Pages: [1] 2  All   Go Down
  Print
Author Topic: Kitchen underway  (Read 7324 times)
Deansocial
Offline Offline
« on: November 16, 2011, 04:10 PM »
only photo i have at the moment but waiting for the quartz tops to go on and a little more work by me and it will be finished in 2-3 week and hope the folding sliding doors will be in by then too...
jmbfestool
Offline Offline
« Reply #1 on: November 16, 2011, 04:12 PM »
Did u use Construction PU for anything?
 Tongue Out Tongue Out Tongue Out Poke Poke
Deansocial
Offline Offline
« Reply #2 on: November 16, 2011, 04:14 PM »
no but gonna get some for your mouth
 Tongue Out
jmbfestool
Offline Offline
« Reply #3 on: November 16, 2011, 04:15 PM »
1.  Are the back of them units just going to have separate panels not one long panel?
2. The far right corner I can see block work im sure.  How come da aint been plasterboarded yet before kitchen fitted
3......... ill have to do some more looking and come back to you  Tongue Out
JMB
Deansocial
Offline Offline
« Reply #4 on: November 16, 2011, 04:24 PM »
yeah seperate panels as requested by customer, yeah i tore the plasterboard off becaus it was sooo out of square because the blockwork was out and the plasterer just followed it!
jmbfestool
Offline Offline
« Reply #5 on: November 16, 2011, 04:28 PM »
Oh dear!  Oh Dear!
JMB
Deansocial
Offline Offline
« Reply #6 on: November 16, 2011, 04:30 PM »
the panels were down to cost aswell as the panel was alot more as it wasnt off the shelf. they are sat 300mm under a brekkie bar anyway
Deansocial
Offline Offline
« Reply #7 on: November 16, 2011, 05:10 PM »
Did look at doing the mistral worktops but they wanted quartz. i do have 1 coming up with mistral(30mm acrylic) do you think it isworth getting a rotex and domino for this project? i currently have a metabo sander sxe 450. wondered if its worth the upgrade
richard.selwyn
Offline Offline
Normandy, France
« Reply #8 on: November 16, 2011, 05:36 PM »
Of course it is  Grin
AlexR
Offline Offline
« Reply #9 on: November 16, 2011, 05:44 PM »
Good start. Is this the job in Toton?
Have you seen mirka ceros sanders? That's going to be my next sander.
Deansocial
Offline Offline
« Reply #10 on: November 16, 2011, 05:52 PM »
yeah it is alex, did i start a thread before? i cant remeber lol. been a bit of hassle as the kitchen company i use drilled all the larder doors wrong doh.
i have looked at the mirka sanders yeah. i forgot about them and think it may be a better pruchase for me than the festool sander
Deansocial
Offline Offline
« Reply #11 on: November 17, 2011, 06:18 PM »
well just had another job swap from quartz to mistral so that will be 2 job so may get the domino for the return end panels. maybe leave the sander for a little while yet as need to make some money
Deansocial
Offline Offline
« Reply #12 on: November 18, 2011, 03:13 AM »
Well had an email last night to confirm the worktops are being template on monday so i will be back there to finish the cab works. Looking forward to seeing this 1 done.
I will dig the photos of the steel work and roof later when i get home
Deansocial
Offline Offline
« Reply #13 on: November 26, 2011, 05:29 PM »
Vindingo
Offline Offline
« Reply #14 on: November 26, 2011, 07:00 PM »
Is that the finished floor?  If not, how are they going to finish under the cabinets?
jmbfestool
Offline Offline
« Reply #15 on: November 26, 2011, 07:38 PM »
why under the cabinets?
Often units are fitted before the flooring goes down  two main reasons!   1. To save on cost of flooring as you need less of it and less work!  2. you can work with out worrying your going to damage the floor.
Then once the flooring is fitted a plinth board(kickboard) is fitted under the units so you cant see underneath
I prefer flooring to be fitted before installing the kitchen.   1. If they get a new kitchen or change the layout of the kitchen at least the flooring runs through and they wont have to redo the entire flooring unless they where lucky and could find a match to finish the flooring off at the time but thats very unlikely.   2. I think it can be quicker laying the floor as their is less cutting round and you have a free open space to work to lay the flooring.
I always want the flooring to be fitting right through where the dishwasher,washing-machine, fridge,freezer go as it makes it easier to get them in and out and sometimes they have little adjustment and need packing up if the flooring does not run through.
JMB
« Last Edit: November 26, 2011, 07:43 PM by jmbfestool » Logged
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #16 on: November 26, 2011, 07:43 PM »
The flooring choice could also come into play.  In Europe - where the floating / laminate floor originated - you would not want to install your cabinets on the floor to allow the floor to "float" without the weight trapping it.  Those floors are also typically pre finished.
jmbfestool
Offline Offline
« Reply #17 on: November 26, 2011, 07:45 PM »
Yes forgot to mention that one!   Yeah the floor needs to move freely and so has to be installed after!      I did a kitchen and a floating floor not to long ago so I should of remembered!
JMB
« Last Edit: November 26, 2011, 07:48 PM by jmbfestool » Logged
Vindingo
Offline Offline
« Reply #18 on: November 26, 2011, 10:25 PM »
I get the cost cutting measure, but this point doesn't make sense to me.  Surely you can put furniture on laminate floor; wouldn't that have the same effect?
I really enjoy the international aspect of this board.  Seeing how people build things in other places is pretty cool!  I also enjoy learning all the different terminology associated with construction.
Deansocial
Offline Offline
« Reply #19 on: November 27, 2011, 04:23 AM »
yeah it is dont to the flooring which was going to be amtico/karnden but after i fitted it and came back a week later to finish a few bits they said we have decided to go for an engineered floor. hmmm this means the units are the wrong height and i would have prefered it in first, never mind. i always prefer the flooring to go in first but it is always a cost thing in my experience.
alfa
Offline Offline
« Reply #20 on: November 27, 2011, 07:59 AM »
How did you finish the cabinet doors?
T15+3 w/ Centrotec Set
Domino DF 500 w/ Domino Systainer
CT 36 E w/ WCR 1000
32mm Hole Guide Rail 1400 mm and 2424 mm
FS/2 Guide Rail 1400 mm and 2424 mm
PS 300
MFT/3
OF 1400 w/ LR 32 Hole Drilling Set
ETS 125 EQ
RO 150 FEQ
DX 93 E Detail Sander
TS 75 EQ
Deansocial
Offline Offline
« Reply #21 on: November 27, 2011, 12:26 PM »
everything is off the shelf, no point making something that someone can make cheaper and better than yourself. They are a laquer finish door and the finish is very good high gloss
Deansocial
Offline Offline
« Reply #22 on: December 07, 2011, 05:45 PM »
tiny bit to finish after floor goes down
jmbfestool
Offline Offline
« Reply #23 on: December 07, 2011, 06:38 PM »
Sound!
Surprised the floor didnt go down before the work top returns went on the sides now you have to try and cut round them but then how do you leave a expansion gap
JMB
Deansocial
Offline Offline
« Reply #24 on: December 07, 2011, 06:42 PM »
Well it was mentioned but i dint fit the tops and im not fitting the floor so it isnt my problem now
Deansocial
Offline Offline
« Reply #25 on: December 08, 2011, 02:15 PM »
folding sliding doors go in tomorrow
Deansocial
Offline Offline
« Reply #26 on: January 28, 2012, 03:57 PM »
jmbfestool
Offline Offline
« Reply #27 on: January 28, 2012, 04:09 PM »
Look nice!
Tim Raleigh
Offline Offline
WWW
« Reply #28 on: January 28, 2012, 04:25 PM »
Looks good.
They need a cabinet for their video boxes.
Tim
Deansocial
Offline Offline
« Reply #29 on: January 28, 2012, 04:31 PM »
Pages: [1] 2  All   Go Up
  Print
Jump to:
