Author Topic: What a find.  (Read 4213 times)
Offline Lemwise
What a find.
« on: April 16, 2017, 11:54 AM »
Look what I just bought, a pre-war Stanley No 3 with the original hardware and rosewood handles. No cracks in the sole, cheeks or wood. It was dirt cheap as well, just €55, that's $59.
Offline ear3
Re: What a find.
« Reply #1 on: April 16, 2017, 11:59 AM »
Congrats.  Are you going to modify at all with a new blade, frog, or chipbreaker?
Offline DrD
  • I might not be fast BUT I sure am slow
Re: What a find.
« Reply #2 on: April 16, 2017, 12:21 PM »
That is truly beautiful!  Congrats!
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline Lemwise
Re: What a find.
« Reply #3 on: April 16, 2017, 12:23 PM »
If the blade is in good shape I will probably only put an after market chip breaker in it. Workshop Heaven sells very nice 3mm thick Quangsheng chipbreaker. (they also have a very nice stainless steel cap iron). A thick chipbreaker like that is enough to dampen and stabilise the blade. I will most likely sand the handle and knob back to bare wood and put a 2K clear wood sealer on them. Flatten the sole and that's it. I'm not going to do anything about the patina. It shows the age and that it's been used. I like that.
« Last Edit: April 16, 2017, 12:29 PM by Lemwise »
Re: What a find.
« Reply #4 on: April 16, 2017, 12:26 PM »
Wow...didn't realize that there was even a modern market for these things between LN, Lee Valley, Marcou and Bridge City. Maybe it's time to clean house...  [smile]
Offline Lemwise
Re: What a find.
« Reply #5 on: April 16, 2017, 12:31 PM »
Old Stanley planes, especially from the pre-war era are very good. The casting, machining and quality of the blade is miles ahead of what Stanley makes these days. If you have some old Stanley planes I'd put them on ebay. They sell like hot cakes.
Offline T. Ernsberger
Re: What a find.
« Reply #6 on: April 16, 2017, 01:05 PM »
Are you sure it's pre war.  Pre war has Key Hole lever caps.  Your plane has a kidney shaped opening in the lever cap making it post war.
Offline Bob D.
Re: What a find.
« Reply #7 on: April 16, 2017, 01:42 PM »
I believe the kidney shaped cap iron came into being in the 1930s.
A great resource on old Stanley planes is Pat Leach's site Blood & Gore.
http://www.supertool.com/StanleyBG/stan0a.html
Info on the Stanley #3 can be found here.
http://www.supertool.com/StanleyBG/stan1.htm#num3
« Last Edit: April 16, 2017, 01:48 PM by Bob D. »
Offline Lemwise
Re: What a find.
« Reply #8 on: April 16, 2017, 01:48 PM »
As far as I know Stanley started making the cap iron with the kidney shaped opening in 1936. And even if it's post-war it's still miles ahead of modern Stanley planes. At this price I'm not going to complain about a few years.
Offline Bob D.
Re: What a find.
« Reply #9 on: April 16, 2017, 01:54 PM »
Agreed. The price seems reasonable for what I see in the photo. I don't have a #3 myself but about a half dozen or so other sizes that I put to use occasionally. They are not just collecting dust on the wall.
« Last Edit: April 16, 2017, 01:57 PM by Bob D. »
Offline Lemwise
Re: What a find.
« Reply #10 on: April 16, 2017, 02:09 PM »
Not to mention I trust the seller. He just doesn't clean the tools. You buy them in the state he finds them in. After disassembling and cleaning the whole thing it will look much better.
Offline Lemwise
Re: What a find.
« Reply #11 on: April 16, 2017, 02:34 PM »
My biggest complaint of planes in general are about the collectors who never use them making prices higher for older tools which were meant to be used as tools but instead they just sit on a shelf like "my precious" from Lord of the Rings.
But it's more fun to look at them than to use them!
Offline tony_sheehan
Re: What a find.
« Reply #12 on: April 16, 2017, 06:44 PM »
Really nice find Lemwise. I love my No3, it's a plane I use a lot. Mines completely standard- I've never felt the need to change the blade or cap iron.
Offline curiousdork
  • I code and woodwork.
Re: What a find.
« Reply #13 on: April 19, 2017, 03:07 PM »
My Type-9 5 1/2C from 1910-1912 is a solid hand plane.  Picked it up on eBay for $72 w/ shipping.  It was in good condition and I cambered the blade so that it's a scrub plane.  The first plane I ever purchased was a 2000 something Stanley Sweetheart 62.  It's a decent blade but the construction of the 5 1/2C is something else, you can feel the difference.
