Ken Nagrod
Restricted
Offline
« Reply #30 on: May 31, 2012, 03:30 AM » |
Sorry about the blurry pictures, I had oil all over my phone.   Looks gorgeous, Darcy!
Phred
Offline
« Reply #31 on: June 09, 2012, 12:40 AM » |
Scott and others:
Thanks for all of the information. I need to refinish my deck this summer. It's cedar and I'm not sure what was last applied. Before using Penofin Marine Grade, I plan on sanding with Granat 80 grit. I also plan on doing just a few boards at a time or I won't be able to reach them to rub out the excess.
Do you also recommend using any stripper/prep products or should the sanding (RS2 E hooked to CT22) be sufficient on its own?
Thanks in advance, Phred
Phred
Offline
« Reply #32 on: June 12, 2012, 09:09 PM » |
Here are a couple of photos of the current condition of my deck. Any advice on prep (sanding, washing, pressure washing, stripping, etc.) would be appreciated! Also what is your typical prep for a deck treated with Penofin and renewed annually? Thanks for looking, Fred
« Last Edit: June 12, 2012, 09:25 PM by Phred »
ericbuggeln
Guest
« Reply #33 on: June 12, 2012, 10:09 PM » |
Whatever you do dont pressure wash it. You will leave marks everywhere. If you want to do it right and you want it to look like Warners posts you will have to sand it fully. Do you have a RO 150? It would pay for itself if not. Get 50,80,120 grit. Ive used Rubin in the past but others will also work. Do one pass in the lower grit 50 or 80 depending in the grinding setting and one pass with 120 in the fine finish setting to sand out swirls from first pass. This is only what has worked for me on certain decks, you may need more or less sanding. blow it off really good before finishing. Yours looks easy from the pics. Sink all nails and screws before sanding, Eric
lpand
Offline
« Reply #34 on: June 13, 2012, 12:17 AM » |
« Last Edit: June 13, 2012, 12:19 AM by lpand »
Scott B.
Magazine/Blog Author
Offline
Paint contractor and freelance writer.
« Reply #35 on: June 17, 2012, 08:54 PM » |
Hey Lloyd Sorry I missed this. For best results on new or sanded wood, do two coats of this:https://epifanes.com/na/store/varnishes-and-clear-finishes/woodfinish-gloss/ Followed by 1-2 coats of this:https://epifanes.com/na/store/varnishes-and-clear-finishes/woodfinish-matte/ Sand between coats. 150/180/220/240 is a nice range to be in as you step up through the grits. And I absolutely recommend using the epiphanes brushing thinner. It is critical. Also, the pricing in these links is really good, WAY better than I can get it for locally. It is remarkable stuff. Just maintain it.
suds
Offline
« Reply #36 on: August 02, 2012, 08:54 AM » |
Been sanding with my RO 150 FEQ and it's been taking quite a bit of time because or my work schedule and lousy weather. Unfortunately my plug to RO failed and now I have to send it in to get it fixed. Evidently this is a common problem if the plug does not "click" in place. Wondered if the Ras 115 would be a good substitute for this job? I've been using Granat and going through lots of it to get to bare wood so maybe the Ras is a better choice or a good substitute? I've been thinking of getting one since i have a number of wood sanding projects.
MFT's, Kapex, TS 55, Vac, 150 Rotrex, 300 Trion, Domino
Brice Burrell
Offline
Remodeling Contractor
« Reply #37 on: August 02, 2012, 09:05 AM » |
I like the Granat but it might not tough enough for this kind of heavy sanding. Id love to see Granat with a thicker more durable backing material. You could try Cristal if you're finding the Granat to be falling apart on you. You'd need to be careful because Cristal can leave a deep scratch pattern behind that can take a lot of work to remove. The Ras would work but you'd need to get through the learning curve to sanding without doing damage on the softwood.
suds
Offline
« Reply #38 on: August 04, 2012, 08:46 PM » |
Wow,there's no comparison between the RO 150FEQ & the RAS. You're right about having to get some practice to know how to operate the RAS, but once you do you can really remove a lot of material fast. For my purpose it is great.
suds
Offline
« Reply #39 on: August 19, 2012, 11:01 PM » |
OK...finally got the deck done and wiped down and the deck looks great. By mid Nov things will start getting cold and even some snow by then so is there any reason to put another coat on it in Oct? What happens next spring..will it need to be sanded again and reinstalled?
leakyroof
Offline
« Reply #40 on: August 20, 2012, 10:05 PM » |
I like the Granat but it might not tough enough for this kind of heavy sanding. Id love to see Granat with a thicker more durable backing material. You could try Cristal if you're finding the Granat to be falling apart on you. You'd need to be careful because Cristal can leave a deep scratch pattern behind that can take a lot of work to remove. The Ras would work but you'd need to get through the learning curve to sanding without doing damage on the softwood. I hearby second that request... For a heavier backing, on Granat... Not asking for much, just a bit...  Maybe we'll get it with Granat2....
Phred
Offline
« Reply #41 on: September 11, 2012, 09:43 PM » |
Here's an update on my deck: 1) first of all thanks for all of the advice from Scott, Eric, and everyone else in this thread--it gave me the knowledge and confidence to tackle this job. 2) a major overhaul of our irrigation system interfered with my plans for the deck, but I finally got the major portion finished with a first coat of Marine Oil. I plan to do a second coat in 2-4 weeks, before the weather turns. 3) I ended up sanding with my RS2E. Pluses = this sander did a good job of leveling across boards and overall worked well for hours on end with minimum vibration. Minuses = much slower than a RO-150 would have been, but budget issues dictated that I use what I had. My boards weren't cupped too much--but the RS2E certainly let me know which ones needed flattening! The vacuum channels in the base got clogged a few times with debris from between the boards. It would become obvious when sawdust started being left behind on the boards and was easily remedied by removing, cleaning, and reinstalling the sander base (including vacuuming the dust ports). 4) I really appreciated the CT22 and ClearVue Mini CV06--there ended up being a lot of dust that I was much happier to have end up in the collection bin rather than in the filter bags or everywhere else. 4) I used Granat 80 followed by Brilliant 150. I echo Brice's comment that Granat would benefit from stronger backing paper, but overall was very impressed as I didn't have to go through all that many sheets. Thanks again to everyone--especially the professionals who offered advice without anything other than psychic/karmic compensation! Fred
« Last Edit: September 11, 2012, 09:50 PM by Phred »
Peter Halle
Global Moderator
Online
« Reply #42 on: September 11, 2012, 10:20 PM » |
That is an image that Festool should scoop up and use! Gotta say that posts like yours make this place a GREATER place to hang.
