Pages: [1] 2  All   Go Down
  Print
Author Topic: Fastcap Kaizen foam  (Read 12366 times)
Dave Reinhold
Festool Dealer Affiliate
Offline Offline
« on: March 10, 2012, 04:29 PM »
I like being organized and I used my systainers to help with that task. I even own multiple sustainers for non festool items but those systainers just had the told and parts thrown in them.  No more, now I've been organizing them with fastcaps Kaizen foam.  It comes in three thicknesses a 20mm, 30mm, and 57mm in a 2'x4' sheet.  Here is some pics of systainers I've done as well as a video.
Fast Cap Kaizen Foam
Thanks Dave
check out www.youtube.com/user/DaveReinholdTV for new tool demos every week
Alan m
Offline Offline
« Reply #1 on: March 10, 2012, 04:59 PM »
iv seen that on u tube a while back . tried to make it out of floor underlay foam. didnt work  right and used 2 cans of glue . i wish you could get it here. the shipping would cost a fortune. .
looks very handy stuff
now
wish list
jmbfestool
Offline Offline
« Reply #2 on: March 10, 2012, 05:21 PM »
Yeah I would like some of that stuff also!!!
I like the drill in the draw idea also!!!!
Often I have my drill stacked under a couple of otherboxes having it in a draw ill always have access to it even right at the bottom of the stack!
Soooooooo ill be ordering some more sortainers  and doing that my self!    Just need to find decent foam!
JMB
Alan m
Offline Offline
« Reply #3 on: March 10, 2012, 05:32 PM »
try ordering it jmb and see how much it would cost
now
wish list
jmbfestool
Offline Offline
« Reply #4 on: March 10, 2012, 05:40 PM »
lol why dont you try?!?!
shame you dont live in UK could order a bulk of the stuff
JMB
harry_
Offline Offline
« Reply #5 on: March 10, 2012, 06:08 PM »
Is there something about this stuff that makes it SO much better than the pink styrofoam I can buy at the borg (probably for much less), that can also be 'sculpted' with PVC glue (or maybe it was the primer)?
Dave Reinhold
Offline Offline
« Reply #6 on: March 10, 2012, 06:24 PM »
I used the pink foam in the bottom of my systainers originally, but never had tool specific cut outs.  The kaizen foam is made of glued up pieces of foam so no chemicals are needed plus I don't think I could make tight fitting spots for tools with a primer brush.  The foam isn't to expensive I gave a sheet to Ken Negrod and he figured there can be 3 pieces cut out to fit a maxi systainer. I lined 2 systainers with less then a 1/2 of sheet of 30mm.
Dave
andvari
Offline Offline
« Reply #7 on: March 10, 2012, 10:28 PM »
The layered structure of this stuff is interesting. I hope availability gets better so I can give it a try.
fatroman
Offline Offline
« Reply #8 on: March 10, 2012, 10:38 PM »
That foam looks interesting.
I put my CXS in a drawer and it's one of the better organization things I've done. Drawers above contain driver and drill bits. Grab one box and you've got just about anything you need.
Domino, RO 125, CT 22, OF 1010, LR 32, TS 55, OF 1400, Parallel Guides, Kapex, Fogtainers, MFT/3, DTS 400, CXS, MFS, RO90, Kapex cart and extensions, Domino XL, RAS, T12, Another MFT/3 ...
James Metcalf
Offline Offline
Memphis Tn.
« Reply #9 on: March 11, 2012, 12:58 AM »
If you need to glue some pieces together I have found if you put a genours amount of hot glue in the center of the pieces where it is not near the edge and hold for a bit until it is dry. It holds better than any other way. You also have some time to line it up before it cools. Hot wire is also another way to make cutouts.
SRSemenza
Global Moderator
Online Online
« Reply #10 on: March 11, 2012, 01:40 AM »
I gotta' get me some of that !  Cool
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Dave Reinhold
Offline Offline
« Reply #11 on: March 16, 2012, 07:15 AM »
There is a way for you guys across the pond to get Kaizen foam.  There is a Gentleman by the Name of Martin Atkins at www.toolovation.co.uk that said he would bring in some kaizen foam if people were interested and if there was a demand he would stock it too.  hopefully you guys can get some and try it out, its really cool stuff.
Dave
jmbfestool
Offline Offline
« Reply #12 on: March 16, 2012, 08:20 AM »
Dave
Well you have giving me two things now!
You know you store your drill in a Sortainer well that never crossed my mind to stick a power tool inside to be honest never thought it would all fit in! Seeing your vid it clearly does soooooo  I went and order another 3 of them sortainers so now have 4 but I think Im going to need more!!  I have T15 drill in one!  My Carvex fits in another and planning on sticking my Milwaukee SDS in another  got grinder drills etc  to sort out so maybe need to get some more!
The other thing is that web you just linked!  Just had a little browse and  noticed these Little Hand   Some UK kitchens I have fitted have brackets you fix to the wall and you simply just hook the units onto and then adjust simples! BUT some have a very poor method of fixing to the wall and these would make much easier to get them into position.  Currently I would I stack a few systainers and then using ply wood and wedges to get it level upped to the correct height.
JMB
ericbuggeln
Guest
« Reply #13 on: May 04, 2012, 08:12 PM »
Wanted to add to Daves thread. Just got some mini sys's in, one of each size. The first one has all my centrotec chucks and everything centrotec. I am gonna bring this to all my installs, so I attached it to the stud finder sys. The stud finder never came with a case and i wanted to protect it. If anyone has any suggestions of what else I should put in there, its lonely. I also use this corded Dewalt drill for all my pocket holes, so i teamed it up with some of the kreg accessories. When more systainers arrive I am gonna put this Kreg drawer and slide jigs in a sys2, not bc it really needs protecting, but so i can attach it to others and roll em in.
The Kaizen foam had almost no learning curve and cut easily. Every once in awhile something would be too tight and I would shave a little off to get a dead fit, but thats how i am in the field too. Bob and I actually cut the 2 1/2 inch foam down to 1 1/4 inch which fit two minisys's and could work for sys1 applications. Definitely would reccomend this product and found it was easy to deal with. I did the complicated centrotec one in less then twenty minutes. One word to FastCap. There are currently 620 billion black ink pens on earth and you make the foam black?Huh? Just saying, I got a silver pen at Staples for $1.99 and a narrow retractable utility blade and a larger one from HD for less then $2.00 each, so I wouldnt waste time with FastCaps offerings, Eric
SRSemenza
Global Moderator
Online Online
« Reply #14 on: May 04, 2012, 11:18 PM »
Nice ste ups. I have the Kaizen, just need to start using it.
Seth R. Semenza
WarnerConstCo.
Offline Offline
WWW
« Reply #15 on: May 04, 2012, 11:58 PM »
I just toss stuff in the boxes.  You can get a lot of stuff in a 2.
ericbuggeln
Guest
« Reply #16 on: May 05, 2012, 07:02 AM »
Warner, that is exactly what the goons over at Contractortalk.com do. Im glad you liked it. Seth, ive seen some of your other systainer mods and i know you are gonna love it, going to ToolNut?
I forgot to mention that i would set the small and large blades to the same depth. I would then use the large for straight cuts and the small for curves, works great. You can do a lot with $20 worth of foam. Eric
WarnerConstCo.
Offline Offline
WWW
« Reply #17 on: May 05, 2012, 08:16 AM »
Just tools and stuff man.
ericbuggeln
Guest
« Reply #18 on: May 05, 2012, 10:48 AM »
Warner, I never baby my tools and they are all banged up, i just hate clutter and i have an assistant, so if everything has a place, either of us can find it at anytime, whether its in a sys or in the boxvan, Eric
Ken Nagrod
Restricted
Offline Offline
« Reply #19 on: May 05, 2012, 11:15 AM »
Some of you know that a few weeks ago I broke my toe and finding comfortable shoes to wear has been a problem.  I found the solution!
Kaizen Foam
I also needed a solution for the inconvenience of bagging a lunch.  I found that if I could carry my lunch with my tools, storage and deployment would be much easier.
I'm working on a version for snacks and a version I call the Olive Garden that holds soup, salad and bread sticks.
« Last Edit: May 05, 2012, 11:18 AM by Ken Nagrod » Logged
WarnerConstCo.
Offline Offline
WWW
« Reply #20 on: May 05, 2012, 11:33 AM »
I think Sasquatch was walking in your foam........
Ken Nagrod
Restricted
Offline Offline
« Reply #21 on: May 05, 2012, 11:46 AM »
Big Grin
I have big feet.
Sas
Dave Reinhold
Offline Offline
« Reply #22 on: May 06, 2012, 10:42 PM »
All this talk about kaizen foam made me want to go and organize some more systainers today.  I think the pen that fastcap offers works great.  It allows me to mark clearly around the item with a crisp line and it only costs a whole $5. People spend more on coffees than that pen cost. Any breakaway knife will work.  I like using a breakaway knife best because you can choose your depth of cut by how much blade is exposed. The fastcap one is $3 not expensive at all so I would add one to my order of kaizen foam if I didn't already have one.
I moved my woodpecker setup block to a mini sys I had. I also used 2p10 and glued a piece of foam to the lid to keep things from moving
Set up my hilti impact in a sys 2
Dave
Sorry for the picture sizes, I'm using tapatalk and haven't quite figured it out yet..
« Last Edit: May 06, 2012, 10:44 PM by Dave Reinhold » Logged
jmbfestool
Offline Offline
« Reply #23 on: May 07, 2012, 05:20 PM »
Dave
Dam you!  I wanted some woodpecker stuff a bit ago!  Them setup blocks where one off many woodpecker items I wanted  Crying Crying. Unfortunallity the uk dealer for woodpeckers is useless!  A complete waist of time!   I had £600 budget to spend on woodpecker stuff  he got £0 of it!  But I also got 0 woodpecker stuff  Sad but I refuse to deal with him again.
Jmb
Intelligent Workshop
Festool Dealer
Offline Offline
Tom Sustins
WWW
« Reply #24 on: May 13, 2012, 11:02 AM »
Sorry to kick up an old thread, but I just realised some of the UK Foggers might be interested in some FastCap Kaizen Foam.  At the moment I have some small sheets and am expecting full stock in a couple of weeks.
Not on our website yet, drop me a line if you would like some.
Also, JMB, I know what you mean about Woodpeckers.  I've been trying to get them to talk to me for months.  They just ignore me.  I'm now looking into getting some similar items made here in the UK
http://www.intelligentworkshop.co.uk
Festool Power Tools - Walko Workbenches - iGaging Measuring Devices - Veritas Hand Tools - Kreg Pocket Hole Jig
FastCap - Bessey Clamps - TiteBond Glues - Oneida Dust Deputy - Trend Diamond Sharpening
Only The Best
jmbfestool
Offline Offline
« Reply #25 on: May 13, 2012, 03:59 PM »
That would be good!  If they can copy some of the woodpeckers tools  do their entire range but a UK version would be mint!   Can't see why a company can't do the same in UK
They won't contact you?   Crap company then.   The UK dealer who sells the woodpecker tools in UK is also crap.  Very annoying old man lazy as heck.  You ask if he has a woodpecker square or something he has to come back to you which can take a full day even the next day  for him to call you and say no but then to tell you what he does have this and that.  Well i didn't ask for them!!!!.  So you ask if he has something else  you get an answer I'll have to come back to you on that and see if I have it so another day waiting!   He asks for yoru email and sends you the list of woodpecker stuff. So you think that's what he has in!  You call him up about 60% of it he does not have. Why the bloody heck does he not put that on the email out of stock or something!
 You call him up before 8 oclock and you get a grumpy man telling you off for calling him up to early he was sleeping!   Well why use your house phone number then for your business! Crazy!  How was I suppose to know he works nights and sleep during the day doesn't say that on his website.
Jmb
« Last Edit: May 13, 2012, 04:01 PM by jmbfestool » Logged
Festool Dealer
Offline Offline
Tom Sustins
WWW
« Reply #26 on: May 13, 2012, 04:20 PM »
Hehe I know exactly what you mean.  In fact I started my business because of him.  He frustrated me so much I set out to do what he's doing, only A LOT better.
I'll see what I can do on the Woodpeckers stuff.  Certainly I couldn't get the whole range manufactured at once.  But little by little would be good.
Can you anodise in green?  Grin
Only The Best
jmbfestool
Offline Offline
« Reply #27 on: May 13, 2012, 05:23 PM »
Funny you say that!  I was thinking at one point doing it my self!  Either import the woodpecker stuff or get the stuff made.
Got a metal fabrication factory just up the road from me I know the owner but I ended up knocking it on the head when I started thinking about it in detail! Got enough on my plate!
Yeah gotta be anodised!  Green would be good Big Grin. I like bright orange also  Tongue Out
Can't wait to see what you get made!  And I hope you will do ALOT better job!   Just telling me if you have something in stock and the price while I'm on the phone. Is 1000% better!
Jmb
« Last Edit: May 13, 2012, 05:24 PM by jmbfestool » Logged
Deansocial
Offline Offline
« Reply #28 on: May 13, 2012, 05:29 PM »
to match your paslode..... Tongue Out
neilc
Offline Offline
« Reply #29 on: May 13, 2012, 10:31 PM »
Have you emailed Richard Hummel at Woodpecker directly??  I've found him to be very responsive to ideas or feedback.  He's a great guy.
If there are issues with UK distributors, I'd think he would want to know.
Given the craft he has demonstrated and the ideas he has developed, I'm sure he's probably patented some of them.  Far easier to email than figure out how to replicate his work locally.
Richard@woodpeck.com is his email address.
neil
Pages: [1] 2  All   Go Up
  Print
Jump to:
