Author Topic: Live edge American Elm conference table  (Read 2983 times)
Offline toykiter
« on: June 27, 2017, 02:26 PM »
Hi guys,
Check out my recent table where I used handheld CNC- Origin from Shaper to create unique joint and inlay of my own design butterflies. Hope you guys like it. Enjoy the flick;
All my friends think I have ADD called Festool. I convinced them it's common work related illness.
Offline Trevin
Re: Live edge American Elm conference table
« Reply #1 on: June 27, 2017, 02:39 PM »
@toykiter
VERY NICE!  I really like how you designed this entire table.  The metal "butterfly's" were awesome.  I like your style.
Trevin   [big grin]
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline Billedis
« Reply #2 on: June 28, 2017, 08:49 AM »
WOW that was an awesome creative job!  Thank you for sharing.  Bill
Offline Untidy Shop
« Reply #3 on: June 28, 2017, 09:41 PM »
Excellent is an understatement, both in the execution and the final result.
__________________________
I find it puzzling that when high quality work such as this is presented on the FOG that  there is little response!  [blink]
« Last Edit: June 28, 2017, 09:45 PM by Untidy Shop »
Offline Svar
« Reply #4 on: June 28, 2017, 09:54 PM »
Its because people are speechless.
Offline SouthRider
« Reply #5 on: June 28, 2017, 10:01 PM »
Stunning, absolutely stunning!
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline jtwood
« Reply #6 on: June 28, 2017, 10:15 PM »
Super creative and very beautiful results.
Steve
Offline blaszcsj
« Reply #7 on: June 28, 2017, 11:43 PM »
Cool way to use the shaper.
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline neilc
« Reply #8 on: June 29, 2017, 12:01 AM »
Saw it on YouTube in the Shaper channel and was amazed with the inventive use of the tool for the irregular joint.  The work is really well done!
What is the base design?
Offline toykiter
« Reply #9 on: June 29, 2017, 02:41 PM »
Thanks guys for great feedback. Base is simple beefy metal trapeze legs and whole table is a knockdown for future move.
Offline ear3
« Reply #10 on: June 29, 2017, 03:20 PM »
Wow.  Incredible work that maximizes the natural beauty of the wood.  You've got me thinking about getting a Shaper Origin now.  How did you flush the metal butterflies to the table surface btw?
Offline toykiter
« Reply #11 on: June 29, 2017, 04:04 PM »
I did grind aluminum flat and tapered sides a little to pound them in with epoxy flush. With Origin we scanned traced on paper butterflies to create file and cut wood super precise (to my surprise) also with depth of the butterfly. I only had to square off bit radiuses. One piece was sticking out a bit and I sanded it with RO 150 and finished all by hand after I buffed out Festool oil. Veils and RO 150 left a circular pattern, so I had to touch them up with green vail by hand. Really cool that you can scan existing part with tool to create file.
Offline Svar
« Reply #12 on: June 29, 2017, 04:24 PM »
What a great feature! I'm sure this little tool will be a success.
Offline egmiii
« Reply #13 on: July 01, 2017, 04:33 PM »
Viewing projects like this are what keep me active on the FOG. Very nice.
