Author Topic: Router Bit Storage Cabinet Build  (Read 47804 times)
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« on: September 10, 2014, 05:51 AM »
For 10 years I have wanted to rebuild my router bit cabinet, mainly because I never planned for shaper cutters in the original design. Then over the recent years, it just didn't even have enough space for all of the new router bits either. This will be the third generation, with each version a little bit nicer and a little bit larger.
The most difficult part of the build was the necessary planning for the wider variety of bits and pieces I wanted to store in this cabinet. The older version (version 2) didn’t take much planning for the bits, except for the set of forstner bits. (Yuck, that's ugly!!  [scared])
The core design is based on angled shelves for efficient use of space while also being easy to see and access all the bits. Below is the original SolidWorks model I created several years ago when I contemplated writing a magazine article describing the build. Since then, I decided to enlarge it and not use faceframe construction.
The reason why I contemplated writing a magazine article is because in the 20 years since I built the first model of router bit cabinet, I have never seen my method of storing the bits published before. The key to the design is that I can mix 1/4" and 1/2" bits in the same set of holes. This means I can keep all of the bits organized by shape or function, without throwing that organization into a tizzy if I add new bits.
The secret is that I first drill 1/2" holes 5/8" deep, and then drill 1/4" holes in the center of the first hole down an additional 1/2".
I use forstner bits in the drill press to drill these holes for flat bottoms. I also used a fence with the drill press to ensure that the rows of holes were perfectly straight. Because I needed to drill two sets of holes over the top of each other, once I set the fence, I didn’t change it until all of the holes were drilled. To be more efficient, I used a spacer between the fence and the workpiece to drill one row, and then removed the spacer to drill the next row. This way I could add/remove the spacer without changing the position of the main fence. (Sorry, I forgot to get a picture of this setup.)
I based my layout on 4 angled shelves. The upper shelf focused on the forstner bit set with a few other odds and ends filling in the rest. However, at the last minute before assembly, I decided to add holes for the 14 Domino cutters I have. The next shelf was for moulding cutters, panel raisers, and other larger bits. The next shelf was for smaller profile cutters, dado and groving bits, and pattern bits. The final shelf is for the shaper cutters.
I spent some time contemplating what to do with the bottom of the cabinet. I didn’t want to just leave it flat because the original cabinet bottom was always a disorganized mess. Then I found this flat-bottom rounding router bit that I didn’t even know I had. I bought a box of router bits at an estate sale years ago, but never went through them because I didn’t have room for them in the router bit cabinet. Its designed to create rounded wells, such as pencil trays for desk drawers.
With that discovery, the layout for the cabinet bottom came together. I would drill holes for all of the template guides on one side, then router collet storage, and the rest I would fill with various sized pockets. The MFS guide was invaluable for creating the pockets. It was a gift from Christian Oltzscher years ago and he sent me both the large and small sets. I set it up on VacSys to I could securely clamp the MFS to the board without fighting with the table. Then I set up the OF1400 with the large template guide, and plunged the pockets in two passes. The tricky part was aligning the MFS perfectly to the previous pockets so they would all line up.
I don’t normally put a finish on shop cabinets, but the previous cabinet collected a lot of dust. So I decided to brush on some lacquer to the shelves this time. I knew that doing that would require me to ream out all of the holes, but it wasn’t very difficult, and I used a C12 by hand to do it. Actually I'm glad I did, because the main forstner bit was exactly 1/2" and a little too snug for the bits. I found a cheap brad-point bit that was slightly oversized for the reaming.
I laid out the bits several times to make sure I wasn't forgetting anything in the planning. It was also kind of cool looking at the miniature forest of bits.  [big grin]
The next step was the most critical, and one I had been dreading from the beginning (because I knew it would take about 5 hands and I only come equipped with two  [scared] ). I needed to mock up the shelves to determine the best spacing between them to ensure bits could be inserted and removed from all of the holes, but at the same time, I wanted the shelves as close together as possible. This cabinet was already taller than the original, but I wanted to keep it as short as possible so the upper shelf wasn’t too high.
I couldn’t cut the melamine yet, so I took some scrap plywood sides and first clamped them to the horizontal bottom shelf. Then one shelf at a time, I clamped them between the sides just snug enough that I could reposition the shelf with a mallet until it was where I wanted it. As each shelf was added, I checked the bit storage holes above the previous shelf for clearance. When they were all in place and tightly clamped, I marked their positions so I could transfer the layout to the actual melamine side pieces later.
The final assembly wasn't too difficult. I Dominoed the carcase using 6mm tenons. To get a good glue joint, I scraped the melamine clear using the CMS, OF2200, and a 3/4" dado bit just a couple thousandths of an inch deep. (Oh, this was when I decided to add the Domino cutters to the cabinet, because I realized how much of a pain it was to dig the 6mm cutter out of the Domino Systainer.)
I first glued and clamped the carcase together. After the glue was dry I installed each of the shelves similar to how I did it with the mock-up using clamps. But this time I could put them in place while the cabinet was laying face-down to make it easier. I had accurate layout lines drawn on the melamine so I could line up the shelves with the lines before screwing them in place. I added a couple of cleats, hung it on the wall, and filled it with all of the bits. Voila, done!
P.S. I'd prefer to not put doors on this, but if it turns out to be a mess again, I can always add them later. The very first version I made 20 years ago is in my dad's workshop, and it has a glass door.
Offline mattfc
Re: Router Bit Storage Cabinet Build
« Reply #1 on: September 10, 2014, 07:11 AM »
that looks great.. will steal with pride
Offline wow
  • Inactive Member
« Reply #2 on: September 10, 2014, 08:09 AM »
Are you willing to publish plans with dimensions? it would, of course, be easier to modify known dimensions than start from scratch.
Offline Billedis
« Reply #3 on: September 10, 2014, 09:19 AM »
Beautifully thought out and built.
Offline Tim Raleigh
    • Oakville Cabinetry
« Reply #4 on: September 10, 2014, 09:31 AM »
Fantastic...Thanks.
Tim
Offline shed9
« Reply #5 on: September 10, 2014, 11:54 AM »
The idea of one hole with two diameters is genius. I'm using that one, thanks  [smile]
Offline jonny round boy
« Reply #6 on: September 10, 2014, 12:05 PM »
Very nicely done, sir!  [thumbs up]
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Offline VW MICK
« Reply #7 on: September 10, 2014, 03:40 PM »
That's cool .would never have thought of the double size hole idea .
Also really like that bottom tray idea .I'm building drawers ect for the shed at the moment .
Now I'm thinking an MFS  jig could be handy
« Reply #8 on: September 10, 2014, 04:51 PM »
If it would have been written up as a published article I would have created some basic dimensions. But it's really all driven by what you have on-hand. I had a 7-foot plank of 6/4 maple 7" wide (give or take). So I max'd out the shelf dimensions at 28" x 7". When I mocked up the shelves, I found that a vertical separation of 7" between shelves gave me enough clearance to insert/remove my tallest router bits. (This would be 5" separation when measured perpendicular to the 45 degree shelf.) However, this separation is going to be different (I think) if you have wider or narrower shelves than the 7" I used. The total height of the cabinet was dictated by getting all 3 pieces of melamine from a single rip of plywood that was sitting around. The top had to be 28" to match the shelves and I had to throw away 2" due to damage on the sheet. This left 33" of total height, which coincidentally was the exact same length I hoped for during the mock-up.
Even the spacing between holes in the shelves depends on what you have for bits. The main shelf has a spacing of 1.5" and the larger shelf has a spacing of 2". But you could even set this up with variable spacing for small bits at one end of the shelf and larger bits at the other end. This is kind of what I did for the forstner bits, where the gap between each pair of holes got smaller and smaller toward the right.
Oh, for setting up the pockets, that was just trial and error with a little bit of number crunching. I had 11-1/4" front-to-rear to use, and wanted about 1/2" of lip at the front and rear. I picked either 5/16" or 3/8" as a spacing between the pockets, and the rest was therefore allotted to the pocket size. Since the web spacing could be fudged, I then just picked a pocket size of 2-3/8 x 3 for the first 8 pockets. For the width of the middle ones, I just visually ballparked the size so the single large pocket looked about right compared to the other 3.
By the way, I do have some 8mm bits that Festool gave me for photo-props. So there are 16 holes to the right on the main shelf that are not dual-size. They could have been dual size, but I was content with leaving them single.
Offline land_kel
« Reply #9 on: September 10, 2014, 08:01 PM »
How come I don't see any photos on this thread?  I see them everywhere ekes, but only ? for all of these.
D
Lots of stuff
« Reply #10 on: September 10, 2014, 08:10 PM »
My guess is that it is a browser setting, especially if you are reading the forum with a mobile device. The images are hosted on my server. Maybe whatever forum software that is used to make the forum accessible to mobile devices isn't processing remote images.
Offline land_kel
« Reply #11 on: September 10, 2014, 08:27 PM »
Hmmm. Using my iPad and Tapatalk HD. I'll wait fifth the PDF drawings hehe
Lots of stuff
Offline mohrab
  • Shop Companion
« Reply #12 on: September 12, 2014, 03:43 PM »
Very nice work - I particularly liked the base.
Question:  I don't recognize the Festool product the base is shown resting on (5th pic also showing the MFS)?
« Reply #13 on: September 12, 2014, 03:53 PM »
That's the Festool VacSys. It was given to me about 5 years ago, but is not currently available in the U.S.
Offline jacko9
« Reply #14 on: September 12, 2014, 05:44 PM »
Very nice
Offline Charlie Mac
« Reply #15 on: September 12, 2014, 07:58 PM »
Nice design, well executed, and well documented. (although that should be a given) Sweet!
Offline RKA
« Reply #16 on: September 12, 2014, 08:12 PM »
I love it!  Thanks for sharing!  I'm just starting to accumulate bits, so everything I have will fit in a Tupperware box.  Give me another 5 years and I'm going to use these ideas for my cabinet! :)
-Raj
Offline es07Eric
    • www.ericllanesphotography.com
« Reply #17 on: September 12, 2014, 10:23 PM »
Thats really nice, I especially like the bowls in the bottom shelf!
KS 120 | TS 75 EQ | PS 420 EBQ | OS 400 EQ | OF 1400 EQ | MFK 700 EQ | HL 850 E | DF 500 Q | RO 150 FEQ | RO 90 DX FEQ | ETS 150/3 EQ | ETS 125 EQ | PRO 5 LTD | PDC 18/4 | CXS | CT 26 E | CT MIDI | CT SYS | Boom Arm | MFH-1000 | WCR 1000 | MFT/3 | CMS-VL | FS 3000 | FS 1900 | FS 1400 | FS 1400 LR 32 | FS 1080 | LR 32 | SurFix |
Offline neilc
« Reply #18 on: September 12, 2014, 11:12 PM »
Great design, Rick.  Like the dual size hole idea.
neil
