Pages: [1]   Go Down
  Print
Author Topic: Rocker  (Read 1819 times)
rdesigns
Offline Offline
« on: February 13, 2012, 05:32 PM »
This is one of two replica rockers that I just finished. The original was an old, broken-down rocker about 80-100 years old.
This was my first attempt at steam-bending and seat-scupting.
For this project, my MFT/3 and Kapex were both a great help.
Sal LiVecchi
Offline Offline
« Reply #1 on: February 13, 2012, 05:56 PM »
nice job on rocker. I really like the seat sculpting you did
Sal
Life is too short and the road is too long to drive anything less than a Festool
Vindingo
Offline Offline
« Reply #2 on: February 14, 2012, 10:58 AM »
Building a rocker has been on my list for a while, looks great.
Do you have any picture of your steam set up?  Did you bend the pieces then fit them, or fit them while still flexible?
rdesigns
Offline Offline
« Reply #3 on: February 14, 2012, 11:50 AM »
No picture, but a steamer set-up is simple--just a plywood box not much bigger than the pieces you want to steam.
You make a connection for the steam hose in the bottom on one end and connect a hose from there to whatever vessel you use for the boiler. I set the box on trestles with the steam connection lower than the other end.
 I used a large old aluminum kettle with 3/4 i.d. vinyl hose and heated the kettle with a propane camp stove. You don't really need both an inlet and outlet connection like some how-to books or articles show. With a 3/4" hose, the steam runs up the middle of hose, and the condensate runs back down into the kettle, clinging to the walls of the hose. This is the same way old one-pipe steam radiators worked. The steam fills the box, because steam always rushes to wherever condensation is greatest, so you don't get cool spots with this method.
I'm no expert on steaming and bending wood, but I learned some valuable things.
You bend the wood as quickly as possible after removing it from the steamer. You clamp it to your form and leave it there for a day or two. It WILL spring back somewhat, so your form should be a tighter radius than the final bend. For example, the back pieces on the rocker were clamped to a form with a 19" radius, and ended up with about a 21" radius.
I fit the pieces after bending.
The tight radius needed for the knee braces had to be done in a two-step process:  first, I ripped the oak to 1/8" strips and steamed them and clamped them onto a form in the same order they came off the saw; after they cooled and dried on the form, I glued the strips together, again in the order they came off the saw, and re-clamped them onto the same form. There was virtually no springback.
Don T
Offline Offline
Phoenix, Az
« Reply #4 on: February 14, 2012, 12:23 PM »
That is a nice looking rocker.  I never thought about doing any project that requires steam bending because I thought it was complicated.  I may have to try building something after reading about your process.
RO150, C12, DF 500 Q, CT33, TS75, MFT3, Kapex 120, MFT3/Kapex, MFK 700, RO 90, ETS150/3, CT22, Centrotec Installers Kit
rdesigns
Offline Offline
« Reply #5 on: February 14, 2012, 01:34 PM »
It's not all that difficult. There are quite a few good articles on the subject that you can google, and I recommend reading as much as you can find, because you'll soon find that everybody has a little different idea about how long to steam and how to build the steaming setup, etc. All of which shows that various methods all work, so you need not be intimidated from trying it.
honeydokreg
Offline Offline
WWW
« Reply #6 on: February 19, 2012, 04:03 PM »
Nice. I guess all I could add is. " Rock on". !!!!
pay attention to the details.... they make the difference... festool does
www.kregscustomcarpentry.com
youtube channel:  builtinsbykreg
unityroad
Offline Offline
photos
« Reply #7 on: February 19, 2012, 05:39 PM »
Nice finished rocking chair. I say finished because completing some things for my wifey generally get put aside, ( I gots too many irons in the fire). Did you wedge tennon the legs to the rockers? keep up the nice work. Tim
rdesigns
Offline Offline
« Reply #8 on: February 20, 2012, 07:57 PM »
The leg/rocker connection is simply a 3-1/2" screw driven up from the underside of the rocker, counterbored and plugged with a face-grain oak plug.
The only mortise and tenon joints are those between the seatback  rails and the back legs, also where the back slats fit into the
seatback rails. And the where the front rail joins the front legs.
The seat, being such a wide expanse of solid wood and subject to seasonal movement, is not fixed left and right to legs. Instead, its corners are housed in stopped dados that will allow shrinkage and expansion.
The seat is kept centered by a pocket screw up thru the back side of the front rail and up into the seat.
Pages: [1]   Go Up
  Print
Jump to:
