Author Topic: Horror show stairwell  (Read 6249 times)
Offline ear3
« on: December 26, 2016, 01:41 PM »
I was hoping to solicit some advice on the project I've been working on, which is a large stairwell.
Some background -- this is actually the second time this year we've worked on the stairs.  It's covered with these 3/4" thick end grain doug fir tiles, and had these thin maple caps at the front of the tread.
255996-0
255998-1
256000-2
You'll see that the thick part of the maple cap is a lot narrower than the channel it's supposed to fit into.  Not only that, but the front edge of the wooden tile where it meets the cap is actually back beveled 5-10 degrees, so there is all this additional space between the cap and the tile the lower you go.  There are many other features of how the stairs are constructed that just kind of make you scratch your head.  They were also originally stained white, so they scuffed up very quickly.
They have had problems with the stairs almost from the moment they were installed.  So we were asked last year to sand down and fill the gaps that had developed especially near the front of the treads (almost certainly, as we just recently found out, because of the spacing between the maple cap and the front row of tile on the tread), as well as reattach the maple caps that were coming up in a few places.  We did so, but with the warning that there might be more serious issues with the stairs that a cosmetic resurfacing was not going to solve.
Well, a year later, we're back, and dealing with the exact same problems.  The problems have been exacerbated by the fact that the custodial service has apparently been mopping the stairs with copious amounts of water.  They didn't want to do a complete overhaul, so we settled on a partial rehab, with disclaimers that this still may not be a long term fix, and recommending too that the stairs won't be mopped like they were.
The main part of the fix involves redoing the maple caps -- cutting a channel in the front of the stairs with the tracksaw (and finishing up with the Vecturo on the ends) so that they're actually resting on and can be secured to the wooden tiles, as opposed to just butting up against them (and also filling in the gap left by the previous maple cap, and using a generous layer of adhesive and fasteners to make sure the new cap doesn't come loose).  A router would have been more efficient, but there were too many variables to control (nails in the path of the channel, the bowing out of some of the stairs) to make it that much faster such that it would justify the risk you take with one errant move of the tool.
256002-3
I made the caps wider and a consistent thickness (which is thicker at the edge than they previously were).  This should cut down on the movement in the front of the treads that was causing the filler to disappear and gaps to open up.
256006-4
But we've now run into a problem with one of the stairs, where the subfloor itself is actually coming up.  The subfloor is just a layer of 3/4" ply over the concrete structure of the stairs.
256004-5
It's not clear whether it's coming off of the concrete or just delaminating, but we're going to have to take out some of the tiles to investigate.  So my question is whether a repair can be done that doesn't involve ripping out the plywood subfloor of that entire stair.  Since the plywood is itself resting on the solid surface of the underlying concrete, it's not a question of degraded structural integrity, but simply flatness -- so wouldn't it be possible to remove tiles in a few strategic places, then secure the ply to the concrete using something like tapcon/blue screws?  What about shooting some additional adhesive under the ply where the screws go to up the holding power to the concrete?
What would you guys do to make the best of what is this less than optimal situation?
« Last Edit: December 26, 2016, 01:51 PM by Edward A Reno III »
Offline awil66
Re: Horror show stairwell
« Reply #1 on: December 26, 2016, 02:32 PM »
Your plan seems like a plan. Since the stairs are concrete it is probably the ply or the tiles themselves buckling up. Probably from the copious amounts of water they have been subject to.
I would cut out some tiles first, see what the ply looks like, but I think you already know. You may have to remove a section of ply and install a new piece. I would use the best PL glue or maybe the marine grade epoxy glue. You can't trust future cleaners to follow directions.
Best of luck.
Offline rizzoa13
« Reply #2 on: December 26, 2016, 05:14 PM »
Squeeze glue in wherever you can and use tap one or a shotgun with washers to get the ply to stay put. (If it's right on the edge of a concrete stair nose don't use the shotgun 😳). The real fix is to redo the whole thing and properly seal the concrete with some type of roll on membrane, but you already know that and they don't wanna pay for it!
Offline BMAC
  • BMAC Construction & Consulting Ltd.
« Reply #3 on: December 26, 2016, 05:46 PM »
For re-glueing the subfloor to the underlying concrete I'd suggest injecting hot melt glue from Pamtite (Fastenmaster) it is crazy strong and sets up to full strength in 5 minutes. Originally designed to install tackless carpet strips (called smooth edge here) and the carpet can be power stretched in 5 minutes instead on glueing with PL with requires 24hours to set up before power stretching (some concrete you can't nail the strips down if there is in-floor heating in the slab.
I do insurance restoration and repairs as well as New Home Warranty claims and on one job I did last year I successfully drilled a 1/16th" diameter hole and with a similarly sized glue nozzle injected glue under a 1 foot diameter small void where an expensive engineered tiger wood floor that was squeaking every time you walk on the area. I saved having to replace $20k of flooring. The hole small injection hole was placed in a dark mineral streak and filled with a coloured hard wax to match and you can't see the hole at all.
I also did a similar repair to a single tile 24"x24" that had a small hollow sound near a grout line and I drilled a number of 1/16" holes in the grout line adjacent to the void and inject Pamtite glue there too. After the repair I re-grouted the repair area and it was perfect. Saved them $10K as this was a large Ensuite with the same tile on the walls of the 7 foot shower and around the soaker tub.
I even use the glue gun to attach MDF base to my projects as it saves me a ton of time. No nail heads to fill, sand a paint. I take ALL of my base measurements ahead of time and I cut all of the base in the shop and the base is then pre-painted in the shop ready for installation at site. I also use a caulking kit that I've previously added the matching paint to so that way I don't even need to much if any paint touch ups at site
« Last Edit: December 26, 2016, 06:21 PM by BMAC »
Bruce
Support services for the Fire and Flood Restoration Industry. Specializing in custom cabinetry restoration and millwork.
Offline ear3
« Reply #4 on: December 26, 2016, 07:33 PM »
I didn't know about the PAMTite.  That stuff looks slick, and the injector is small enough -- gonna look into that as a possible solution.  Thanks.
Offline BMAC
« Reply #5 on: December 26, 2016, 08:20 PM »
Pamtite is also a German made solution, go figure!
Bruce
Offline BMAC
« Reply #6 on: December 26, 2016, 08:29 PM »
I've also used it to fasten down threshold transition strips. It also states that the American New Wood Flooring Assoc. has approved it for wood flooring starter strips.
Although it's not your Grandma's hobby glue gun it's still priced decently at about $115 here in Canada (less for you I'm sure) and glue sticks are about $15 a pound at my flooring supply distributer. You must use the Pamtite gun as the heat has to be something like 395 F. Just remember to wear at least some disposable latex gloves when using as the hot glue doesn't feel to good when you accidentally come in contact with it (yup, happened to me...).
Good luck Edward
Bruce
« Last Edit: December 26, 2016, 08:53 PM by BMAC »
Bruce
Offline ear3
« Reply #7 on: December 28, 2016, 09:22 PM »
We took out a few of the tiles on that problem stair today to get an idea of what we were dealing with. I actually wasn't on site but will be going in tomorrow to attempt the fix. It's hard to tell from the pictures since there is so much adhesive underneath the wooden tiles, but it looks like the ply is still intact.  You can see, however, that the buckling was occurring right at the seam of two pieces.  We got the PAMTITE and so will use that with a few fasteners to resecure the ply. Depending on what I find tomorrow when I'm actually looking at it, I may even consider cutting a small slice off one of the pieces of ply to relieve some of the pressure that was causing the buckling. I assume that would be an Ok thing to do - just a sliver, not a huge channel, and something that can be filled to prevent water from dropping underneath.
Good luck Edward
Bruce
« Last Edit: December 28, 2016, 09:27 PM by Edward A Reno III »
« Reply #8 on: December 28, 2016, 09:44 PM »
 Hey Edward...not trying to be cocky, but there's a reason most subfloor providers/manufacturers  stipulate at least a 1/8" gap between adjoining sheets of subfloor. It's a time proven process.
Offline ear3
« Reply #9 on: December 28, 2016, 10:10 PM »
Lol.  So I guess I'll bring it up to spec then!  Like I said, there were many things with the design/construction of the stairwell that are curious to say the least.
« Reply #10 on: December 29, 2016, 12:32 AM »
[thumbs up]...ya that's all you can do. Sometimes wood, as much as we think we own it...really owns us. Metal I can control...wood however, it never dies. It's only dead relative to our conception of death. That's many times the love/hate relationship with woodworking.
Offline ear3
« Reply #11 on: December 30, 2016, 09:00 AM »
Well, went through with the fix yesterday.  After clearing out all the adhesive and various gunk, turns out they had left some space in between the underlayment
256222-0
Even so, I cut a little off one of the edges to slightly widen the gap so it would make the adhesive application easier.  The plywood was fine -- no delamination -- but it was definitely coming up off the concrete structure of the stair.  So I decided to peel back a few more pieces of tile, working carefully with the Multimaster armed with a scraper blade to undercut the adhesive, and then a chisel to bust it into pieces, so as not to disturb the adjacent tiles
256224-1
Added some access holes for the PAMtite further from the edge (I realize now that I made the holes too large -- I'll do it right next time), and predrilled the holes for the tapcon screws -- I couldn't get all the way to the front edge with the screws, because there was a thick metal strip at the front edge of the stair that I didn't feel like messing around with, but I felt comfortable with how much anchoring I was able to set up elsewhere on the board.
256226-2
256228-3
Not sure if I worked too slowly (the PAMTite sets REALLY fast), or if I used too much glue, but when I locked everything down, the boards were not completely flat, and there remained a slight undulation.  The ply is locked in place however, so I just decided to work around the problem at the final stages.
I filled the gap with caulk, then pieced the tile back in, using the PAMTite so it would be ready to work on almost immediately:
256232-4
Then used the RAS to flatten out the undulation, which worked quite brilliantly
256234-5
Set the tracksaw to cut the channel/rabbet in the overhanging pieces
256236-6
And voila, it's like nothing ever happened
256238-7
256240-8
I put the maple cap on shortly thereafter, and tomorrow we will come back and fill it in preparation for final sanding
256242-9
So thanks again @BMAC for the word on PAMTite -- really a remarkable adhesive, that we will no doubt make use of in the future now that we have the kit.
« Last Edit: December 30, 2016, 09:23 AM by Edward A Reno III »
« Reply #12 on: December 30, 2016, 11:43 AM »
This PAMTite stuff is rather interesting, the Flex 40 in the green package, has only 40 seconds of open time and it fully cures in 5 minutes.
Offline ear3
« Reply #13 on: December 31, 2016, 08:59 AM »
We finished up all the prep work yesterday, and will begin applying the finish over the course of the weekend. At one point yesterday we had 4 vacs going at once, which included my ct26 and the CT sys I just picked up specifically for this job -- three people sanding and me rounding the corner of the maple caps with the of1010.
256272-0
Thankfully it looks like the nightmare is over and we will bring this job to a successful conclusion.
Offline HarveyWildes
« Reply #14 on: December 31, 2016, 11:11 AM »
Nice work.  The design of the stairwell, and in particular using end grain for treads, is certainly challenging.  I can see where there is a much higher risk of water damage.  Nice job on the repairs.
What are you going to use to finish the treads to mitigate the risk of future water damage?  I can see two options - something that sinks down relatively deeply into the grain to plasticize it, and/or something really tough and impermeable that sits on the top.  Also, are you doing anything to keep water from seeping down to the sub-floor layer.  If water does get down there, is there a good way to dry it out?
Also, what is the purpose of the shelf about half way down the stairs.  Is it permanent or temporary?
Offline Scott in Bend
« Reply #15 on: December 31, 2016, 01:05 PM »
Nice job Edward.  Great pictures, too.  The end grain stairs reminds me of some old factories and shops that had wood block floors.
Also, thanks to BMAC for recommending PAMtite.  That is a new product to me and could be useful on some of my future jobs.
Offline Tinker
« Reply #16 on: December 31, 2016, 02:34 PM »
>>>Also, what is the purpose of the shelf about half way down the stairs.  Is it permanent or temporary?<<<
I had been looking at that also.  If it stays there, I would want to have a signed disclaimer in case of ANY accident which is just begging to happen.
You have done a great job on your repair. I would be concerned that if water has been used before, it will be used again. The finish you use needs to prevent water penetration.  I have no recommendation there.
Tinker
Wayne H. Tinker
Offline BMAC
« Reply #17 on: December 31, 2016, 06:00 PM »
@Edward A Reno III
Great repair job! Looks like a lot of hours but a fantastic result for the client.
Yup the Pamtite adhesive system is pretty versatile and yes, you have to work quick! I should've mentioned that it's beneficial to experiment of a number of scraps pieces.
I just picked some of the 40 second open time glue sticks (something newer). I usually use on MDF base boards installs the 1 minute open time sticks. Every once and a while I need an even slower open time and they do have 2 minute open time sticks. All of the various "open" time glue sticks reach full cure in 5 minutes.
Bruce
Offline ear3
« Reply #18 on: December 31, 2016, 07:38 PM »
Thanks for the compliments. Theres actually three of those "shelves", which are part of the original design. They get covered by cushions as quasi stadium seating for presentations or movies that can be projected on the large white wall opposite the landing.
Not that I mind, but the people who will walk up and down the stairs -- while they might be able to tell a slight difference in terms of the larger maple caps -- will have no idea just how much work and pain went into bringing the stairs back to status quo. It's almost more trouble to fix someone else's workmanship rather than scrap it and build it from scratch, since you're boxed in by all the choices they made.
I'm not very knowledgeable about finishes, so I didn't end up choosing it, but we're using a product called lecol loba 2k: http://www.floorsalesonline.com/lecol-loba-2k-invisible-protect.html
The main goal was to get as natural looking a finish as possible, which this finish is apoarently good at.  The one extra water protection measure we are using is to run a small bead of clear caulk along the edge where the train meets the riser.
Offline Bert Vanderveen
« Reply #19 on: January 01, 2017, 11:44 AM »
End grain block floors were almost always laid in/on sand, just like the parquet floors of old. My guess is that the sand takes care of a lot of the moisture problems that might occur. Using them on stairs, like in this example, would be more problematic.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
« Reply #20 on: January 01, 2017, 12:24 PM »
That's pretty interesting stuff Edward...they also mention that it has increased anti-slip properties. Important stuff for a public place.
I'd be interested in a photo after you've coated the steps and really interested in the long term performance.  [smile]
Offline ear3
« Reply #21 on: January 04, 2017, 08:30 PM »
@Cheese Here's some pics of the finished stairs after 3 coats. Fingers crossed for long term durability.
The client was pleased.
« Last Edit: January 04, 2017, 08:33 PM by Edward A Reno III »
« Reply #22 on: January 04, 2017, 11:40 PM »
Thanks for the update Edward, the step caps look great and I really do like the "stopping off areas" that are placed along the way.  It rather works with the artsy...fartsy program.  [big grin]  I'm serious...
I'm also really interested in the long term performance of this coating, anything made or developed in das fatherland, always makes me sit up and take note.
