Electric Trim
Offline
« on: May 08, 2011, 03:04 PM » |
I need to duplicate this shutter. What kind of materials would you guys use on this?
I'm thinking mahogany for the outside but I'm unsure about the flat panel.
The new one will be painted the same. Any thoughts? Money isn't a problem for this customer.
Also, any pointers on how to construct it are welcome.
Sal LiVecchi
Offline
« Reply #1 on: May 08, 2011, 03:09 PM » |
E T Mahogany for the stiles and rails would work fine, for the flat panel maybe a glue up of the same material would work. My concern would be the paint adhering to the mahogany because of the oils in the wood.
Life is too short and the road is too long to drive anything less than a Festool
Joe Smith
Offline
« Reply #2 on: May 08, 2011, 03:19 PM » |
If you are going to paint it, I would use poplar and exterior paint.
XL shirt size.
Electric Trim
Offline
« Reply #3 on: May 08, 2011, 03:22 PM » |
Thanks for the input.
I could be wrong but I think south American mahogany paints well. Feel free to correct me on that.
Anyone want to weigh on gluing up the flat panels. That was my first thought but I wonder how well they'd hold up being that large. (warp, cup, split?)
I prefer real wood every chance we get but...
Is MDO plywood a bad idea for the panels?
Electric Trim
Offline
« Reply #4 on: May 08, 2011, 03:26 PM » |
Have you done that before Joe?
Joe Smith
Offline
« Reply #5 on: May 08, 2011, 03:40 PM » |
I have. Any wood that is going to be outside will need some maintaining every year. It you are going to use paint, I can see no reason to use more expensive wood, because the paint is going to cover it, unless you have a bunch of that wood laying around. Assuming it is going to be painted, I would use plywood or MDO, but the ply would be cheaper. If it is not going to be painted, I would us Ipe or Sapele. Both stand up to the weather really well. You will run into problems with thin panels from solid wood in a outdoors environment and having to repairs in a year or less.
XL shirt size.
woodguy7
Offline
« Reply #6 on: May 08, 2011, 03:51 PM » |
Any time i use Mahogany i prime it with "Aluminium" primer, then paint with whatever.
The construction, Haunched mortise & tenons with fox wedges on the corners & a through wedged tennon on the rail.
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
Alan m
Online
« Reply #7 on: May 08, 2011, 04:14 PM » |
i would use marine ply for the panels and plant on ipe or teek etc.
another option would be some of that plastic or cement board fasia board stuff and domino it together
jmbfestool
Offline
« Reply #8 on: May 08, 2011, 04:23 PM » |
Wouldnt that make the paneling pretty thick using ply and then sticking ipe/teek on top? You might aswell just have ply or ipe/teek. I get it the ply is try and keep the paneling stable but you might aswell just use ply on its own seen as its been painted cus you basically covering it in ipe/teek to protect the ply from its elements but thats what paint does any way. JMB
Brice Burrell
Offline
Remodeling Contractor
« Reply #9 on: May 08, 2011, 04:36 PM » |
I say forget the mahogany, there are less expensive alternatives that will work just as well (or better). Cypress if you can find it in your area is a very good choice. Other woods that will work well, spanish ceder and white oak. White oak is least expensive but it's also heavy (that's not necessarily a bad thing). I'd stay away from poplar, there's no reason to tempt fate when the client has the budget for better material.
Brice Burrell
Offline
« Reply #10 on: May 08, 2011, 04:48 PM » |
Here's another thought, PVC. I'd really think about using laminated Azek. I'd start with a 1/2" sheet and glue a 3/4" frame (rails ans stiles) to it. Then glue the molding in.
Ken Nagrod
Restricted
Offline
« Reply #11 on: May 08, 2011, 05:10 PM » |
Brice,
If he's matching the color to what's in the picture, it's too dark for Azek or other PVC brands. The heat from the sun will do all sorts of funky things with the PVC when painted too dark. That's why on the tech instructions for the manufacturer's website, they usually state a light reflective value range. I was recently told by one manufacturer, the color you choose (too dark) could void the manufacturer's responsibility after install.
mastercabman
Online
NORFOLK,VA
« Reply #12 on: May 08, 2011, 05:22 PM » |
There is a new kind of threatment on wood that can be use outside.Called TMF "THERMALLY MODIFIED WOOD" I don't know if you can get it where you live but it is rot,bug,moisture,resistant.Any species of wood can be treated that way. Also,not sure about cost.
bjackson3
Offline
« Reply #13 on: May 08, 2011, 05:29 PM » |
Timberlane has a line of shutters that they do this with. After examining how they did it I found that they put some aluminum channel laminated between 2 pieces of azek for the rails and stiles. We hung some black shutters for a customer about 4 years ago and they still look as good as the day we hung them. I have never had a problem painting Azek some very dark colors so long as you do the proper prep and use the right paint. We are actually in the process of designing a large pergola all of PVC and will be laminating site made plywood beams into 2 layers of 5/4 PVC for the rafters. Ill make sure to post pics when we get started should be a fun one.
Ken Nagrod
Restricted
Offline
« Reply #14 on: May 08, 2011, 05:39 PM » |
Timberlane has a line of shutters that they do this with. After examining how they did it I found that they put some aluminum channel laminated between 2 pieces of azek for the rails and stiles. We hung some black shutters for a customer about 4 years ago and they still look as good as the day we hung them. I have never had a problem painting Azek some very dark colors so long as you do the proper prep and use the right paint. We are actually in the process of designing a large pergola all of PVC and will be laminating site made plywood beams into 2 layers of 5/4 PVC for the rafters. Ill make sure to post pics when we get started should be a fun one. It's not about the paint or prep. It's about the paint color and the direct sunlight on it, how it affects the movement or distortion of the PVC. I'm not making this stuff up. Just read any of the install instructions from Azek, Koma, Versatex. Do whatever you want, but keep in mind, it's your labor and replacement material cost should a problem occur. The manufacturers wipe their hands of it with the info and warnings they give.
bjackson3
Offline
« Reply #15 on: May 08, 2011, 05:46 PM » |
Fully realize the manufacturers don't like dark colors, but if a VERY reputable company like Timberlane can make a shutter out of Azek, (I know this because was i was at the factory), and offer a lifetime warranty with it even when painted black I would tend to think it can be done. I just trimmed, last year, the entire exterior of a house, all beaded and jack mitered with a plank molding and they painted it a dark green. Glued and pocket screwed all joints and it still looks like new. Sherwin Williams Duration paint has ALOT of stretch to it. I tend to think that no matter the color if its plastic and its in the sun it is going to get hot, you just have to allow for it to move (Lots and lots) and you will be ok. Don't get me wrong I would much rather work in wood, but sometimes it just makes sense.
Peter Halle
Global Moderator
Online
« Reply #16 on: May 08, 2011, 06:40 PM » |
I have to agree with Ken. If you end up using a PVC product, check the manufacturer's data. Some will flat out void the warranty, some will not if you use a heat blocking paint. I have used a product in the past that would allow dark colors on pvc even in Arizona. Unfortunately threw the info away.
Brice Burrell
Offline
« Reply #17 on: May 08, 2011, 07:16 PM » |
Sorry, my Azek suggestion has gotten this thread a little off course...
Ken Nagrod
Restricted
Offline
« Reply #18 on: May 08, 2011, 07:22 PM » |
I think it was a good and relevent suggestion. You just have to keep in mind about the paint you put on it. I just looked at some documentation I got from Versatex last week. Here are pictures of it.
« Last Edit: May 08, 2011, 07:33 PM by Ken Nagrod »
Peter Halle
Global Moderator
Online
« Reply #19 on: May 08, 2011, 07:28 PM » |
Brice,
I don't think that your suggestion has gotten this off course at all. Material choices are what were asked for, and you supplied a very viable material. Color choices and products and warranties are all part of the equation.
Kevin Stricker
Offline
« Reply #20 on: May 08, 2011, 10:34 PM » |
Cedar for the frame and MDO for the panels. Maybe not as durable as Azec but more dimensionally stable and plenty durable. Oil based primer on all surfaces not glued, with 5mm Sipo dominos, exterior rated pocket screws and TBIII for the frame.
I have re-milled 25 year old cedar decking into perfectly functional and beautiful hand rails. Wood quality is not as good these days but you can still find some great heartwood if you are selective at the lumber yard.
« Last Edit: May 09, 2011, 09:24 AM by Kevin Stricker »
Electric Trim
Offline
« Reply #21 on: May 08, 2011, 11:15 PM » |
Brice,
Definitely agree Brice. I'm not really ruling anything out. Thanks for the input.
Nigel
Offline
« Reply #22 on: May 09, 2011, 01:14 AM » |
I've just made some replacement shutters like this.They are 3m in total width with 3 leafs each side.The originals were all oak.I'm not kidding when I say they weighed a ton.They were also all very warped. Well I needed lightweight so I used pine frames with exterior ply panels.The frames are double haunched morticed and tenonned.I'll know if it's right in year or two!
Tim Raleigh
Online
« Reply #23 on: May 09, 2011, 10:19 AM » |
My first thought for heavily exposed areas is always cedar. Western red cedar seems to be the preference in the US. It holds paint well (if the moisture level is correct) and it a joy to mill. It's a little soft for heavily trafficked fixtures like gates etc. but I still like it. Folks here (North East) use MDO for exterior, but the construction is not true rail and stile but an applied rail and stile design where the rails and styles are over laid, glued and pinned to a large panel creating a rail and panel look. The edges are usually covered with a poplar molding and then primed. Pine (ponderosa) is also used in exterior applications here, I am not a big fan of it but some of the window makers use it. Heart pine (reclaimed) maybe another alternative. It is almost as hard as Red oak. I'm thinking mahogany for the outside but I'm unsure about the flat panel.
I think mahogany is a bit of overkill but I can see why you would use it. Unless this is going to be a clear finish and you can see the wood it just seems unnecessary though. There was a good discussion about choice of wood, construction techniques etc. for an Arched Gate on Wood web. The new one will be painted the same. Any thoughts? Money isn't a problem for this customer.
Money is always an issue  I think the paint (color and adhesion) because of UV will be the number one issue here particularly on a south facing (in direct sunlight) wall. Folks recommend Sikkens Cetol system for this situation although I have never used it so I can't recommend it. It looks like this shutter is failing due more to lack of maintenance than any thing else, so you may want to include a maintenance schedule (option) in your pricing. Also, any pointers on how to construct it are welcome.
Depending on what material you use I (mdo, PVC solid wood) I would favor mortise and tenon of which you have had plenty of great advice already. I think you do need to think about the drainage on the bottom rails if your profile is at right angles to the face. Tim
Brice Burrell
Offline
« Reply #24 on: May 13, 2011, 12:43 PM » |
Okay, I talked with my Azek rep and he confirmed what I remembered from a conversation with another rep several years ago. Azek can be painted dark colors (even black) with Sherwin-Williams VinylSafe paint and they will honor the warranty.
