ForumMFG
Offline
« on: November 13, 2009, 01:15 PM » |
Now that i finally got the move done into my new home it was time to fix up the condo. Well, i spilled a whole gallon of paint on the front porch which is cement. I got most of it up except for the paint that dried. Any advice on removing the paint without a pressure washer? Im really in need of some advice!!!
Brice Burrell
Offline
Remodeling Contractor
« Reply #1 on: November 13, 2009, 01:21 PM » |
Dave, do you have an angle grinder, if so try a wire wheel. Or you could try the Rotex, I'd use a chemical remover otherwise.
Alex
Offline
« Reply #2 on: November 13, 2009, 01:54 PM » |
Angle grinder + wire brush seconded. It's gone in a jiffy. Actually did this last week. Rotex doesn't work.
Precisio CS70 EB Set, T15+3, Rotex 150 FEQ, Deltex DX93 E, DS400 EQ, DTS400 EQ, RTS400 EQ, ETS125 EQ, CTL22 E, CTL Mini.
Peter Halle
Global Moderator
Online
« Reply #3 on: November 13, 2009, 02:04 PM » |
Dave,
Was it latex?
If so, denatured alcohol will dissolve it. test in a small area. Use rags and wear a respirator. I've used it to get spills off of brick.
With an iPad the FOG is always with you..
Thank you for making this Forum what it is.
ForumMFG
Offline
« Reply #4 on: November 13, 2009, 03:16 PM » |
I don't have a angle grinder so I will try some chemicals tonight. If it doesn't work, I'll try borrowing a angle grinder.. Thanks guys.
woodshopdemos
Inactive Member
Offline
« Reply #5 on: November 13, 2009, 03:38 PM » |
I have used a scraperwith success. I personally think the effort should be to remove as much as possible without chemicals...and save them for the last. Once they dilute the paint, it becomes harder to remove...in my thinking.
In memory of John Lucas (1937 - 2010)
Tom Bellemare
Festool Dealer
Offline
« Reply #6 on: November 13, 2009, 03:51 PM » |
This is a Festool forum isn't it? LS 130 plus Scraper I've never tried it but it could work quite well... Tom
Rutabagared
Online
Location: Southwestern Pennsylvania (USA) Member Since: Jan 2008
« Reply #7 on: November 13, 2009, 04:20 PM » |
Dave, Would it be feasible to just paint the porch?
Joe
Brice Burrell
Offline
« Reply #8 on: November 13, 2009, 04:35 PM » |
Joe
Joe, this is a power tool forum, your reply is off base unless you'd suggesting Dave buy a sprayer to paint the porch. Look at Tom as an example of our kind of thinking.
Neill
Offline
« Reply #9 on: November 13, 2009, 04:50 PM » |
Joe
Joe, this is a power tool forum, your reply is off base unless you'd suggesting Dave buy a sprayer to paint the porch. Look at Tom as an example of our kind of thinking. Brice, Boy, talk about a "homer".  Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
ForumMFG
Offline
« Reply #10 on: November 13, 2009, 05:07 PM » |
Joe
Not so much=)
Charimon
Offline
Living LEAD in the midwest
« Reply #11 on: November 13, 2009, 07:46 PM » |
a pressure washer and shopvac will work well If you have a small electric pressure washer, hook it to hot water like the hot on the clothes washer through a garden hose. you can slice a hole in a cheep vac hose and slide the nosle through and away you go.
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
Peter Halle
Global Moderator
Online
« Reply #12 on: November 13, 2009, 07:49 PM » |
Craig is correct. If you can gain access to a hot water pressure washer it is amazing what they can do. I saw a painter take 15 year old paint spills off of brick and mortar with one. Might be worth calling someone - unless this is a reason to get a tool. Good luck Dave.
paul_david_thomas
Offline
Location: Winchester, Hampshire, United Kingdom Member Since: Aug 2008
« Reply #13 on: January 6, 2010, 06:30 PM » |
A little petrol on top of the paint a lighter and a pair of running shoes... It should get rid of it AND you get to burn things - double brilliant !
TS55, MFT/3x2, Domino, CMS, C12, RO150, RTS400, Kapex 120, Midi, OF1400, MFK 700 & Two German Wirehaired Pointers :-) They really help ! Winchester, Hampshire, UK
