims.html
