Danielkarl
Offline
« on: November 25, 2010, 11:38 PM » |
I was looking at a Grex P635. I was wondering how well they worked and mostly how the depth could be adjusted. So if you have one tell me how you like it, how the depth is adjusted, and whatever, in addition to it being a really cool color. Thanks, Dan
Martin Johnson
Offline
« Reply #1 on: November 26, 2010, 01:12 AM » |
I have this one...love it...you adjust the depth with your air regulator...very nice and easy to use.
SRSemenza
Global Moderator
Online
« Reply #2 on: November 26, 2010, 01:23 AM » |
I have one. It is very good. As far as the depth goes - no adjustment on the tool. Changing pressure will do it, but I have found that it pretty much takes care of itself. I have used it on a variety of woods and never found a need to try adjusting the depth.
srs
Festool Service 800-554-8741
Bob Menefee
Offline
Location: New Philadelphia, OH US Member Since: Nov 2009
Remember to keep the "Son" in your eyes !
« Reply #3 on: November 26, 2010, 01:31 AM » |
I have the 650L . I love it . Have it for about 3 yrs now , works great every time . Grex makes a great gun not just for it color but it helps . On the 650L the adjustment is auto .
Thanks, Bob
Steve Rowe
Offline
« Reply #4 on: November 26, 2010, 10:04 AM » |
I have the P635 as well and it is a great little pinner. No depth adjustment as others have indicated and don't see the need for it. Have had it for over 3 years with no problems at all.
Neill
Offline
« Reply #5 on: November 26, 2010, 02:59 PM » |
I have the 635 also. Have had it for about 2 years without a problem. Being a hobbyist I may not use it as much as the others.
I have used it with my regular compressor as well as my Jac-Pac.
The only issue I have had is with the trigger and safety. I have large hands and the configuration is quite tight. It took a bit of a learning curve to get the hang of it.
Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
mastercabman
Online
NORFOLK,VA
« Reply #6 on: November 26, 2010, 07:27 PM » |
I had mine for about 5 years.I had to replace the blade about 1.5 year ago.Great little gun.never had any problem with setting nails.
rookie08
Offline
« Reply #7 on: November 26, 2010, 10:47 PM » |
+1 on the 650. Have it and it is great for all sorts of uses.
Cheers
CharlesWilson
Offline
« Reply #8 on: November 26, 2010, 11:20 PM » |
You won't go wrong buying this little gem.
Charles
Charles Wilson
GPowers
Offline
Metric convert
« Reply #9 on: November 27, 2010, 01:38 AM » |
I have been looking but is is a lot of coin.
Greg Powers Size:XL
harry_
Offline
« Reply #10 on: November 27, 2010, 08:32 AM » |
A lot of coin!
bonesbr549
Offline
I'd rather be woodworking
« Reply #11 on: November 27, 2010, 10:20 AM » |
While I don't need it often it works great when I need it. I have a c02 bottle setup with regulator and it works great and you can barely see the pin holes. I use it mostly to pin in wooden srrips in glass panels to hold the glass in.
ADKMedic
Offline
« Reply #12 on: December 02, 2010, 11:52 AM » |
I have the 650, and think it is awesome!
I have used it to hang crown molding in my house. it works quite well, and when those 23ga pins are shot at opposite angles, there is incredible holding power. I also pre-paint my moldings, so I like having teeny-tiny holes to patch and paint.
Andy
GPowers
Offline
Metric convert
« Reply #13 on: January 25, 2011, 01:03 AM » |
Decided on the P635. Just did not seen the need for the full 2 inches for the additional 100 bucks. So far I love it.
Greg Powers Size:XL
quietguy
Offline
« Reply #14 on: January 25, 2011, 10:29 AM » |
That is probably the best choice. The 2" pins are great in certain applications and in softer woods, but not something that you need very often (or maybe never).
Deke
Offline
« Reply #15 on: January 25, 2011, 05:58 PM » |
Oops, I have the 635. Who can keep track of all this?
Sal LiVecchi
Offline
« Reply #16 on: February 25, 2011, 12:36 PM » |
have a 635 and loved it so much went out and bought a 650 for the longer length pins....
Well rarley use the longer ones except for pinning stiles and rails on cabinet door assemblies
Both are awesome to use for sure....work great for my cabinet making applications
Life is too short and the road is too long to drive anything less than a Festool
Craftsman 11
Offline
« Reply #17 on: October 08, 2011, 06:52 PM » |
I have the Grex 645. Shoots pins up to 1 3/4". Grex makes really nice guns. I have their compressor too. Both excellent.
SRSemenza
Global Moderator
Online
« Reply #18 on: October 08, 2011, 10:47 PM » |
Hi Craftsman 11, Welcome to the FOG !  I have the 635. Do you guys that use the longer pins have trouble with them deflecting? Seth
RonWen
Retailer
Offline
« Reply #19 on: October 09, 2011, 08:11 AM » |
Hi Craftsman 11, Welcome to the FOG !  I have the 635. Do you guys that use the longer pins have trouble with them deflecting? Seth I've found that it depends on the type of wood and what grain direction going into -- those are some mighty thin pins not to be affected by grain direction. Most of the time it's not a problem although with the 23ga. I'm usually using <1-1/4" pins. It's a great tool!
Neill
Offline
« Reply #20 on: October 10, 2011, 10:08 AM » |
Just to stray a bit off topic from the current line of discussion, a word of caution...
I have the 635 and I love the tool. It's utility, quality, ease of use are all superior.
My word of caution is to be sure that you clear the chamber of pins before you store the tool. I don't use mine a lot but apparently after my last use there were 3 long pins left in the chamber. When I went to use it yesterday, I looked but did not see the pins in there because they were so far up. I loaded the chamber with shorter pins. Before I realized what was going on, I had three pins sticking through the finished lid on a box I made. I was able to clip them off, file and sand them down but the lid just does not look the same.
So, before you load new pins into the chamber, don't just look, but give it a shake to be sure nothing was left from your prior project.
Neill
GPowers
Offline
Metric convert
« Reply #21 on: October 10, 2011, 02:28 PM » |
Neill
Great insight, thanks for the tip
Greg Powers Size:XL
Neill
Offline
« Reply #22 on: October 11, 2011, 09:39 AM » |
Greg,
Thanks.
Neill
SRSemenza
Global Moderator
Online
« Reply #23 on: October 11, 2011, 11:05 AM » |
As Neill said, definetly check the magazine. I have had that happen too, but in the opposite direction (which isn't as bad). Shooting 5/8" when I though I was using 1". Discovered when small trim piece was not staying put.
Sal LiVecchi
Offline
« Reply #24 on: October 12, 2011, 11:13 AM » |
The newest version of Woodworking Magazine just did a review of Pin Nailers, They have a few recommendations on the different one out there it might be worth giving it a look before you make a purchase,
Bear in mind I have both the 635 and 650 and I believe in my mind they are top of the line
Sal
Craftsman 11
Offline
« Reply #25 on: October 15, 2011, 04:30 PM » |
Thanks for the welcome. I have to say yes , the long pins can be prone to deflecton but it does depend on the type of wood and the psi setting. Hi Craftsman 11, Welcome to the FOG !  I have the 635. Do you guys that use the longer pins have trouble with them deflecting? Seth
Jim Green
Offline
« Reply #26 on: February 20, 2012, 04:59 PM » |
I don't see anyone mention Omer nailers. I have used just about every brand over the years and nothing has compared to these nailers? I would highly recommend them to anyone's short list.
josephgewing
Offline
« Reply #27 on: February 20, 2012, 05:10 PM » |
A vote for Cadex. I would stick with the one that uses 1/2 inch pins ( the less expensive one ). I use the shorter pins much more often and have not needed the maximum long pins. An advantage of the Cadex is that *slight headed* pins are available. I have not noticed any difference in the entry hole they leave and they have more holding power than the non-headed pins.
Joe Ewing
builderbob
Online
« Reply #28 on: February 20, 2012, 07:34 PM » |
+1 for the Cadex! I have a Grex 630 from years back and it just collects dust. I have two of the Cadex CPB 23.35 headed pinners! I keep one in the shop and one for the field installs. I primarily only use the headed pins as the holding power is far greater than the straight pins IMO.
Bob
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Zacharytanner
Offline
Location: Upstate New York...Adirondack Mountains Member Since: Nov 2009
« Reply #29 on: February 20, 2012, 08:13 PM » |
I can't be the only one with the Bostitch 23 gage pinner............. I LOVE it
Frank
Festool Kapex KS 120EB w/ 4 Blades Domino DF500 Set Domino DS Systainer 4,5,6,8,10 TS55 w/ FS1400 and FS2700 Rails MFT/3 with Accessories CT33E D36 Tradesman Trion PS300 Jigsaw RTS 400 EQ Orbital Sander RO 125 125 Abrasive Systainer with , 60,80,100,120,220 Grit Festool paper 2 Systainer Carts Festool T18+3 Kit CXS Kit with Centrotec Wood Bits ETS 150/3 150 Abrasive Systainer Festool Toolie RO 90 RO 90 Abrasive Systainer OF 1010 Router
Frank
