Author Topic: Refinishing a Simpson Full View Door  (Read 583 times)
« on: March 13, 2019, 11:45 PM »
I needed a side entrance door for a garage that will be demoed in the spring. I checked at Menards and any cheap slab door was a $100 and with a jamb was around $120+. Obviously HD and Lowe's are more.  [crying]
I decided to visit the local recycle center and just purchase anything in the $20-$30 range and make it work. I spotted a full view exterior door in pretty good condition. On further examination, it appeared to be constructed of Doug fir with thermo-pane glass.
GOOD ENOUGH      I paid the $30 and took my new door home.
After some sanding and dismantling I came across this stamped into the top edge of the door.
While the name may be difficult to make out, the style number 6002 immediately registered with me as I've already installed 3 Simpson full view exterior doors on the house. All were marked style 6002.  [cool]
So then it kicked in,  I had just purchased a $700 Low E door for $30.
https://www.simpsondoor.com/find-a-door/
Here's a shot of it in the shop.
After some sanding, I noticed that some of the Doug fir was delaminating from the lower portion of the door. Notice that in image 5 the machinists scale can be pushed to the outside edge of the stile. Complete delamination of the bottom of the stile.
The lower portion of Simpson doors are interesting because they use a composite material in the bottom of the door to prevent rot from forming. So the real issue I faced is how to re-adhere the veneer to the composite material because the composite was going no where in a hurry.
« Reply #1 on: March 14, 2019, 12:12 AM »
I've had great results using West Systems Epoxy and having some left-overs I decided to give it a try.
By using a small needled syringe, I was able to inject the epoxy completely underneath the delaminated area. Any squeeze out was then redistributed with a 3M plastic scraper.
Notice how the entire delaminated area has been saturated with epoxy.
A little wax paper, a very flat piece of wood and some Bessey clamps complete the operation. Let's check it out in the morning.  [smile]
Offline travisj
Re: Refinishing a Simpson Full View Door
« Reply #2 on: March 14, 2019, 12:28 AM »
Nice find!
I had lunch with a friend a week ago and we were talking about the local reuse centers (the one in New Brighton specifically).  His father was a developer of high end homes and he followed suit for awhile.  He has since moved more towards engineering.  He said that if I ever need anything, to start at the reuse center.  The contractors in Minnesota (and maybe elsewhere as well) get a full value deduction for any building materials they donate.  I know my father had picked up some steel entry doors there in the past as well as some brand new double hung windows that I put into an icehouse (ice fishing for those in warmer climates).  If I recall the windows were less than $40 each and were still in the factory shrink wrap.
Offline Pnw painter
« Reply #3 on: March 14, 2019, 12:38 AM »
Thanks for sharing. Gives my some good ideas should I ever come across this issue.
I’m curious if the epoxy will bond to the wax paper or if it’ll come off cleanly?
« Reply #4 on: March 14, 2019, 12:43 AM »
I was too but that's why they're called experiments.  [smile]
Check in tomorrow morning.  [big grin]
« Last Edit: March 14, 2019, 12:54 AM by Cheese »
« Reply #5 on: March 14, 2019, 12:53 AM »
Nice find!
Ya I'd never consider myself to to be an "antiquer" because time is money and I'm running out of time.  [smile]  However the few times I went to the reuseit centers, I did score some pretty nice stuff. The time before the Simpson door episode, I purchased 2 new, in the box Velux skylights. Brand new 30" x 48" roof windows for $50 each. Needless to say, they will be installed in the new garage.
« Reply #6 on: March 14, 2019, 10:23 AM »
I noticed that the stile on the RH side wasn't delaminating but it had several splits on the bottom. I took some of the extra epoxy and with the 3M plastic scraper, I spread a thin layer of epoxy over everything.
So here's the stile that was clamped with the wax paper. The wax paper just pulled right off and you can see how the epoxy soaked into the Doug fir. Also note the build-up of epoxy along the bottom of the stile.
Actually I was pleasantly surprised to see the wax paper release from the epoxy.  [big grin] I was prepared to sand the wax paper off if necessary.
Here's the LH stile after some sanding. Also note how nice and tight the Doug fir veneer is on the stile.
[ Specified attachment is not available ]
And here's the RH stile with a little more sanding needed on the bottom.  Next stop, is enlarging the existing hinge mortises with an MFS.
« Last Edit: March 14, 2019, 11:22 AM by Cheese »
Offline RKA
« Reply #7 on: March 14, 2019, 11:05 AM »
It's looking good!  Nice save.
-Raj
Offline leakyroof
« Reply #8 on: March 14, 2019, 12:21 PM »
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
  Now add 6 coats of Epifane Marine Varnish and you're set for a good couple of years.  3 coats of fast drying Rapid Clear and 3 coats of High Gloss..... [wink]
 Or are you painting it to match the Garage?.... [popcorn]
« Reply #9 on: March 14, 2019, 12:57 PM »
You bring up an interesting point. The other Simpson wood doors on the house were SW oil-based primed, 2 coats of SW latex and then 2 coats of GF clear water base poly. However, all are protected with full view aluminum storm doors.
This door will not have the same protection so I'm open to suggestions. I'd also like to paint it black so I wonder how that will muck up the equation?
Offline leakyroof
« Reply #10 on: March 15, 2019, 09:30 AM »
  How much Sun will it get?  Any overhang of gutters or roof adding a tiny amount of sun blockage during the day?  I'm sure someone will chime in with current Paint quality experience for a really dark exterior door.
« Reply #11 on: March 15, 2019, 09:36 AM »
On one hand the black pigment will better limit degradation of the paint medium than any other color. On the other hand it will absorb more insolation and get hotter than any other color. Wood doesn’t expand very much with heat but the composite material in the bottom of the stiles might.
Offline leakyroof
« Reply #12 on: March 15, 2019, 09:40 AM »
  So what we have here is the Roseanne Roseannadanna Paradox.... [wink]
