Author Topic: Acrylic Cover  (Read 2424 times)
Offline iamnothim
Acrylic Cover
« on: February 20, 2017, 06:43 PM »
My daughter's cats are crawling on and sleeping on my homemade tube amp.  I have a pair of 1959 Amprex Bugle Boy tubes hat I am real partial to.  Fur against glass can produce a very destructive static charge.  Since I can't kill em' I am building a "simple" cover from 1/4" Lexan polycarbonate sheet.
I watched a couple YouTube videos and it looked straight forward.  Jigsaw, tables, bandsaw, and smooth with a flush cut router bit.  Still I had some trepidation about this.  I could see the sheet cracking up.  Since I don't have a very fine bandsaw blade I decided to use my TS55 REQ.  I have a Tenryu 52T thin kerf blade.
I dialed the 55 down to a speed of "1".  Guess what?  Worked like a champ.  Very clean cuts.  This material is a lot more pliable than I expected.   Tomorrow I fire up the OF1500
My reputation pre-deceases me.
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Acrylic Cover
« Reply #1 on: February 20, 2017, 06:52 PM »
Flame polish the edges. Use a propane torches low and gently fan across the edge, practice on scrape.
Offline iamnothim
Re: Acrylic Cover
« Reply #2 on: February 20, 2017, 07:29 PM »
I'm glad you brought that up Tom.
The video said to use MAP Gas.   I'm not at that stage yet I wondered if you can get MAP cylinders that fit a standard torch head
Offline rst
Re: Acrylic Cover
« Reply #3 on: February 20, 2017, 07:30 PM »
tjbnwi's comment about flaming is correct, however, I machine plastics for super market fixtures as part of my business and I would not flame a raw cut edge.  The easiest way to get a very clear finish is to scrape (there are dedicated plastics scrapers, but you can use scraping cards for wood also) first or sand, stepping to 320 grit and then flame.  I pre heat the edges by running along them quickly a few times and then flame with a light source that will allow me to see the sheen, much like you would to check a sprayed finish or buffing.  If you linger too long or get the edge too hot too quickly,it will bubble, just sand again and re-flame.
Offline tjbnwi
Re: Acrylic Cover
« Reply #4 on: February 20, 2017, 07:34 PM »
Yes.
Offline tjbnwi
Re: Acrylic Cover
« Reply #5 on: February 20, 2017, 07:36 PM »
@rst,
Thank you for explaining it more clearly than I did. Sometimes I forget others have never done certain things.
Offline rst
Re: Acrylic Cover
« Reply #6 on: February 20, 2017, 07:37 PM »
Mapp gas is actually no longer avilable in the US.  What is being sold now is actually a propane mixture "Current products labeled "MAPP" are, in fact, MAPP substitutes. These versions are stabilized liquefied petroleum gas (LPG) with high levels of propylene.".
The big shops use hydrogen, I use propane because I am usually not making large quantities and the set up tariff is steep.  I also do not have a commercial scraping/router as the cheap ones start around $10,000 and go up drastically from there.
Re: Acrylic Cover
« Reply #7 on: February 20, 2017, 09:29 PM »
Mapp gas is actually no longer avilable in the US.  What is being sold now is actually a propane mixture.
Ya I've been looking for Mapp for the last 4-5 years for sweat soldering copper. It's extinct unfortunately. The current MAPP is nothing like the real deal.
Offline Arvid
Re: Acrylic Cover
« Reply #8 on: February 20, 2017, 11:37 PM »
I've cut it with a marathon framing blade
Offline Kodi Crescent
Re: Acrylic Cover
« Reply #9 on: February 27, 2017, 09:30 PM »
Thanks for posting this.  I had been considering something like this to cover my Saw Stop's cast iron tables.  It's just too easy for my kids and I to accidentally place something wet on top and...oh look!  A rust bloom!
Offline iamnothim
Re: Acrylic Cover
« Reply #10 on: February 27, 2017, 09:45 PM »
Cool. A great application.
Mine is finito
Offline Untidy Shop
Re: Acrylic Cover
« Reply #11 on: February 27, 2017, 10:58 PM »
@rst
Just wondering?
Great result @iamnothim .
Re: Acrylic Cover
« Reply #12 on: February 27, 2017, 11:31 PM »
This can be very confusing, but there is a significant difference in flame temperatures between the old Mapp and the new Map Pro. The new Map Pro is based more on a propylene mixture and produces approximately 10% more BTU's than propylene gas, but it also produces 15% less BTU output than the old style Mapp. Mapp is still the best for small projects, if you can find it.
