Pages: [1]   Go Down
  Print
Author Topic: A Planter box  (Read 2397 times)
Rob McGilp
Offline Offline
Curmudgeon
WWW
« on: August 21, 2008, 11:28 PM »
Hi all,
So having prepared my timber for production on a planer and using the TS75 to square and cut to width, it was time to make the box.
You only need one tool.. the Domino.
Pic 1 shows the basic frame of one panel.
Pic 2 shows the panel dominoed together
Pic 3 shows the Domino ready to produce the 5mm trenches for the panels and base. You can see the 23mm plastic collar in place on the piston.
Pic 4 shows one assembled frame with the trenches routed with the Domino
Pic 5 shows the assembled unit. Note that this is a dry assembly. I might get round to gluing it if it starts to move.
The timbers I used are Peruvian Walnut and Alpine Ash.
The whole process took about 2-21/2 hours.(including prep time for the timber.)
Regards,
Rob
Bill Wyko
Offline Offline
Location: Tucson AZ 30 miles from water, 3 feet from heck.
« Reply #1 on: August 22, 2008, 12:29 AM »
Wow Rob. When I saw on the main page "planter box" I didn't expect it to be this nice. Great job.
The bitterness of poor quality, lingers long after the cheap price is forgotten.
Reg
Offline Offline
« Reply #2 on: August 22, 2008, 02:51 AM »
Nice one Rob!....What is that "Orange" thing on your Domino?
Regards
Reg
Bill Wyko
Offline Offline
« Reply #3 on: August 22, 2008, 01:53 PM »
I think he's got that for depth control. Another cool way to do that is with a metal shock bushing.
Rob McGilp
Offline Offline
Curmudgeon
WWW
« Reply #4 on: August 22, 2008, 06:16 PM »
Hi Reg,
Bill's right. The orange piece is a length of electrical conduit cut to a specific length to allow for a mortise (or dado) of less than 10mm.
The formula for setting the depth of cut is;
28mm-(depth of cut desired)=length of conduit in mm.
Then all you need do is place the collar onto one of the plunge pistons. Be sure to use conduit that will not be tight on the piston.
Regards,
Rob
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #5 on: August 22, 2008, 07:54 PM »
Beautiful contrast with the two different woods. Great work Rob.
Reg
Offline Offline
« Reply #6 on: August 23, 2008, 05:45 AM »
Thanks Bill and Rob....
Pages: [1]   Go Up
  Print
Jump to:
