Pages: [1]   Go Down
  Print
Author Topic: Slide Together/Apart Bookcase  (Read 4599 times)
CharlesWilson
Offline Offline
« on: February 2, 2008, 11:58 PM »
Slide Together Bookcase
This woodworking project accomplished a number of objectives:
1.   I finally put to use some oak boards that I brought to Connecticut from Minnesota 30 years ago.
2.   I was able to reuse some boards taken out of a stereo cabinet that I had modified.
3.   I verified Jerry Work's claims concerning the Festool dovetail bits.
4.   I created a bookcase that assembles/disassembles without fasteners or glue-ups (except for edge joining to get desired width).
5.   I 'invented' another use for dominos. (Patents are not being filed, so feel free to copy.)
The bookcase is vertically symmetrical with interchangeable components used to hold it together on top and bottom. The sides and shelves were about 12" wide, and were edge joined using 5mm dominos to align the boards during glue-up.
The sides of the bookcase are, of course, mirror images of each other, but since they are vertically symmetrical, they are also identical.  (I registered the domino spacings from the midpoint of the sides.) Stopped dovetail slots from back to front will receive the top and bottom shelves. The backs of these shelves also have a male dovetail that locks into 7" wide boards that prevent the assembly from racking. The kickers (top and bottom) have male dovetails on their ends, and each fits into a dado in the shelf, locking the assembly in place. The 20mm Festool dovetail bit was used to cut the dovetail slots using the OF-1400 router. The cuts were made without first opening up the slot with a straight bit! The last time I tried that was 35 years ago, and I sure generated a lot of smoke back then. This operation went without a hitch, and the dovetails were flawless.
I used 6mm (narrow setting) domino mortises on the sides for the variable shelf supports. The depth of the mortises was set to 15mm. After locating the midpoint of each side, I used the guide rail and a 1000mm MFS section to locate the domino mortises. In this project, the mortises were referenced from the edge of each board using the standard pin on the domino machine. Mortise spacing was 30mm.
The shelves had 'open' domino mortises placed in them. The depth setting was 25mm. The front of each shelf used the narrowest setting, and the rear  used the middle setting. The mortises were created by using a piece of MDF on top of the shelf, with the domino fence height set so the bit just cleared the bottom of the MDF. A little cleanup with a chisel was required.
Here we have a test fitting of one of the sides.
To add stiffness and prevent the sides from bowing out, I created a stabilizing rail, and hand dovetailed it into both sides. The bookcase seems very rigid, and the addition of a back is not planned at this stage. I will keep the FOG posted if any modifications are required.
Here's the finished and loaded piece of furniture:
I created this animation for the assembly and disassembly of the bookcase using SketchUp:
The changes made to the original bookcase in the SketchUp design included replacing dominos with 3/16" shelf pins (it was just easier to draw that way); modifying the upper and lower stabilizers so that they cover the dovetail slots when viewed from the back of the bookcase; and reducing the width of the stabilizing rail in the center of the back. With these changes (except for the pins, of course) it is more suitable as a free-standing bookcase.
Here is the visible dovetail slot in the original bookcase:
Here are links to the SketchUp files:
AVI file (linked to above):          http://www.box.net/shared/lyvj297kkc
SketchUp used for Animation:   http://www.box.net/shared/7qb3kzwo40
Components with dimensions:  http://www.box.net/shared/tgu4gzisc4
Components (no dimensions):  http://www.box.net/shared/a5mepoewc4
Charles
« Last Edit: May 16, 2008, 12:40 PM by CharlesWilson » Logged
Charles Wilson
semenza
Offline Offline
« Reply #1 on: February 3, 2008, 12:35 AM »
   Very slick, creative use of Dominos for the adjustable shelves!    Is it hard to pulll them out of the mortises when you want to adjust them?  I have read quite a few posts about them being very tight.
Seth R. Semenza
S. R. Semenza Woodworking
Tom Bainbridge
Offline Offline
Limey Carpenter
« Reply #2 on: February 3, 2008, 05:09 AM »
thats simple and effective
making identical and handed pieces is good practice for other work
i love working oak, yes its fickle on the saw and dangerous without a riving knife but thats part of the challange
dominos can be tight, sanding them down altough fiddly and sealing them against mositure movement might do the trick
Bromley, Kent. UK
aka dirtydeeds
CharlesWilson
Offline Offline
« Reply #3 on: February 3, 2008, 12:21 PM »
Yes, yes, they are very tight.
By the way, you know the old saying:
When a guy is holding a hammer, everything starts to look like a nail.
Well, there is a similar one:
When a guy is holding a Domino, ....
  everything starts to need mortises (or something like that).
There were over 200 mortises made for this bookcase.
Charles
« Last Edit: February 3, 2008, 01:40 PM by CharlesWilson » Logged
Charles Wilson
John Stevens
Offline Offline
Ardmore, PA
« Reply #4 on: February 3, 2008, 11:13 PM »
Charles, beautiful work!
...and nice to see the shelf idea put into action  Cheesy  (http://festoolownersgroup.com/index.php?topic=614.msg6053#msg6053)
Regards,
John
"mankind are more disposed to suffer, while evils are sufferable, than to right themselves...  ~Declaration of Independence
brandon.nickel
Offline Offline
Currently Peoria, IL - Eventually back to CO
« Reply #5 on: February 3, 2008, 11:15 PM »
Could you elaborate on how exactly you used the MFS to reference each set of mortises?  Did you use the alignment pin that I've seen used for the circle-cutting jig (thanks to Brice)?  I don't have an MFS (yet) and I'm looking for ways to justify it.
TS55, MFT1080, Domino, OF1400, LR32, RO150E, DTS400, Trion, CT33
CharlesWilson
Offline Offline
« Reply #6 on: February 3, 2008, 11:59 PM »
I marked the center of each side (masking tape with a line at the midpoint). Then, with a 1000mm MFS section fastened perpendicular to the guide rail, I successively moved the board 30mm at a time, clamping the side in place. When clamped, I used the Domino to make the front and back mortises. I estimate that my eyeballing the location of the board produced a positioning error of less than +/- 0.25mm.
If you don't have an MFS section, you could of course just use the guide rail provided with the MFT, with an attached measuring tape. The use of a measuring tape, or a graduated MFS section prevents any error accumulation over the length of a side. If you used some other indexing mechanism such as spacer blocks, it would be possible for some sort of error to accumulate when doing the sides at different times.
Charles
Charles Wilson
CharlesWilson
Offline Offline
« Reply #7 on: February 4, 2008, 12:12 AM »
Regards,
John
Thanks for setting me straight, John. I 'remembered' instead of 'invented' another use for dominos. I'm sure I read that thread before I got my Domino, so the idea was floating around in my subconscious when designing the bookcase.
Charles
Charles Wilson
John Stevens
Offline Offline
Ardmore, PA
« Reply #8 on: February 4, 2008, 08:26 AM »
Sorry, I didn't mean to come across as if I was trying to "set you straight."  (That's why I used the cheesy grin--what could be more cheesy than quoting yourself, but if the shoe fits...  Cheesy )  I have no doubt you thought of it independently, and besides, you actually put the idea to use!  Again, nice work--I especially like that you salvaged the wood from an older piece.  The hand-cut DTs are really nice, too.
By the way, I've read your first post three or four times, so please forgive me if I missed it somehow, but what method did you use to make the male part of the DTs?
Regards,
John
CharlesWilson
Offline Offline
« Reply #9 on: February 4, 2008, 09:08 AM »
The male DTs were made using the OF1400 as a horizontal router, as described in Jerry Work's MFS appendix. It sure works better than trying to stand the boards up on end and push them past a dovetail bit on a conventional router table.
Charles
Charles Wilson
semenza
Offline Offline
« Reply #10 on: February 4, 2008, 11:46 AM »
   For the shelf supports- could the 5 x 19 x 30 tenons be used in the 6 x 20 x 40 mortisies to make them easier to pull out for adjustment?  Maybe the 1mm size difference would be just right?
Seth R. Semenza
CharlesWilson
Offline Offline
« Reply #11 on: February 4, 2008, 01:16 PM »
The bookcase is no longer in my possession so I can't actually try it. I think the 1mm difference might be too big.
Charles
Charles Wilson
CharlesWilson
Offline Offline
« Reply #12 on: February 5, 2008, 01:15 AM »
It seems that I forgot to mention something in my first posting. Actually, the topic should have been entitled 'Slide Together/Apart Bookcase' since I didn't use any glue or fasteners in the project (except for edge gluing boards to get 12" widths).
Charles
Charles Wilson
CharlesWilson
Offline Offline
« Reply #13 on: March 30, 2008, 10:12 PM »
Charles
« Last Edit: May 4, 2008, 02:23 PM by CharlesWilson » Logged
Charles Wilson
Les Spencer
Offline Offline
« Reply #14 on: March 31, 2008, 12:47 AM »
Charles,
Now that is cool. Did you use SU to design the bookcase?
Les (near Indy)
CharlesWilson
Offline Offline
« Reply #15 on: March 31, 2008, 11:10 AM »
Not the first time through.
I used it to redesign the bookcase, and then generate the animation. The changes I made to the SketchUp design included replacing dominos with 3/16" shelf pins (it was just easier to draw that way); modifying the upper and lower stabilizers so that they cover the dovetail slots when viewed from the back of the bookcase; and reducing the width of the stabilizing rail in the center of the back. This way, it can be now be used as a free-standing bookcase.
Of course, access from the back will be limited by the upper and lower stabilizers and the stabilizing rail.
Charles
Charles Wilson
nickao
Offline Offline
« Reply #16 on: May 15, 2008, 11:18 AM »
The more I look at this the more I like the project as a whole. The pics and instructions are great, the sketch up animation is really good too.. This could win the contest on any given month.
I love Eiji's doors, but this project is closer to what most everyone can achieve. This has the basics of a lot of operations covered and I think more suitable to the masses as a project.
What do you think?
Please go through the project threads and bring some projects to my attention if you want me to consider them. Somehow I missed this and would have never noticed it if I did not look around. Please make sure your personal project, even the really old threads, are bumped so we do not forget about them.
Nickao
« Last Edit: May 15, 2008, 11:21 AM by nickao » Logged
The one who says it can't be done should avoid interrupting the person doing it. (or designing / contemplating it)
Matthew Schenker
Offline Offline
« Reply #17 on: May 15, 2008, 11:21 AM »
Nick,
I agree.  And I'll add that it's a challenge judging all these great projects!!
I'm just glad that there are rolling deadlines, so if someone does not win this month he or she is automatically entered the next month!
Matthew
Former FOG Owner/Administrator.  Now enjoying life as a "regular" member!
nickao
Offline Offline
« Reply #18 on: May 15, 2008, 11:22 AM »
Yes, that is why I said can win in any given month.  If guys do not bump their own projects now and again I fear they could be lost(not considered). This forum is really getting big.
Nickao
« Last Edit: May 15, 2008, 11:23 AM by nickao » Logged
Matthew Schenker
Offline Offline
« Reply #19 on: May 15, 2008, 11:36 AM »
Nick,
Maybe that could be part of the contest!  Members can "bump" their favorite projects by jumping in with a nice comment about it.  You can bump several if you want (just to make it tougher for the judges).  Kind of a natural way to nominate, don't you think?
I know the number of projects is growing, but one goal of this contest is to encourage members to browse deeper into the forum and see more of what it offers.
Matthew
CharlesWilson
Offline Offline
« Reply #20 on: May 16, 2008, 12:42 PM »
I updated the original posting to indicate the dovetail slot that was visible from the back of the original bookcase. The SketchUp design eliminates this cosmetic "feature".
Charles Wilson
Dan Lyke
Offline Offline
WWW
« Reply #21 on: October 18, 2008, 10:21 AM »
Just for completeness, and because I was inspired by this to use the Domino for shelf pins for my own project, here's my page on cutting shelf pins with the Domino, with the critical bits repeated here.
I should have taken a picture of the other side of these two guides, but they're the same thickness, the spacing I wanted my shelf pins at, and they've got a strip screwed on the far side to give me a  90 reference angle.
* CuttingShelfPinsWithTheDomino2.jpg (38.32 KB. 600x456 - viewed 78 times.)
So it was just a matter of starting at one end and leap-frogging those guides up my cabinet:
* CuttingShelfPinsWithTheDomino1.jpg (37.36 KB. 456x600 - viewed 54 times.)
Resulting in (in a temporary installation, just so we've got some storage in the kitchen while I finish things like doors and drawers):
* 10Mission_Pantry_FirstInstallation_InPlace4.jpg (42.12 KB. 456x600 - viewed 55 times.)
Accomplished computer geek, novice woodworker, road cyclist, in Sonoma county, northern California.
Pages: [1]   Go Up
  Print
Jump to:
