Pages: [1]   Go Down
  Print
Author Topic: Bandsaw in NJ?  (Read 1530 times)
Vindingo
Offline Offline
« on: April 20, 2012, 09:00 AM »
Is there anyone in the north Jersey area that has a bandsaw capable of resawing 8-10"?
I need two pieces of 2" thick walnut resawed in half.  Normally I would use a router to surface the board, but I would rather not turn half of this beautiful piece of wood into router shavings.  The two pieces will be 8"x20", the board below is getting ripped in half.
I'm flexible, send me a message or reply to the thread
Any help is much appreciated.
Vinny
Edit:  I'm in Morris county
« Last Edit: April 20, 2012, 09:06 AM by Vindingo » Logged
jmarkflesher
Offline Offline
Scoot
« Reply #1 on: April 20, 2012, 08:29 PM »
Flemington, NJ. 20 min north of Trenton by the Delaware river.
DEC 21st, 2012 TIC TIC TIC   WAS A DUD
Vindingo
Offline Offline
« Reply #2 on: April 25, 2012, 10:25 PM »
Google maps puts me at about an hour away.
A 14" Jets bandsaw for $250 on CL slipped through my fingers the other day.
I will follow up with you soon, if I don't find someone closer or just end up buying a bandsaw.
craig feuerzeig
Offline Offline
WWW
« Reply #3 on: May 04, 2012, 10:39 AM »
If this is still an issue Vinny, you're welcome to use mine.
Bowclamp "good caul"
Wood_Junkie
Offline Offline
« Reply #4 on: May 04, 2012, 10:48 AM »
Don't sweat that miss... $100 more for a riser kit; $30 more for v-belt upgrade so the motor doesn't slip or shimmy.. add a good resaw fence and such for another $100+... and don't forget a quality resawing blade.. $35.
Then you finally can resaw 8"-10".  At approximately 20-30 minutes per board (it is slow going with that thickness)
jmarkflesher
Offline Offline
Scoot
« Reply #5 on: May 04, 2012, 03:23 PM »
I sure hope it's not 20 to 30 mins. I just ordered a 3/4" Lenox Tri-Master Carbide- Tipped blade from Highland Tools. I had my 1/2" for 15 years and just pinched it cutting a PVC pipe in half. MISTAKE. New blade $175.00 delivered. !/2" cut black walnut short logs like silk.Guess that's what you're paying for.
« Last Edit: May 04, 2012, 03:27 PM by jmarkflesher » Logged
Pages: [1]   Go Up
  Print
Jump to:
