Author Topic: .  (Read 4317 times)
Offline Cochese
    • The 144 Workshop
« on: September 25, 2014, 10:29 AM »
« Last Edit: August 24, 2015, 04:24 PM by Cochese »
Offline GOT8SPD
Re: Custom closet advice
« Reply #1 on: September 25, 2014, 11:10 AM »
I have a similar problem, however, I have that left nook on BOTH sides of my closet.  I think i'm just gonna put shelves.
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #2 on: September 25, 2014, 11:35 AM »
could put shelves  w/ wicker baskets, maybe make a shoe rack, make it a hidden storage area lock and key...
Offline GreenGA
  • JR
« Reply #3 on: September 25, 2014, 12:57 PM »
Would you mind reposting the SketchUp with dimensions all around?
Never use a 2x4, when a 2x6 will do just as well.
SYS-Lites, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, C12 Set, T18 Set, Ti15 Set, CT48 w/Boom Arm, Carvex PSBC, HL850, HL65L, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino 500 & 700 Sets, MFK700 Set, OF1010 EQ, OF1400, OF2000E+, MFS700, FS3000/2, LR 32-SYS+97" rail, 2011 Centrotec Set, Metric and Imperial Zobo Forstner Bit Set, VS600 Dovetail System, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sys, Sorts, Minis, Midis, Maxis. Attics, Classic, New and Blue).
Coming Attractions: Workcenter, NAINA when available.
Offline BMH
« Reply #4 on: September 25, 2014, 01:15 PM »
My daughters had the same issues with their closets. After thinking about it for a while I reframed the front to be flush with the sides and ceiling and was able to make a nice built closet in for them with no loss space
Offline Brent Taylor
« Reply #5 on: September 25, 2014, 02:22 PM »
I have in the past I've used this type of space as a hidden storage area. Maybe think about building a cabinet with a door that begins under the shelf rod made out of the same material as the closet system that you are going to use and get a hidden lock with the magnet key and euro hinges. makes a great place to stash long guns and paperwork. Brent
Offline Billedis
« Reply #6 on: September 25, 2014, 02:24 PM »
I concur with BMH, would look much cleaner.
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #7 on: September 25, 2014, 07:52 PM »
Cabinet type door on the left area facing the room, or the drawers you want that pullout into the room. Maybe a pullout. Piece of plywood to cover the new shelves from the inside of the closet.
Treat the balance as a normal closet.
Offline tjbnwi
« Reply #8 on: September 25, 2014, 09:11 PM »
I'm afraid you've lost me. Just cover up that little section?
If you open the small area to the room cover the side facing the closet so items on the shelves will not fall off into the closet. Access is now from the bedroom no need to fight the clothes to get to the shelfs and allows you to design it as a simple closet shape.
Offline wow
  • Inactive Member
« Reply #9 on: September 25, 2014, 09:15 PM »
I don't know how functional it would be, but what about a 'lazy susan' type arrangement. You'd swing it to the left, exposing the contents that are 'hidden' in that section?
Of course you'd have to leave the area in front of it unblocked, which may or may not result in additional storage area.
Offline GreenGA
  • JR
« Reply #10 on: September 26, 2014, 10:11 AM »
Do you have any restrictions or the like?
Do you have an idea of how much you intend, or need to, store in the closet?
Oh, is there power in there for light?
Offline Billedis
« Reply #11 on: September 26, 2014, 02:29 PM »
I don't know if you saw this when I posted it once before, but I had a 24" deep closet 8" wide, and it had two out swing panel doors that were 60" total.  I opened up the closet to 8' x 8' and built the three 32" wide 8' high cabinets and just slid them in.  To keep the carpet intact you talk about, you could open it up, and instead of 24" deep, make the cabinets 28" deep.  Take a little more material, but you gain a lot of drawer space.  Here is a photo.  I made them out of poplar and just cheap Lowe's Sandply for the carcases.  I used Sherwin Williams stain, 6 coats of hand applied wipe-on poly, sanded to 320 between each second coat, then finished with Bri wax applied with 0000 steel wool, then a coat of wax applied and buffed with micro fiber cloth.
