Pages: [1]   Go Down
  Print
Author Topic: Apron Lining  (Read 2088 times)
Rob-GB
Offline Offline
« on: February 25, 2012, 01:06 AM »
Just finished installing this American Black Walnut Apron Lining, the component parts were made before Christmas but fitting was held up because until the metal balustrading was in place the safety rails could not be removed (scaffold tubes bolted to the concrete slab we are covering). Again this is a team effort and not all my own work which also meant I learnt some new tricks, don't you just love how playing with timber affords new experiences  Grin
Okay i hear you...to the pics already!
Before
Those newel posts are curved on all four sides and slightly wider at the top than the bottom (there is a top cap to go on later that resembles a square acorn). Handsomely made by Bazzer, and not an easy project either.
After..
The curved parts are of built up laminations, both internal and external curves and the double astragal ceiling cover mould, we "bacon sliced" sections of timber and kept them in the order we sliced them, even while putting through the sander to get the required thickness! The top moulding that sits just under the marble floor is made from 22 laminations at 2.8mm thick glued up in one go with Urea Formaldehyde glue. To avoid getting white glue lines in the final piece we added rare earth pigments to the glue powder prior to adding water and mixing, as a result of this the glue lines, when the piece is moulded actually take on the appearance of the wood grain lines. Thumbs Up When I explained this to the architect he was quite impressed...as he is with my Kapex too! He is quite a keen woodworker at the weekends apparently and took an instant shine to it. Grin ( Trion and TS55 aided and abetted by the Domino and OF2200 also had a role in this project  Big Grin)
Thanks for looking in.
Rob.
Problem? No such thing! Only a solution waiting to be found:- RJ
"A $2 guppy swims......" Deke
EWTHeckman
Online Online
« Reply #1 on: February 25, 2012, 01:28 AM »
That is some darned pretty wood work!
Ed "What the" Heckman
RL
Offline Offline
« Reply #2 on: February 25, 2012, 05:52 AM »
Fine work!
I like green.
RonWen
Retailer
Offline Offline
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #3 on: February 25, 2012, 06:01 AM »
Beautiful job!
mattfc
Online Online
« Reply #4 on: February 25, 2012, 06:42 AM »
Love how the curved sections came out, creates the wow factor. Did you vacuum press the laminated sections, or clamp round a mold?
Rob-GB
Offline Offline
« Reply #5 on: February 25, 2012, 08:24 AM »
I used all the clamps I could lay my hands on with some and used hardwood battens that spanned the mould and were screwed back to it to assist on others. The top moulding had a male and female mould that required sash cramps to pull them together, 22 laminations is only moderately easier to bend than a solid piece. Wink Grin
We reckon wastage at 80% for the curved parts, after planing, sawing, sanding and moulding from sawn stock, the result though is worth it.
FEStastic
Offline Offline
« Reply #6 on: February 25, 2012, 09:14 AM »
Wow  Rob stunning work
woodguy7
Online Online
« Reply #7 on: February 25, 2012, 09:20 AM »
Love that black walnut.  Stunning as always Rob.  How's the handrail coming along ?
Shirt size medium
windmill man
Offline Offline
« Reply #8 on: February 25, 2012, 09:47 AM »
Rob
That apron is a thing of beauty,its good to see that there are still some people who appreciate such work and great to see it done to such a high standard.
John
Rob-GB
Offline Offline
« Reply #9 on: February 25, 2012, 09:55 AM »
Cheers buddy,  I have to redraw the wreaths and such as my sample highlighted that the straight runs are not at 90° to each other on the rakes, I can not state on an open forum my thoughts on the metal work. I tried to explain that a section through a cylinder at an angle was an ellipse and was met with " Now your just being technical..."  Sad
Rob.
Tim Raleigh
Offline Offline
WWW
« Reply #10 on: February 25, 2012, 10:00 AM »
Rob:
Not that you need me to tell you but that is just beautiful work. Thanks for posting.
Who or what is a "Bazzer"? When I looked it up I got "Brazzer" which are a lot of porn sites Big Grin
I do love the design of the newel post. The curved sides read so well with all the rest (stair, railing etc.)
Tim
Rob-GB
Offline Offline
« Reply #11 on: February 25, 2012, 10:23 AM »
Rob:
Tim
Okay you can use that explanation to your significant other,  Wink but Bazzer is a chap I am working with. He is a top bloke and quality woodworker, great for us to bounce ideas off each other and he is better at wood carving than I, more of a natural in that respect, I think.
Rob.
woodguy7
Online Online
« Reply #12 on: February 25, 2012, 11:05 AM »
Bazzer, lol.
It's great to work with someone of equal or better skill level than yourself.  You tend to learn stuff without realising your are doing so.  It's kinda like when I went to the alps for the first time snowboarding with my mate.  He was so much better than me I was struggling to keep up & felt rather downtrodden.  But when I came home & went to the Cairngorms with some other mates I was miles better than they were were before we were at the same skill set.
Different but the same  Grin
Rob, was the external post on the apron turned on a lathe ?  That's how I would have done it then cut a rebate from the inside.
Keep the pics coming for us lesser mortals  Wink
Shirt size medium
Guy Ashley
Offline Offline
WWW
« Reply #13 on: February 25, 2012, 11:54 AM »
Bazzer, lol.
This is what you call "waiting for the Nagrod body slam". He must be offline!! Grin
DIPLOMACY:
Wood_Junkie
Offline Offline
« Reply #14 on: February 25, 2012, 12:53 PM »
I am stunned at how beautiful that is.  Dang, to have the cabbage to afford that kind of work, on that kind of scale.  Nice place!
Keep up the great work!
Rembo
Offline Offline
« Reply #15 on: February 25, 2012, 02:16 PM »
good job.
Tim Raleigh
Offline Offline
WWW
« Reply #16 on: February 25, 2012, 02:26 PM »
Yes, I was wondering the same...?
It's taken me a while to get out from under those "Brazzer" sites.
Tim
Rob-GB
Offline Offline
« Reply #17 on: February 26, 2012, 02:42 AM »
Alan and Tim, the external curved "posts" are laminated. There is no room at the corner for the back apron to be more than 20mm thick, otherwise they probably would have gotten turned.
At least this way we had no end grain issues.
Rob.
nydesign
Offline Offline
« Reply #18 on: February 26, 2012, 09:30 AM »
That's really gorgeous work! congrats!
jmbfestool
Online Online
« Reply #19 on: February 26, 2012, 09:45 AM »
Looks really Nice Rob!!!!   Love it!!
JMB
Tim Raleigh
Offline Offline
WWW
« Reply #20 on: February 26, 2012, 02:08 PM »
Impressive. Now you are just getting technical... Big Grin
Pages: [1]   Go Up
  Print
Jump to:
