Author Topic: Basic router question  (Read 2912 times)
Offline lshah72414
« on: January 14, 2017, 05:06 PM »
I am very inexperienced. I am trying to use a round over bit on (festool 1400 router) edges of oak (30" long x 4" wide x 1/2 " thick).  I have an mft/3 table with clamps. I was trying to practice on scraps before I did actual cuts. I cannot hold piece due to thinness(width) of material. Also, even if I could hold I can't use chip catcher underneath router because it is so thin. If I had a table saw with router bit and fence I can see how to do it. But with what I have, I can't figure it out. Do I have to make a template of sorts?  Any suggestions or should I start looking for someone with a table saw? Thank you
« Last Edit: January 14, 2017, 05:09 PM by lshah72414 »
Offline SRSemenza
Re: Basic router question
« Reply #1 on: January 14, 2017, 06:05 PM »
   I am assuming the round over bit is the type with a bearing to run along the edge of the wood?
    You should be able to clamp the piece along the edge of the MFT with a little overhanging / protruding beyond the edge of the table. Maybe not with Festool clamps depending on the distance to hole locations , but with some type of bar clamp or quick clamp.
    Put one clamp near the middle of the piece and a second at the opposite end from the end you are routing from. Route half way until you reach the middle clamp, ease the router out and turn off. Move the far  clamp to the beginning of the cut where you have already routed, and shift the middle clamp enough to allow room to ease the router into the middle and continue.
    Be sure the clamps are tight AND clamped fully over the table surface, NOT  partly over the metal table side in such a way that the piece could tip down while routing.
     You should be able to use the dust cup as well.
Offline lshah72414
« Reply #2 on: January 14, 2017, 06:21 PM »
Sir,
When you say shift the middle clamp, I assume you are meaning behind the router?, because the problem I am having is the base of the router is wider than the material itself. Thank you for your help.
Offline lshah72414
« Reply #3 on: January 14, 2017, 07:32 PM »
Just did what you said and it worked perfectly.
Thank you again
Offline rst
« Reply #4 on: January 14, 2017, 08:57 PM »
Double sided tape can be your friend in those circumstances.  Tape to a larger piece that can be clamped.
Offline SRSemenza
« Reply #5 on: January 15, 2017, 12:20 AM »
Thank you again
Great, glad it worked out!
Basically do part of it, move the clamps to the part you just did, do the rest.
Offline Holmz
« Reply #6 on: January 15, 2017, 12:53 AM »
... Do I have to make a template of sorts?  ...
If you were doing a lot of the same sized parts, then something that was also 1/2"thick for the router to bridge across would alleviate/ameliorate issues with the router rocking.
So the "router rest" could be screwed to a piece of MDF 'IF' the roller follower did not foul it. Or extra pieces of MDF could be placed under both the 30x4" and "the router rest".
Obviously a router table would be a another good/ideal solution.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #7 on: January 16, 2017, 12:35 PM »
Though Im a little late but look at one of these
https://www.woodcraft.com/products/bench-mate-non-slip-pad
Online Peter_C
« Reply #8 on: January 16, 2017, 03:24 PM »
I am really late, but maybe you didn't know about this accessory for your router. It also requires the fine adjuster accessory, but it is designed for edging material.
https://www.festoolusa.com/power-tool-accessories/routers/other-accessories/edging-plate-486058
Offline mwildt
« Reply #9 on: January 17, 2017, 08:41 PM »
A basic carpet underlay for an area rug works similar. Most home stores have them in different sizes.
Offline johnbro
« Reply #10 on: January 19, 2017, 03:29 PM »
Just set your workpiece on top of a piece of scrap; place both on the MFT and clamp down. The scrap will hold the work up high enough that you can run the router without hitting the table top. If the clamps interfere with the router just move the clamps and do the roundover in stages. Bob's your uncle.
TS 55, 3 guide rails, MFT 1080, RO 150, ETS 150/3, MFK 700, OF 1400, Kapex 120, Domino 500, CT 26
Offline grbmds
« Reply #11 on: January 19, 2017, 03:53 PM »
I always found that the simpler the better. Peter's suggestion was maybe the best because it was straightforward. Is it inconvenient to have to move the clamps several times? Sure it is, but it works and takes no time to set up. Starting out, it's easy to get frustrated and simple is less frustrating.
Randy
