Pages: [1] 2  All   Go Down
  Print
Author Topic: FastCap – Tape Measure Review  (Read 10603 times)
Steve R
Offline Offline
« on: March 20, 2012, 05:39 PM »
In my review Maxi Systainer Review - What Festool doesn’t say that could change your life! Someone asked about dimensions… so I added some images showing the dimensions annotated with a tape measure. In a reply, Brian.ca, wrote “What type of tape measure is that in the pictures Steve?   That looks really slick.”. Check the above post to see the tapes in action… don’t hold your breath they are not that exciting.
Someone quickly replied and gave him the link for the tape measure I used. I thought about replying to my other review and adding information to that thread but realized that Brian.ca’s question really pointed to the fact that things as simple as tape measures can be a valuable product to and more information can be of benefit.
I don’t know how many tape measures I have owned, used, broken or lost over the years. Some I liked many I loathed. Too many times I found the scale down to 1/32 of an inch or even 1/64 of an inch, on the first few inches and Dang! Try and read that when you’re working above your head in dark corner!
Or they are only readable on one side of the tape and you can’t get to that side for the location you need to measure in. Also the color tape and the numbers so close they have no contrast and are hard to read.
FastCap makes many things; their website says the best selling line for them is their tapes measures.  I just have just three types of their many measures and would enjoy having a complete set to see how much I would use the others. What I find refreshing and like about the FastCap line is that they offer many options.
As with any measure accuracy is important. Now if you only have and use one measure you are always accurate. But if you want “Your 36” cut match someone else’s 36” cut. All tapes need to accurate. But even then measurement is a moving target. Take a tape sitting in your vehicle at -30 F. and measure something outdoors at -30 F. then go into a heated shop them tape warms up and you cut warm material… load it in the vehicle and the next day take back to the -30 F. location and don’t be surprised that you cut it short… How much?  In rough/framing…not enough to matter. Want it to fit an existing dove tail… not going to happen.
I took all of the below tapes and my others and in a temp stable site shop all my FastCap tapes measured spot on the same, at the full length of the tape. I checked my other tapes against them and found a couple of off brand tapes to be measuring differently. But not much more than the width of the line markings when tape to tape was measured. The oldest tapes had more hook slop….go figure.
We all work differently, on different things; therefore having measuring options just makes sense.
When working in remodeling the Lefty/Righty is what I use the most. I have two of them and have no issue having someone measure with one and another to mark and cut to the other.
I use the True32 for standalone project work as I just like to work in mm and Festool supports that. Also it is getting harder to find products, materials etc. that are not manufactured in mm…but labeled in inches.
Both the Lefty/Righty and the True32 use conventional locks. If you pull the tape out and let go it will retract back in. Push the lock lever down with your thumb and it locks.
The PMS (how they came to name it that, I have no clue), had an Auto lock. If you pull it out and let go, it stays! A very handy feature! Also the overall shape of the PMS is more comfortable to hold.
If I had to pick Auto-lock or manual lock, I would pick auto-lock for all my tapes. Now will the self brake wear out? Most likely I will lose, someone will take, or it will get kinked/stepped on before it wears out.
Other features on all of FastCap tape measures are:
The White dot on the label is a reusable writing surface that I have come to love and depend on! At first I thought it was a gimmick. I soon found that I have come to depend on it. I have even found the myself and crew marking down the measure and tossing the tape to the cutter and they toss back a clean tape so we don’t have the excuse of not hearing what the cut was.
With a writing surface included you need pencil… (I will review the Fatboy pencil later)… with a point.  All the FastCap tapes have a built in pencil sharpener!  WhooooHoooo! I don’t know how long I have used my Benchmade knife as my pencil sharpener.  Once you see this you wonder why someone else hasn’t done this before!
Another feature that is head slap moment is that is that clip on the tape. Most tapes have a fixed clip. FastCap’s have a thumb actuated clip. What I like about this is it goes over thicker surfaces with ease. All my other tapes I have to work to get them on even a thick tool belt strap. The FastCap is just flat out faster to clip and unclip.
I haven’t tried the flat tapes that FastCap offers. I like the concept and look forward to finding one on a dealer self soon so I can try them.
01 The three tapes I use most
02 View of what the tapes look like
03 You can write on the white area many times
04 Erase with the pencil eraser or with your thumb
05 The build in pencil sharpener gets a lot of use as it is always with me
Cheers,
Steve
MissHailey
Offline Offline
« Reply #1 on: April 05, 2012, 11:10 AM »
I've never seen a tape measure that you can write on like that! That's pretty clever!!
Steve R
Offline Offline
« Reply #2 on: April 05, 2012, 07:28 PM »
I'm glad you found the review helpful. I find it very amazing how many times I learn stuff just chatting with people in the trade/hobby/interest.
Cheers,
Steve
mastercabman
Offline Offline
NORFOLK,VA
« Reply #3 on: April 05, 2012, 07:29 PM »
I have used them before.They ok but i wish the numbers were a little bigger.The pencil sharpener is a sweet thing to have,but doesn't last very long.(at least for me)
But some of those tapes has a very strong recoil    Watch your fingers!!!!  OUTCH!!
Overall they're not bad for the price and not so bulky.
Steve R
Offline Offline
« Reply #4 on: April 05, 2012, 09:05 PM »
I haven't had them all that long...but am going 2.5 years with not issue with sharpeners. How long have your lasted?
Once I went to Reading glasses I wish everything was printed bigger.... in all honesty I find them very read able.... and when I compare them to others... the they are better.
Got to say ... never had a recoil issue...
Cheers,
Steve
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #5 on: April 06, 2012, 12:47 AM »
The new Bostitch tapes are quite legible, but will deliver a nasty bite on return, too.
 Mad
- Willy -
MFT/3 x2, TS 55, Guide Rails x5, Parallel Guide Set, CT 22 w/Boom Arm, CT Mini, RO 90, RO 125, ETS 125, RTS 400, RAS 115.04, C 12 + Centrotec Imperial Bits, CSX Set, TI 15, DF 500 Domino Set, SCG-10, Domino Plate from RonWen, MFK 700 Set, CMS-GE, OF 1010, OF 1400, OF 2200 Set, LR 32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, more "Stuff"-tainers...
mastercabman
Offline Offline
NORFOLK,VA
« Reply #6 on: April 06, 2012, 06:23 AM »
For the sharpener,maybe 2 months.It just start to shattered,and then just keep on breaking the lead.
I can read them,but i use the 16ft stanley,and i like the bigger # on the yellow background
Not all of them does that,but on some the recoil is just too strong
Cheers,
Steve
JPF Woodworking
Offline Offline
« Reply #7 on: April 06, 2012, 06:55 AM »
Thanks for the great review Steve. Like you said, it is always interesting what you can learn talking with others in the know. How long will we have to wait to hear about the "Fatboy"? Just when you think you know something about a simple pencil, someone will come along with an innovative thought. Don't leave us hanging out here too long!
Best regards to all,
John
P
EWTHeckman
Offline Offline
« Reply #8 on: April 06, 2012, 12:59 PM »
I just bought a Stabila recently. It has a much stronger return than my Stanleys, which sometimes need help to get the tape in. There's a nice spring loaded shock absorber to save the hook. The build quality is great. It fits nicely in my hand. The tape is very easy to read and printed on both sides. I'm generally impressed.
There are some drawbacks, though. I bought one with metric, which is half metric, half SAE. I would prefer an all metric tape. (They do make all SAE tapes.) The hook is only on one side of the tape, which means that there's no hook when using it upside down.
On balance, I think it's an excellent tape. Unfortunately, I have yet to find a perfect tape.
Ed "What the" Heckman
Steve R
Offline Offline
« Reply #9 on: April 06, 2012, 07:06 PM »
EWT,
Can you take a few pictures of the over all shape and of the tape itself. Also if you can show the "spring loaded shock absorber to save the hook"  the would be nice to see but it might be an internal thing?
You are right when you said "you haven't found the perfect tape" I think I have favorite ones for certain jobs.... but no single tape work for it all. That is way I showed my three main tapes.
Cheers,
Steve
EWTHeckman
Offline Offline
« Reply #10 on: April 09, 2012, 11:05 AM »
Sure. Here you go:
Here's a front and top view of the tape. I put it next to two of my Stanleys so you get an idea of the relative size.
Here's a view of the shock absorber. It's the yellow area that the hook hits when the tape is retracted. It's spring loaded and can be pushed all the way back to the black rubber part of the case. You can also see that the hook has a fairly robust connection to the tape.
Here's a comparison shot of the markings on all three tapes. The anti-glare coating on the Stabila is very good:
« Last Edit: April 09, 2012, 11:08 AM by EWTHeckman » Logged
Ken Nagrod
Restricted
Offline Offline
« Reply #11 on: April 09, 2012, 03:14 PM »
Sure. Here you go:
Ed,
Thanks for pointing out that movable shock absorber.  I just noticed it on mine.
Steve R
Offline Offline
« Reply #12 on: April 09, 2012, 03:24 PM »
Sure. Here you go:
Thanks for posting the pictures.
I did look at the same place on the Fast cap and the blue and green ones also have a retraction bumper, to easy the shock of contact. It seems to be connected to the locking mechanism.  The yellow ruler with self lock...doesn't.
Cheers,
Steve
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #13 on: April 09, 2012, 06:58 PM »
The new Stabila tapes are quite nice, they feel like "machines". I agree that they should have an all metric version but on the other hand, it could be seen as two tapes in one.
The shock absorber is cool and it is on all of the new versions. I also like the grip strip on the hook & two-sided printing.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Steve R
Offline Offline
« Reply #14 on: April 12, 2012, 10:28 PM »
Tom, just have to ask do you sell the FastCap rulers?  Being a dealer here not just a user could effect your feedback. If you sell  both cool!  If not.... Hmmmm
Cheers,
Steve
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #15 on: April 12, 2012, 11:33 PM »
Steve:
I'm not saying anything against the Fastcap tapes and I think they are quite desirable. I have worked closely with a cabinet shop owner who loved them and I know many other people that are quite fond of them. A lot of these comparisons are personal preference and sometimes those preferences are based on how one works, how one's eyesight is, and what you're used to.
The Stabila's don't have the writable surface or pencil sharpener and I think both of those are great assets on the Fastcap tapes. However, I'd put what the Stabila tapes have up against the Fastcaps any day. I'm not sure how to make a fair comparison and I don't really have the inclination to do the experiment.
I have a no-name 25' tape that a friend of mine gave to me after he bought 2-for-1 from a bin at the BORG. I use it all the time and it works just fine. It seems to be a knock-off of a Stanley. I have tapes that were old when I was young and they still measure but don't really retract. When I break out one of my Stabila tapes I can really tell the difference. It just seems like a Sapphire Martini next to a Tecate.
The people that know me will tell you that I'm not a tool snob. I have Henckel and Wurstoff knives in my kitchen that have been there for 30 years. I have Santoku Ceramics that have been there for several years. When I realized a year or two ago, while looking at the competition at Harbor Freight, that I could buy a 6" ceramic chef's knife for $13, I bought two of them and I love them!
I go out of my way to not steer anyone in any direction that I don't think is the best for them. It's a simple business call... If the customer isn't happy with my opinion, the relationship is likely over. That's bad business.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Steve R
Offline Offline
« Reply #16 on: April 13, 2012, 01:26 AM »
Steve:
Tom,
Thanks for being a stand up guy and dealer! I very much appreciate and respect  your response. I had to ask as I got a personal email outside of the site asking....  I posed the question for the person and you addressed it. Thank you so much Tom!
Please keep up the posts!
Cheers,
Steve
RonWen
Retailer
Online Online
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #17 on: April 13, 2012, 09:25 AM »
I presume that all of the dealers that participate on FOG endorse & recommend all of the products they sell -- what better (worse?) way to generate an overall negativity of themselves than to support products that are of sub-standard quality on an open discussion forum?
I have several of the FastCap tapes that I like very much however I also realize they vary in accuracy -- I have layed different FastCap models side by side stretched out to ~6' and do find slight differences in dimension.  I also have other brands including Starrett that I haven't compared, I decided that tapes are all "roll-up story sticks" and I make sure that I use the same tape (only) all the way through a project.  That way irregardless of the accuracy error it doesn't affect the finished project.
Intelligent Workshop
Festool Dealer
Offline Offline
Tom Sustins
WWW
« Reply #18 on: May 13, 2012, 11:05 AM »
Yes I generally find all tape measures vary in their accuracy from batch to batch.  I always use one tape measure from start to end of a project.  FastCap will refund or exchange any product you find to be faulty or unreasonably out of true, for life.  Whilst a UK dealer for their products, I have been impressed with the FC Tape Measures and I only stock items I have complete confidence in.
http://www.intelligentworkshop.co.uk
Festool Power Tools - Walko Workbenches - iGaging Measuring Devices - Veritas Hand Tools - Kreg Pocket Hole Jig
FastCap - Bessey Clamps - TiteBond Glues - Oneida Dust Deputy - Trend Diamond Sharpening
Only The Best
tmorton
Offline Offline
« Reply #19 on: May 29, 2012, 10:06 AM »
The other great thing about the True 32 and the combo imperial / metric tape is that there are little black dots that mark 32mm. It comes in real handy now that I know what they are for. There are also marks for the standard Cabinet heights etc on the True 32. Hard to beat for the money and I have 2 of each.
-Ty
TS-55, MFT/3, ETS 150-3, OF1400, Parallel Guides, RO-90, Domino DFQ-500, LR-32, PSB-300, Kapex and UG cart with new Wings, MFK 700, CXS
JLB builders LLC
Offline Offline
WWW
« Reply #20 on: June 05, 2012, 07:29 AM »
The Stabila and the Fastcap combo imperial / metric tape look great. Id like to check out the Fastcap with the little black dots that mark 32mm and marks for the standard Cabinet heights. I have been happy with my Husky that I did a review on last year but always searching for the perfect tape.
Question from a Trim carpenter stand point. Why 16 feet tapes? most trim I use is 12 or 16 feet so why not have a tape that goes to 18 feet? Gives a little extra tape for when you need to bend into a corner and still have enough tape to keep from having your hand jammed in the corner blocking your view and struggling to pull the last few inches out of the tapes housing fighting the return spring.
Assorted Playskool tools and some Bob the builder vids,
Kapex,TS75,CT26E,Domino,Kreg jig,Fein MM,Fein 6 inch sander, many Systainers,Porter Cable 6" joiner/13 inch thickness planner and Bosch tools etc.
http://www.facebook.com/pages/JLB-Builders-LLC/118746931490281
Julian Tracy
Online Online
WWW
« Reply #21 on: June 05, 2012, 08:24 AM »
Every specialty Fastcap tape I've bought had a crappy belt clip - spring steel is a poor quality - stretched out, wouldn't grip anymore.
JT
Ken Nagrod
Restricted
Offline Offline
« Reply #22 on: June 07, 2012, 12:29 AM »
Funny about Julian's comment above.  I bought the Stabila 16 foot tape measure at JLC Live this year.  As Tom Bellemare said, it does feel like a quality tool.  After using it all this time, I think it's no better than the FastCap tapes (and you know what I really think of them).  The steel used for both the blade and belt clip is very poor in performance.  The tape easily gets kinks in the blade and the belt clip spreads apart too easily.  I've frequently taken the clip off to squeeze it tighter.  That lasts a second or two.  Can't recommend the Stabila tapes to anyone.  Back to the drawing board for the engineers at Stabila.  I can say that I never had these two issues with my Stanley Fat Max tapes, not that they're perfect in other regards.
Besttool
Offline Offline
« Reply #23 on: June 07, 2012, 01:00 AM »
Talmeter
TALMETER - Hultafors marking measure - Taking measuring further.
http://www.hultafors.com/uk/products/about-our-products/tape-measures-with-precision/talmeter/
CMS; + CMS-TS-75; + CMS-OF; + CMS ST; + CMS-VL;
CTM 26 E; (+ ONEIDA Dust Deputy)
Domino DF 500;
FS 800 + 1400 + 1400 + 3000 + 1080-LR 32;
HL 850 + SE-HL + WA-HL;
LR 32-SET;
MFS 200; MFS 400;
MFT 1080;
OF 1010; + OF 1400;
RO 90; + RO 150;
T 15+3; + Centrotec 09;
TS 75  REBQ-PLUS;
TS 55 REBQ-PLUS;
VS 600;
CARVEX PS 400-SET;
SYSLITE;
21 Systainer's
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #24 on: June 07, 2012, 01:13 AM »
Quote
If you don't mind, Ken, I'd like to make sure this gets passed on to those at Stabila... Their tapes are made to hire, if I'm not mistaken.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Ken Nagrod
Restricted
Offline Offline
« Reply #25 on: June 07, 2012, 01:38 AM »
Quote
Tom,
Don't mind at all.  At least their levels have been superior to everything and on par with Levolution.
Ken Nagrod
Restricted
Offline Offline
« Reply #26 on: June 07, 2012, 01:44 AM »
We've talked about this brand in the past.  I think it was JMB who first posted about them.  I believe their products are NAINA, however they could be imported without restrictions like Festool has.  BTW, got inches?  Poke
builderbob
Offline Offline
WWW
« Reply #27 on: June 07, 2012, 10:07 AM »
That's a pretty sweet tape!  Almost makes me want to evacuate imperial measuring!
B
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Peter James
Festool Dealer
Offline Offline
Festool Dealer Right Outside NYC - 10,000 Sq Feet
WWW
« Reply #28 on: June 07, 2012, 10:13 AM »
+1 That looks real functional. Like a Fastcap tape and Accuscribe in one!
www.toolnut.com
www.festoolproducts.com
www.festooldominoxl.com
www.powertoolsupercenter.com
Full Line Festool stocking dealer located right outside NYC.  Festool Factory Trained Salesman.  10,000 sq. ft retail location.
peter@toolnut.com
goforbroke442nd
Offline Offline
« Reply #29 on: June 14, 2012, 12:40 PM »
Ok, here's a really newbie question regarding tape measures.
I recently picked up a few of the Fastcap tapes at my local woodcraft.  I wanted some metric and metric/imperial ones and ended up with two of the flat, non metalic types (which both happen to be in white cases).  These are the "limp" type rulers which lie flat are are similar to tailor tape measure but in rolled form.  One is only metric, and one is metric/imperial with story board.
I went with these because it seemed like in all the metal curved rulers, there was give on the hook at the start of ruler.  I found that almost all my metal tape measure have this give, and it really bothers me since I'm not sure if I should be measuring it pulled right, and what to do for inside corners.  This came up more recently when I was trying to square up the guides on my mft.  I later picked up a woodpecker square.
I noted that for the flat tape rulers, there was no give at all.
Should there be no give on the end hook of the metal tapes?  or, how is it properly used when trying to do precise measures?  normally i've just started the measure 1" in when I'm trying to be precise, but moving from home improvements towards furniture, I guess I'd like to clear up this nagging question...
thanks in advance!
Pages: [1] 2  All   Go Up
  Print
Jump to:
