Pages: [1]   Go Down
  Print
Author Topic: Son's Toylander- Minature Landrover Defender Series 2  (Read 10986 times)
venk67
Offline Offline
« on: February 24, 2011, 09:42 PM »
Project in progress:  Smile
This is my goal for my 3 year old son.
This is where I am to date, 6 months into the project:
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
Have used my MFT/3, TS55, Qwas dogs, OF1400, MFS 400, T-15,  ETS 125 EQ, PS 300, my parallel guides and my Festool beltsander (run off my generator, which I do wheel outside!!)
I had to make a jig for the beltsander until I can get the stopper from UK
I will be using my domino with a home made jig for 1/2 inch material.
I have found my benchcookies from Rockler really useful too.; of course modified and Festooled with lime green duct tape!!
Even though many of my tools were bought to build this project, even I could not justify the cost of picking up the VAC SYS on my last trip to UK, so I modified the vac-clamp a carvers clamp and a foot switch to make my own affordable version.
It works for me and has been very useful so far... [ ERROR: SPECIFIED ATTACHMENT MISSING ] ]
So useful that if they ever bring the vac sys to USA, i would buy it for future projects, just so i do not have to run my air compressor.
Considering what I do for a living this woodworking project so far has been a great stress reliever.  Have had as much fun learning the tools and coming up with jigs/ modifications as I have building the toylander.
Hopefully my son will not have finished highschool by the time his Toylander is completed.
Venk
For more info on toylanders here is the link to their website.
http://www.toylanderownersclub.com/
"Control, control. You must learn control."  Yoda
mattfc
Offline Offline
« Reply #1 on: June 03, 2011, 03:28 AM »
How are you getting on with this? any progress update? What drive train did you go for?
venk67
Offline Offline
« Reply #2 on: December 14, 2011, 12:14 AM »
Thanks for the interest: I have taken an age (6 months)  to get this reply put together and Nigel’s comments made me realize that some might be curious.
Progress was slow initially the first 6 months were hard, so far about 12 months into the project.
After getting plans from Real Life toys and the the majority of the metal parts, motors and wheels, I eventually decided upon cabinet grade plywood.
I have to admit that I am having to relearn some skills from comprehensive school in UK.
Anyway, have been helped a lot be reading the forum, reviewing videos and essentially learning along the way.
I cut out the floor base twice, as the first time I was off by a few mms, to be honest I did not really understand how to mark the wood properly and where on the line to cut.  Anyway second time, I used a combination of the TS 55 and guide rails and my PS300 also on guide rail.
I did not use the paper plans supplied, I thought it was better to mark all items out:
Did have help:
; it has been great father son project, but recently Cars 2 is more popular, so I am working once he goes to sleep and before he wakes.
Have used my domino to help position rear inner wing panels on the floor panel,
Front inner wings attached to base:
Cut slots in floor for handbrake using my MFS and OF 1400
Have my main outer side panels cut (using a template made of 5mm ply) and my OF1400.  Made some mistakes with that initially.  Even the the guy at Woodcraft warned me to only cut off a small amount of material with the template bit, I did not realize what he meant, second time I took the jig saw around the plywood to leave just 6-8 mm to trim off with the router.  Much easier.  I used the CMS with router attached to round over these large panels where instructed on the supplied build plans.
More to follow later
rookie08
Offline Offline
« Reply #3 on: December 14, 2011, 12:44 AM »
Very cool.  He's going to love it I'm sure!
Curious on the vac system, can you tell us where you got the components if we want to duplicate it?
Thanks!
venk67
Offline Offline
« Reply #4 on: December 14, 2011, 07:42 AM »
Sure from memory I think I bought the black clamping part from
http://www.vac-clamp.com/
I bought a carvers vice from  http://www.highlandwoodworking.com/veritascarversvise.aspx
it works well, but can use a fair bit of air, I got tired of my compressor coming on and since I was in the UK, during a festool promotion there, I picked up a vac-sys, which I have to admit works even better.
My plan for very large (heavy) items is to shim up my vac clamp (with suitable thickness plywood) so it suctions at same height as the vac-sys.  The experimentation has been a fun part of the project.
The Vac sys, has definately helped me speed up, and I believe I have most of the wooden components made now.
venk67
Offline Offline
« Reply #5 on: December 14, 2011, 11:57 PM »
I have a question about preparing the plywood before painting.
Does anyone have any suggestions for a primer that will fill the grain.  Not sure if there is one that comes in a spray can, but I really need to make sure the grain does not come thru when we paint.  I think I could have got a better finish if I had used MDF instead of plywood.
Ideally I want to be able to get an autobody type finish?
V
Alex
Offline Offline
« Reply #6 on: December 15, 2011, 06:39 AM »
Venk, you can use liquid putty. It is a very thick primer/thin putty that you can spray on. Normal primers or paints are not the way to do it, they have no filling power.
I think the best way to do it is to use real putty on the entire surface, and sand it, but not down to the wood, just leave a very thin layer of putty on top. It is a technique often used for boats. I grew up in a body shop but we also did boats sometime and the secret of a smooth shiny surface was lots and lots of putty and good sanding. First we used a good quality 2 component filler or polyester filler, and then sprayed it with liquid putty for the finishing touch. The last sanding before the finish spray was done by hand with P800 and P1200 paper, for wet sanding. Make sure you wet sand and not dry because the surface will be smoother.
If you want a finish that looks like a real car you have to get rid of seeing any wood on the surface because wood will never look as smooth as metal. You must definitely get it sprayed, not brushed or rolled. Might take a couple of layers to get a thick enough coat. Finish with a clear coat of laquer to get the shine. That's how it's done on real cars too.
« Last Edit: December 15, 2011, 06:46 AM by Alex » Logged
venk67
Offline Offline
« Reply #7 on: December 15, 2011, 07:30 AM »
Thanks for the advice.
THere are parts of the car that have the endgrain showing, can I seal that with diluted woodglue painted over it and then use the real putty , liquid putty etc?
I think this may be a part, I ask for some expert help!!
Perhaps I can get the prep work done?
rookie08
Offline Offline
« Reply #8 on: December 15, 2011, 10:03 AM »
Thanks for the siters.  I'll start with the clamp and vise, but my sister is going to England next summer so may have a shopping list for her.  Big Grin
On the Festool vac sys, any problem on getting it work in the US?  Do you need a transformer or just a plug adapter?
Thanks!
venk67
Offline Offline
« Reply #9 on: December 15, 2011, 01:16 PM »
I run a generator.
But I think a step up transformer is needed, otherwise,
 a plug adapter will not be sufficient, IMO.
others may chime in!!
Venk
kev carpenter
Offline Offline
festool carpentry
WWW
« Reply #10 on: December 23, 2011, 03:29 PM »
keep the good work up , (I've got a real s3 galvy chassis Big Grin) I've been wanting to make one for my 4yr old sone but I've never had the time Mad
venk67
Offline Offline
« Reply #11 on: February 11, 2012, 05:46 AM »
Just the electrical system to do.
The paint job is professionally done, I have to admit i would have struggled to get a finish like they achieved and it would have taken me more time!!
http://festoolownersgroup.com/CoppermineMain/albums/userpics/thumb_TOYLANDER.jpg
Alex
Offline Offline
« Reply #12 on: February 11, 2012, 06:18 AM »
That looks good, give us some more detail pics please.
venk67
Offline Offline
« Reply #13 on: February 13, 2012, 05:08 PM »
 Smile  Still a few touches needed, but got hte toylander out into the sun and snapped a few shots:
Have to change the location of the push button on the door handle to make it look like the real Landrover, but nearly done//vl
mattfc
Offline Offline
« Reply #14 on: February 13, 2012, 05:40 PM »
You have done a great job, trim detailing is excellent as is the paint finish. Steering wheel is on the wrong side though Grin
Did you get all the bits from real life toys or self source and build from a mobility scooter or similar?
jmbfestool
Offline Offline
« Reply #15 on: February 13, 2012, 06:52 PM »
Looks really good!   I like it!   Its made me wanna make something like that now!   Ill make one for my kid when I get a kid one day!  ( 10years min  Embarassed)
JMB
Kev
Online Online
« Reply #16 on: February 14, 2012, 03:02 AM »
That's just STUPID GOOD !!!  Big Grin
I hope your kid has fully comprehensive toy insurance - the first scratch is gonna hurt !
That's a real double take - live to see a side by side with real thing.
To me, that's the sort of work you could easily lease out for photo and video shoots.
Nigel
Offline Offline
« Reply #17 on: February 14, 2012, 03:16 AM »
Yep,brilliant job Venk. Could just drive off into the hills in that  Smile. Looks like a petrol version......
Alex
Offline Offline
« Reply #18 on: February 14, 2012, 06:11 AM »
That turned out great, I like all the details. The finish looks very good, pretty real if you ask me. Great gift for a kid. Does it have a motor in it?
Kev
Online Online
« Reply #19 on: February 14, 2012, 07:05 AM »
Just heard the US Government's top secret Shrink Ray has been stolen ...
... Could all of the woodworking pictures posted by Venk just be to put us off the scent?
... Is Venk the evil genius behind the theft of the Shrink Ray?
... Could the small child in the preceding pictures really be Venk's older brother, having accidentally stepping I front f the Shrink Ray during the heist?
Hmmmm
 Big Grin Big Grin Big Grin
woodguy7
Offline Offline
« Reply #20 on: February 14, 2012, 09:15 AM »
Kev, you been watching "Despicable Me" again  Big Grin
Shirt size medium
venk67
Offline Offline
« Reply #21 on: February 14, 2012, 08:25 PM »
Two electric motors with 24 Volt power and speed controller is the answer to your question Alex.
Real life toys supply a manual with instruction on how to make this model from two 4X8s of either plywood or moisture resistant MDF.
For those of you still in the UK they will also supply pre-cut panels.
Most of the hardware- lamps, grille, steering wheel, wheels and latches for the tailgate etc are from RLT, though some make their own parts.
One person did a cost comparison and apparently there was a GB 150 difference between buying vs making your own. (cheaper to make your own)
AS for the landrover badges and the AA badge these are made by a guy in Northern Ireland with CNC technology- I ordered those separately.
Good luck to anyone who embarks on this project for their child it is a very worthwhile project.  It felt good to hand over the keys to the new owner.  Not many 4 year olds drive hand made electric cars!!
I can say that for someone who does not do woodworking/ carpentry or electrical work for a living this project was a massive challenge and I learned alot along the way, and with some help (thanks to all who offered their advice)  I am near completion.  ON Saturday we got all the indicators working, the headlights work and the brake light comes on if the car slows significantly.  Just some cosmetic fixes to do then should be able to move onto the next project....
Finding room for the cars in the garage!!!
« Last Edit: February 14, 2012, 08:28 PM by venk67 » Logged
kev carpenter
Offline Offline
festool carpentry
WWW
« Reply #22 on: March 14, 2012, 12:52 PM »
aye  Big Grin
Pages: [1]   Go Up
  Print
Jump to:
