No, that's not a duplicate pic. That's sub #2
If these pics aren't right side up, my apologies. I made the changes in photobucket, but they don't seem to be reflected here.
Below is some quick boxes for the subwoofer amps.
A few things to share Festool-wise. Most of the panels I needed to cut from previously ripped 35" sheets. This presented a problem in that I couldn't use one parallel guide, as my table is too wide.
Best option was squaring up one guide and using a clamp at the other end.
One challenge was to cut a 52 degree bevel. With my first sub, I tilted the guide with a shim, cut a scrap piece and measured the angle. Subtracted that from 52 degrees and set my saw bevel accordingly.
For the second sub, I tried every which way with my table saw to do the same thing, and simply couldn't find a safe and effective way of doing it without making an elaborate jig.
So back to the TS55 and the guide.
Another issue was with the Kapex. I had used my Kapex very little but discovered that it was out of square when cutting short pieces. Checking further, I realized the fence was crooked.
To their credit, a call to Festool resulted in getting a new fence shipped promptly, and with no hassle.
Gotta work this weekend but hope to have the second sub in operation next week .
