As many of you know, spraying paint is a mystery to me. I have had so much difficulty in achieving a smooth finish coat with Advance that today I tried to return the client his down deposit for the kitchen I'm working on and he would not take it. He's in no rush and is confident that I will one day I will find the solution.
I have tried many combinations of thinning and needle sizes that I'm now asking you for your help.
I have the following equipment.
Fuji Q5, 5 stage, T70 gun, PPS system and all needle sizes that Fuji makes.
I was wondering for anyone who has successfully produced a smooth final coat with the same equipment, maybe minus the PPS system, but having the same gun if you could provide me with what worked for you. I will need to know the following;
Are you reducing the amount of air via the turbine or air valve near the gun.
What percentage of thinning
What needle and cap combination
How far are you from the surface
How big is your fan
Are you doing mulitple passes
etc.
BM recommends a stage 3 with a 1.3 needle and cap and 5-10% thinning with water. I tried this and I call BS on that. I was not able to get the paint to atomize properly.
Also, if there is anyone in the Greater Toronto Area who has had successs spraying Advance with a turbine based HVLP and is willing to give me a lesson, that would be greatly appreciated. I will pay you for your time.
Thanks in advance, no pun intended
JC
