Pages: [1]   Go Down
  Print
Author Topic: A prototype Morris-inspired Outdoor Chair and Stool  (Read 9852 times)
Frank Pellow
Offline Offline
Toronto, Ontario, CANADA
« on: November 18, 2009, 12:06 AM »
I built a prototype of a Morris-inspired outdoor chair this during the last week.  The chair wasn't supposed to be a prototype but I made a major goof on the chair  Embarrassed, so I am keeping it for us.   I decided on a week ago to make two of these All-Weather Morris chairs for our daughter Kristel for Christmas:
The plan and the article about making the chair are by David Theil in the book 'Arts and Crafts Furniture Projects' as published by Popular Woodworking.  Beside the picture, you see my parts cutting plan.
There is a striking similarity between this chair and a "real" Morris chair with photos and plans in the same book:
Some day, I hope to tackle making the real chair.
The plan called for construction out of 3/4 inch thick pine.  But, I decided to use 1 inch thick (5/4 dressed) western red cedar instead.  When I picked up Margaret from physical therapy Monday at noon, she was very surprised to see a load of 16 foot long 5.5 inch wide, 1 inch thick cedar on the roof rack of the car.  I drove very slowly and carefully.  Here enough of the wood for two chairs and two stools is sitting just outside my woodworking shed:
The plans call for 71 parts in a chair and stool after cutting all these parts ((as well as 10 more that I found I needed (but more on that later) most of the edges were rounded over on my router table using a with a 1/4 inch roundover bit then sanded with 80 and finally with 120 grit paper.  Here one part is about to be sanded:
The four legs were made as Ts using screws glue and simple butt joints.  In fact, all the joints in the chair and stool are butt joints.  David Theil only glued and screwed a few of the joints in his chair and used a brad nailer on the rest.  I glued and screwed all the joints.
The top of the back legs were cut at a 5 degree angle, started on the table saw then the cuts were finished by hand:
The top edge of the stretchers had to be cut at an angle and my guided circular saw made this an easy task:
Now I realized that I had goofed!  The bottom side stretchers were supposed to be installed with the top edge 8 inches off the floor.  I installed them with the bottom edge 8 inches off the floor.  I decided to add another set of side stretchers lower down, so that the bottom of the extra stretchers will be in the proper position:
Next, the side slats were installed:
It turned out that 15mm thick plywood was exactly correct to use as spacers.
Now I realized that in correcting the above goof the way I did, I had compounded the problem.  The front and back rails were supposed to rest of the side stretchers 8 inches off the ground and there was no way to make this happen.  What I should have done when I realized that I had installed the stretchers in the wrong place was to remove them in spite of the glue.  At this point, I declared this chair to be a prototype that I would keep rather than give away.  The only solution that I could think of was the install the two sides inside out, that is with the slats on the outside rather than the inside of the chair.  I proceeded to do this.  Cleats were installed to support the front and rear rails:
Things went from bad to worse.  I dropped the assembly and split the board used as the front of one of the front legs:
This I managed to fix with lots of glue:
From distances greater than a metre, I could not see the crack in the repaired leg at all.  It is about time something went right.  Smile
Now to the arms.  Tapers needed to be cut on the back of each arm.  I couldn't bother getting out a rail and plunge saw to do the job for such a short cut; rather I just cut the taper freehand with my table saw.  It was surprisingly easy to do and to cuts were perfect.  I realize that this could be dangerous and do not advocate that anyone else follow my example here.
A piece was cut at an angle at the front of each arm then glued together in order to create a bent arm:
The front part of each arm was strengthened with two Miller dowels:
Beveled cleats were attached to the inside of the front and rear rails:
Next, I stained most of the parts then installed the seat slats:
I built the frame for the chair back and tested it for size and position:
The back is to be attached to the chair with a continuous hinge (stainless steel, of course) .  A bevel had to be cut on the bottom of the back stiles.  I set up my Incra sled to do the job but thought better of it.  That setup seemed awkward and, in the end, I simply sawed the bevels by hand:
The seat back was temporarily installed:
It's a good thing that I tested the back, because I realized that if the back were allowed to descend all the way forward it would put undo pressure on the hinges and, eventually, pull out the screws that were holding the hinge.  This seems to be a design flaw not noticed by David Theil.  A way to prevent this was to place some sort of blocks on the sides of the back that would be stopped by the arms.  Margaret suggested that a make these with a angle matching the angle of the tapers on the back of the arms so that the blocks blend in to the design.  I did this, and we both think that they do blend in well ?and they do a good job.  Here is a picture with the seat back folded forward as far as it has been allowed to go:
The back can assume one of three angles the use of a simple back support with embedded dowels that fits into a pair of holes drilled in the back porting of the arms.  I secured each of the the dowels in the support with glue and with a Miller dowel drilled through the support at a 90 degree angle and into the dowel:
I love those Miller dowels - they come in so handy so often!    Thumbs Up
Here the back support is about to be inserted into a pair of holes in the chair arms:
The chair is a somewhat unusual size for outdoors; that is bigger than a Muskoka chair but smaller than a lounge chair.  This means that I was unable to find a ready-made pad for it.  But I found a nearby place that will make what I want and am awaiting a quote (probably about $100 per pad) .
David Thiele's stool also has a pad, but I am leery of placing pads on furniture that people are likely to be resting dirty shoes upon.  So, my stools will not have pads.  Since there will be no pad, I had to change the stool design a little bit.  The other thing that I didn`t like was that the stool is rather plain.  I wanted it to have at least some hint of being Arts and Crafts inspired.  But I also wanted to stick to the butt-joints only restriction so not introduce something like through tenons.  What to do?  The aspect of Arts and Crafts that appeals most to me is the exposure and featuring of the joints.  There is a somewhat interesting joint formed by the L seen at the tops and bottoms of the legs and I decided to feature those joints in the stool top.
Both Margaret and I think that this creates the desired impression.
Here is photo of the completed chair and stool:
They are both finished with one coat of Sikens Cetol 1 078 Natural stain.  I will store them inside during the winter and add a second coat in the spring.
I will post a picture with the [ad once I get a pad.
« Last Edit: March 24, 2011, 08:41 AM by Frank Pellow » Logged
Cheers,
               Frank (Festool connoisseur)
Holzhacker
Offline Offline
WWW
« Reply #1 on: November 18, 2009, 09:51 AM »
Oh, yeah it looks like you goofed up on that chair. Doesn't look nearly good enough for your daughter. The best thing would probably be if you shipped it to me for my backyard where no one will see it much. I'm sure the next one will be much better. Big Grin
Very nice Frank.
Neill
Offline Offline
« Reply #2 on: November 18, 2009, 10:28 AM »
Frank,
I agree with Holzhacker.  Why would you want to give your daughter a defective chair?  What I don't agree about is sending it to HIM.  I would be happy to take it off your hands.
Seriously though, great job!  I think one of the hallmarks of an experienced woodworker is knowing how to fix those goofs we all make.  You have done that expertly.  I usually fix mine by adding them to the wood pile.
Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
woodwrights_corner
Online Online
« Reply #3 on: November 18, 2009, 11:01 AM »
Frank,
Thanks for sharing.  I'm not much on words, but I really like this twist on the classic design.  Great job!
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #4 on: November 18, 2009, 11:26 AM »
Frank, way to persevere, we all know haw frustrating mistakes can be on our projects. I made a prototype Morris chair a few years ago with the intention of making a real one. It went surprising well and I had so much fun. It was all traditional mortise and tenon joinery. Anyhow, one of the things I did was use 1/4" brass rod to attach and act as a pivot point (hinge) the back. This would allow you to drop the back flat down onto the seat. Of course it would mean making some design changes.
« Last Edit: March 24, 2011, 01:07 PM by Brice Burrell » Logged
Frank Pellow
Offline Offline
« Reply #5 on: November 18, 2009, 11:48 AM »
Brice, thanks for the idea about using a rod rather than a hinge.  I will think about using one on the next chair that I make.
Cheers,
Frank Pellow
Offline Offline
« Reply #6 on: November 27, 2009, 02:39 PM »
I took delivery of the custom made chair cushions today and I am very happy with them.
Cheers,
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #7 on: November 28, 2009, 12:14 PM »
Great work, Frank, as per your usual.  My compliments to your wife, too, for the solution (adding ears to the folding back) to prevent overstressing the hinge.  The cushions really make the overall project "pop" when viewed.
Dave R.
Frank Pellow
Offline Offline
« Reply #8 on: November 28, 2009, 01:30 PM »
Thanks Dave, I too think that the cushions really enhance the chair.  They blend in well but, at the same time, add something to the appearance.
I will pass your compliments to Margaret.  But, the "wings" that she invented, while working very well, don't fit in with Arts and Crafts furniture in the opinion of many people who have seen pictures.  So, I will be using something else (most likely the rod suggested by Brice) for the remaining three chairs that I will be building.
Cheers,
Brice Burrell
Offline Offline
WWW
« Reply #9 on: November 28, 2009, 06:51 PM »
The prototype looks pretty good with the cushions.
Frank Pellow
Offline Offline
« Reply #10 on: November 29, 2009, 08:31 AM »
Thanks Brice  Smile  -but do you say that because the cushions hide a lot  Huh? Scratching Chin
Cheers,
bruegf
Offline Offline
Michigan
« Reply #11 on: November 29, 2009, 11:54 AM »
Frank,
The chair looks great!   A marine grade naugahyde would give you a stool cushion that was weather resistant as well as allow easy clean up even if some did rest dirty shoes on it.
I need to work up some ambition.   I've got hundreds of board feet of teak shorts that I haven't made any use of over the last 15 years.  A few of these chairs would put it at least some of it to very good use.
Fred
Fred
Frank Pellow
Offline Offline
« Reply #12 on: November 29, 2009, 12:03 PM »
Thanks for the tip about a possible cushion for the stools.  But, I prefer the look without a cushion.
Maybe I can drive over someday and relieve you of some ol those teak shorts that you want to have put to use.   Poke
Cheers,
bruegf
Offline Offline
Michigan
« Reply #13 on: November 29, 2009, 12:58 PM »
I'd be happy to part with a bunch of it, but its a long drive.  I'm in located in Michigan near the Indiana border.
Fred
Fred
Frank Pellow
Offline Offline
« Reply #14 on: December 02, 2009, 05:52 AM »
Fred you are correct, that is a very long drive.  I always picture folk in Michigan as being clustered along the brder with Ontario.  Embarrassed
Cheers,
bruegf
Offline Offline
Michigan
« Reply #15 on: December 02, 2009, 09:15 AM »
Maybe we could meet up somewhere in the Detroit area if you ever decide you're interested.   Looks to be about half way between our locations.
Fred
Fred
Frank Pellow
Offline Offline
« Reply #16 on: April 20, 2010, 09:46 PM »
Last week,  I made two more of these chairs and, this time, I placed the side slats on the correct side (that is, the inside). Here is a picture of the two new chairs:
Brice, I figured our just how to use a rod instead of the piano hinges but, in the end, I opted for the hinges again.  I was going to use your suggestion because many people did not like the "wings" that I added the back in order to prevent damage but I decided, in the end, that I like the wings.  I know that they are not what one finds on other Arts and Crafts chairs but a fundamental Arts and Crafts principal is be practical and not to hide any working parts and these are practical working parts.  They make the chairs that I build unique so, I decided to feature them by branding the back of one of the wings on each chair.
Cheers,
Brice Burrell
Offline Offline
WWW
« Reply #17 on: April 20, 2010, 10:16 PM »
It works Frank, they look good. Very nice job. Thumbs Up
Frank Pellow
Offline Offline
« Reply #18 on: March 24, 2011, 08:43 AM »
The photos that I had placed into  this thread were missing.   Sad   I have now restored them all from my computer backup disks.   Smile
Cheers,
Eli
Offline Offline
A Yankee in Kangaroo Court
WWW
« Reply #19 on: March 24, 2011, 10:24 PM »
One of the best things about your project write ups is "warts and all". Which I think always enhance a project.  Big Grin
Anybody can follow instructions and bake a cake. Imagine that first guy that ended up with pancakes?
Do nothing, stay ahead.
Pages: [1]   Go Up
  Print
Jump to:
