You guys made me smile
![Big Grin [big grin]](http://festoolownersgroup.com/Smileys/default/biggrin.gif)
and thank you!
It is hard to see from the picture but the two end panels have holes already in the front. I made holes from the bottom up to 30mm at the top. I went that high because I want the
flexibility to add a pulling shelve to rest tools etc just a flat surface that I can retract when not needed.
Hans, I was using the LR32 rail for the first time. To those that wonder how hard it is to setup, heck if I did it
YOU can. Frankly easy, the hardest was to figure out the front hole based on the sliders you are going to use and voila. Because I was learning the LR32 I made hole at every index. Are you suggesting to make then in between too? The cabinet is not glued yet so I am open to suggestion
Neil, quite funny that you mention that I went to the shop and check the space and there is enough room to hold 2 systainers. If ever I come to have that many I know what to do
And yes I have the three (length) in 5mm EURO screws already
The next step is to make the dominos to hold the ends from the top and bottom. The dominos will be visible on the top unless I put a sheet of arborite, not decided yet. I went to the lumber yard today and got some BB 9mm for the backs. I cut a rabbit already. I know that I made that build more complicated that it needs to be but I want to learn as many tools as I can during that project.
