Pages: 1 2 [All]   Go Down
  Print
Author Topic: New member says hi and quick domino test drive  (Read 12281 times)
johne
Offline Offline
The Netherlands
« on: April 10, 2008, 05:46 PM »
Hi everybody, My name is John i am from the Netherlands and an amateur woodworker.
I came across this site while looking for some info on the domino and decided to register.
Some of the work you people do is amazing and a joy to view.
I have been using Festools for about 9 years and have gathered a nice collection so far.
The latest addition was the domino which i purchassed a few days ago. I had some left over 20mm thick oak floor boards
lying around and decided to make  a small 90x90cm, 50 cm high table. The boards were a little cupped so i had to joint and plane
em down to about 15mm, and glue 4 of them together for the legs. The domino was used for the edge joints and the mitres and i
must say it works like a charm. I did not get all 100% smooth joints but they were very close. A few minutes with the beltsander (a festool too)
and the tabletop was flat as can be. I found the domino to be very precise, fast and easy to use and IMO if errors occur they are probably user
induced. Mostly from applying to much pressure. The best way to operate it, for me anyway, is to plunge it while holding it at the back of the machine
(where the power cord is) pushing it forward and not applying downward force.
Added pic i hope i did this right if there is a better way to add images let me know
Dovetail65
Offline Offline
« Reply #1 on: April 10, 2008, 05:49 PM »
Nice table from a pile of scrap. Welcome.
Nickao
Fred West
Offline Offline
Festool Junkie Banner :o)
« Reply #2 on: April 10, 2008, 06:17 PM »
Johne, welcome aboard and very nice piece. I too love my domino and end up putting together things with it just because I can.  Cheesy Fred
Domino,TS 75, Trion PS 300, RO 150, ETS 150/5, DTS 400, RS 400, LS 130, RS 2, Deltex 93, CT 33 CT 22, CT Midi & 3 MFT 1080s, OF 1400, C 12, RAS 115, MFK 700, MFT/3 Shocked)
johne
Offline Offline
The Netherlands
« Reply #3 on: April 10, 2008, 06:27 PM »
Thanks nickao and fred for the welcome.
BTW the domino i have is different from the one i had seen before, they have changed the metal adjustable aligning
pins. They are now plastic fixed pins (not sure if thats good but they are accurate)
mastercabman
Offline Offline
NORFOLK,VA
« Reply #4 on: April 10, 2008, 07:43 PM »
fixed pins? are they still spring loaded?do they retract like the metal pins?
Fred West
Offline Offline
« Reply #5 on: April 10, 2008, 08:29 PM »
Johne, I agree with mastercabman, I too don't understand about your plastic fixed pins???
mastercabman, I love the picture of your shepherds. I have one little 12 week old purebred shepherd girl, one purebred almost 9 month old rottweiler and one 14 1/2 month shepherd/rottie mix.  Grin Cheesy Wink Fred
SRSemenza
Global Moderator
Offline Offline
« Reply #6 on: April 11, 2008, 12:08 AM »
   I like the way the legs miter into the top on your table. Nice.
     I too am wondering about those plastic pins,  I am sure many members here will want to know everything you can tell us about them.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
johne
Offline Offline
The Netherlands
« Reply #7 on: April 11, 2008, 04:09 AM »
The new pins are of course retractable but they are not sideways adjustable.
They are accurate. The only thing I noticed is that due to the shape of the pins,
they won't lock in a previously cut mortise like the "older" round metal pins could.
not sure if this is an advantage or disadvantage.
New pins:
"Old" pins"
Michael Kellough
Offline Offline
Southern New York
« Reply #8 on: April 11, 2008, 07:49 AM »
They are accurate.
There is a saying, "if you can't make it perfect, make it adjustable"
Matthew Schenker
Offline Offline
WWW
« Reply #9 on: April 11, 2008, 08:20 AM »
Good Morning,
That's an odd change?  I'm trying to think, what are the advantages of the new pin design?
Matt
« Last Edit: April 11, 2008, 08:20 AM by Matthew Schenker » Logged
FOG Designer and Creator
http://www.schenkerstudio.com
Bob Swenson
Offline Offline
« Reply #10 on: April 11, 2008, 09:12 AM »
Johne--Love the way You use scrap wood.
That looks like a pro photo on no seam, is that what you do in your other life?
Those pins are a mystery to me!
Bob
Steve Baumgartner
Offline Offline
WWW
« Reply #11 on: April 11, 2008, 09:23 AM »
Johne, welcome!  Nice work   Cheesy
I can see how the plastic reference pins could be significantly cheaper to manufacture than the spring-loaded steel ones.  They eliminate the need for machining holes into the base and fitting the springs, pins, and bushings into them.  But mere cost reduction has never been a strong priority at Festool, so I too am mystified why they did this.  Plus, unless there is some subtlety that isn't visible in your pictures, there is no way to adjust them, which means as things wear you can't tweak them to take out slop.  Perhaps there was some issue that we don't realize?  Maybe Christian O or someone else from Festool can tell us what they were thinking.
johne
Offline Offline
The Netherlands
« Reply #12 on: April 11, 2008, 09:52 AM »
Hi all.
@ Bob Swenson: You guessed right i am a photographer. If anyone's interested There are some samples of what I do at www.everards.com
    (look at the "Fotografie" tab)
@ slb: They included some spares, so if they wear out they re easy to replace (see pic)
Bob Swenson
Offline Offline
« Reply #13 on: April 11, 2008, 11:06 AM »
Johne, Thought so, what gave you away was the no seam and the fact that you
corrected the legs. Are you using a view with a digital back?
After fifty plus years behind the lens you see these things.
Bob
johne
Offline Offline
The Netherlands
« Reply #14 on: April 11, 2008, 12:38 PM »
Bob, I havent used the viewcamera in years. I have a "Leaf"digital back on a Mamiya RZ 6x7. This table shot
was a quick picture with a Canon 5D and a tilt shift lens. You 're right, I corrected the perspective of the table legs
not in camera though but in Photoshop. You have a good eye.
Fred West
Offline Offline
« Reply #15 on: April 11, 2008, 12:55 PM »
Johne, I am with everyone else on those new pins. They completely mystify me and I hope that very soon we hear from Christian O. or someone else.
The photography, however, may mystify me more as I have no idea what you and Bob are speaking about. What seam and what did you do to the legs and can you help mine?  Cheesy Wink Fred
johne
Offline Offline
The Netherlands
« Reply #16 on: April 11, 2008, 01:14 PM »
Fred, Cheesy
The perspective of the legs: If you take a picture of, in this case, a table you point the camera downwards from your
point of view towards the subject. Because of this lines (legs of the table) start converging. On a view camera you can tilt the back
panel (where the film plane is) to correct for this convergence. By doing so the legs look parralel again. With digital it is easier you can
use photoshop or other image editing software to correct this.
Fred West
Offline Offline
« Reply #17 on: April 11, 2008, 01:30 PM »
Johne, thank you very much and I am sure with practice this is something easily picked up but boy even with the explanation it took a minute or so to really SEE the difference. I very much appreciate the lesson. Fred
greg mann
Offline Offline
« Reply #18 on: April 11, 2008, 01:55 PM »
induced.
Words to live by.
Very nice work, Johne, on both sides of the lens.
Bob, I had forgotten Per had written about your previous careers. You are truly a Renaissance man, unlike that no good kid of yours.  Grin
Greg Mann
Oakland, Michigan
Bob Swenson
Offline Offline
« Reply #19 on: April 11, 2008, 02:49 PM »
Greg----Here, here
Johne, you can teach an old dog a new trick.
Way back in my other life
Bob
Bob Swenson
Offline Offline
« Reply #20 on: April 11, 2008, 03:09 PM »
Fred, No Seam paper comes in 12 yard rolls, 9 feet wide in a rainbow
of colors, Only a pro would buy it. Once I took a 9 x 9 piece and
made a Christmas Card with it. As I folded it I wrote the message
backwards. Had to use a rubber mallet to make the last folds. tied
a red ribbon on it and sent it to an Art Director. Wanted to be there
when he opened the card in his little cubical.
It's the thought that counts  Roll Eyes
bob
johne
Offline Offline
The Netherlands
« Reply #21 on: April 11, 2008, 03:50 PM »
Bob, nice shot thx for sharing, always great to see the work of other photographers.
you apparently are a man with multiple talents.
SRSemenza
Global Moderator
Offline Offline
« Reply #22 on: April 11, 2008, 04:03 PM »
       Do you have the cross stop, and are the pins different on that also?  Do the new pins on the Domino change the use of the cross stop?
Seth R. Semenza
Fred West
Offline Offline
« Reply #23 on: April 11, 2008, 04:03 PM »
Bob, beautiful picture and thank you for the lesson on the no seam paper. I love learning new things like that. I have a decent digital camera and I love using it just don't know what I am doing.  Wink Cheesy Grin But, then, that has never stopped me before.  Shocked Fred PS Would also have loved to see that Art Director open that card.  Wink
mastercabman
Offline Offline
NORFOLK,VA
« Reply #24 on: April 11, 2008, 04:26 PM »
thanks! i have a 15 months female and a 21 months male,both are from the same parents.
as for those new plastic "pins".looking at the pic.i don't think they will register into the mortise.not like it's a big deal,i don't cut mortise that close anyway.
Michael Kellough
Offline Offline
Southern New York
« Reply #25 on: April 11, 2008, 04:43 PM »
bob
Fred, it is also known as "seamless backdrop paper". This designation is a little more self explanatory. The no seam/seamless term refers to the elimination of the floor/wall seam that would normally detract from the prop or subject. When the roll of paper is hung horizontally from a pair of stands and draped across the floor towards the camera the paper forms a large radius sweep or cove that is seamless and creates the illusion that the prop is situated in a vast monochromatic space as in the original post.
The difference between Bob's description and mine is an example of the difference between the shorthand of a seasoned pro and the pedantry of an amateur.  Smiley
Dovetail65
Offline Offline
« Reply #26 on: April 11, 2008, 04:49 PM »
bob
I totally understand what you just said Michael as I am below an amateur in photography.
Michael Kellough
Offline Offline
Southern New York
« Reply #27 on: April 11, 2008, 04:56 PM »
The original round pins aren't intended to register in the mortise because that would result in a ridiculously close spacing as you point out. Might as well plough a groove and use a spline.
I can think of a couple of reasons to switch to the new pins. First, it looks the new system costs a lot less. Second, since the original pins are small and round only a very small area bears against the edge of the wood so it can easily be dented. The large flat faces of the nylon pins won't dent the wood.
mastercabman
Offline Offline
NORFOLK,VA
« Reply #28 on: April 11, 2008, 05:07 PM »
good point!
johne
Offline Offline
The Netherlands
« Reply #29 on: April 11, 2008, 05:09 PM »
Semenza, I have the cross stop and it's the same as the "old" one.
Mastercabman, you're right the new pins dont register in the mortise. The reason maybe that if you use the cross stop
very close to the domino you cant accidentally hook the pin in the mortise by mistake? Just guessing here.
I like the fact that there's no need to adjust anything.
Fred, in case you ever want to photograph anything you build for example. Try to avoid on camera flash. Try making use of diffused light.  Use some artificial light if needed and diffuse this by bouncing it off a white wall or ceiling. Chose a neutral or not to distracting background. For smaller objects you can use a large piece of paper to get the seamless effect. use some reflectors like styrofoam to brighten darker areas. To avoid perspective distortions in your subject move away from it and use the tele end of your zoom instead of the wide angle.  Enough about photography LOL. (If anyone wants to know something feel free to ask of course) This is turning into the Digital camera owners group  Grin
Dovetail65
Offline Offline
« Reply #30 on: April 11, 2008, 05:20 PM »
Michael nice explanation on the pins.
I would love to take great pictures.
I just want to point out that if you are not posting pictures on your web site because you feel no one will buy the stuff because of the pictures bad quality. DON"T think that, post what you have. My pictures suck and I have never had anyone say anything negative about the pictures and only positive about the work. Save one photographer who purchased anyway.
So take pics of your projects . I made this mistake and now I have no pictures of over ten items I made, because the pictures were not that great and I was "embarrassed" by them. As time goes on you can learn to take better pics. I have some pics that are not great by a photographers standard, but since I might only make the item once every 5 years I have to use the pics, that or nothing.
I think "how to photograph your work" should have its complete dedicated section, more than just a thread under general. This way as a festool user I can learn how to take pictures form people who know where I am coming from. I don't much care about taking pics of people, but my woodwork. I think this could be nice on this forum.
Is it worth me putting up a pole to see who would like a dedicated section on "how to take pictures of your work"?
I think under OFF-Topic this would be a really helpful section to those off us in this forum.
What do you think Matthew?
Nickao
« Last Edit: April 11, 2008, 06:00 PM by nickao » Logged
johne
Offline Offline
The Netherlands
« Reply #31 on: April 11, 2008, 05:55 PM »
Nickao, If there is an interest in an "how to take pictures of your work"? thread i'd be glad to help
You're absolutely right when you say always take pictures of your work. Craftmanship shows even in a bad picture.
But even more so in a better picture. If i can give some tips or if anyone has any questions just ask.
Michael Kellough
Offline Offline
Southern New York
« Reply #32 on: April 11, 2008, 06:19 PM »
Nickao
Where are these pictures? What are these things you sell? Inquiring minds want to know.
Fred West
Offline Offline
« Reply #33 on: April 11, 2008, 07:04 PM »
Michael, Johne & Nick, thank you all again. Without any double entendre intended I believe that I am beneath Nick as a photographer.  Wink Cheesy I love it but stink.  Grin Fred
PS I thought the pins were SUPPOSED to register in the mortise as part of the spacing and really that is not all that close if you do so.
PPSS mastercabman, those shepherds are beautiful. 15 & 21 months, how are they getting along?
Ned
Offline Offline
« Reply #34 on: April 11, 2008, 08:09 PM »
...No Seam paper comes in 12 yard rolls, 9 feet wide in a rainbow
Maybe you're right about the 9-foot (~2.75m) stuff, but some of us non-pros do buy the 53 inch (~135cm) paper.  It's pretty easily available.
26-inch (~66cm) paper is much rarer, but B&H stocks it in New York.  Same stuff, only smaller.
Ned
sometime photographer of small things
mastercabman
Offline Offline
NORFOLK,VA
« Reply #35 on: April 11, 2008, 08:11 PM »
hard to keep them apart!!!   the female does have a small dog-to-dog aggression problem,but i'm working on that.
as for the male,he's a big cream puff!!!!!! a full 105 lbs of it!!!!!!
mastercabman
Offline Offline
NORFOLK,VA
« Reply #36 on: April 11, 2008, 08:13 PM »
isn't it funny how this tread got started,and now we are talking about photography and german shepherd!!!!
Fred West
Offline Offline
« Reply #37 on: April 11, 2008, 08:19 PM »
Mastercabman, I know what you mean about the thread but it is also one of the things that I love about this forum. My nine month old 92 lb rottie is a total cream puff but my 14 1/2 month old 89 lb half shepherd, half rottie is pretty aggresive and my little girl the 12 week old, 21 lb shepherd just thinks she can take on any and everything.  Shocked Fred
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #38 on: April 15, 2008, 10:27 PM »
Good Morning,
Matt
Here's my guesstimate as to the new "pin" shape.  They no longer register against the true cylindrical end wall of the previously cut mortise, which means they should be less prone to falsely register due to "chaff" (debris) that remained in the previously cut mortise used to reference the new one to be cut.  Same prinicple as is used in many fence and stop systems to prevent sawdust buildup from preventing accurate registry against the stop.  Side motion of the new "pins" is stopped as the pin contacts the junction between the parallel walls of the previously cut mortise and beginning of the cylindrical portion.  The triangular shape of the new pins when viewed from the side enables them to work equally well on all mortise widths in the Domino program.  This change may solve my one gripe about my experiences with my Domino when mortising into the face grain of mediocre Chinese birch plywood and the often resulting "hanging chaff" which throws off registry of successive mortises when using the stops.
Dave R.
Fred West
Offline Offline
« Reply #39 on: April 15, 2008, 10:36 PM »
Dave, I think you may have hit the nail or in this case the pin on the head.  Cheesy I have had that issue with the old pins and some chaff so if this eliminates that then I am all for it. I guess what I don't get is that Festool must have had an awful lot of complaints about this to go ahead and change it and if so:
  • Why haven't we (FOG) heard about those complaints
    When did this change come into being
    What is being done about older machines like ours to bring them up to snuff?
    Fred
Dave Rudy
Offline Offline
Coloroda Front Range, in the lee of Pikes Peak
« Reply #40 on: April 15, 2008, 11:09 PM »
Dave R.
Dave, IIRC, hanging chaff can throw off far more than mortises -- even Presidential elections!  (Sorry, couldn't help it.  LOL)
Fred
Fred, If there were a lot of complaints, believe me we would have heard them here. (We did hear a little of the one Dave Ronyak referred to).  And why do you think the "older" Dominos are not "up to snuff", a characterization with which I would not agree.
I guess the question is philosophical, in a way -- if Festool adds an engineering improvement between models, is everyone who bought his tool before the modification "entitled" to the modfication?  Auto manufacturers, for example, make small changes frequently between model years.  Unless there is a defect involved, earlier purchasers are never "upgraded".
I suspect that if manufacturers like Festool had to retrofit every tool with all subsequent modifications, they would simply find it economically unreasonable, and might default instead to holding all changes until a totally new model was released.
My $.02
« Last Edit: April 15, 2008, 11:21 PM by Dave Rudy » Logged
Ned
Offline Offline
« Reply #41 on: April 15, 2008, 11:31 PM »
Good points, Dave.
Perhaps a more neutral question would be, "Can older model Dominos be upgraded with the new parts?"
Ned
« Last Edit: April 15, 2008, 11:31 PM by Ned Young » Logged
Fred West
Offline Offline
« Reply #42 on: April 15, 2008, 11:40 PM »
Dave, those were good points but on the other hand if the older dominos are not up to snuff and I am speaking about the pins area alone then why the change? Why done so quietly? And by the way, while auto mfgs do make small changes all of the time the pins on the domino are NOT a small part but an integral one. I am not even saying that Festool needs to pay for the change but I would like to know their reason for changing which as of right now we know nothing and if we wanted to change over what would it cost? Fred
Dovetail65
Offline Offline
« Reply #43 on: April 16, 2008, 12:45 AM »
Many people will not purchase the first marketed design of anything, just because such improvements can and will be made. Software comes to mind as the one thing, a brand new model car another. I am sure some people did not purchase the Domino only because they were waiting for the bugs to be worked out.
Nickao
« Last Edit: April 16, 2008, 01:06 PM by nickao » Logged
Michael Kellough
Offline Offline
Southern New York
« Reply #44 on: April 16, 2008, 08:12 AM »
Good Morning,
Matt
Dave R.
Dave, I don't think the new pins will even fit into a mortise (John?). I haven't read any instructions in a long time but I don't think even the round pins are intended to fit into mortises, they are intended to register off the face/edge of the part so the first mortise is exactly in line on both parts to be fitted. The new shape/material is more suited to registering to a face, especially a finished face than a small steel pin.
The possibility of chafe or other debris makes the practice of registering from holes problematic. The more closely spaced the holes the more likely you are to get out of register after a number of mortises. I'm guessing the engineers decided to limit hole registration to the less frequent spacing allowed by the cross stops to keep accumulated error within the tolerance provided by the wider mortise.
Eiji Fuller
Retailer
Offline Offline
« Reply #45 on: May 03, 2008, 03:31 AM »
Johne,
Nice work man. The table and your photography. Really nice.
Eiji
Pages: 1 2 [All]   Go Up
  Print
Jump to:
