Author Topic: Review/introduction to: Knipex CoBolt // compiled information  (Read 7227 times)
Offline six-point socket II
  • aka @the_black_tie_diyer
    • Portfolio
Hi!
I was asked about some more information on the Knipex CoBolt "pocket" bolt-cutter by one of our dear FOG moderators  :) :) which I happily compiled.
It might be informative also for other FOG members that's why he suggested I start this thread.
So here's what I sent:
Quote
I have the 72 32 200 ( http://www.knipex.com/index.php?id=1216&L=1&page=art_detail&parentID=1367&groupID=1473&artID=20523 )
When I bought it there was no CoBolt XL (10" / 250) - So I didn't have a choice size wise, but still I would not get the XL because it's not available with a what Knipex translates as "Multi-Component"-Grip. Which is basically superior in all aspects to the simple "plasti dip" type handle. I would not recommend the latter - they're less comfortable, they hurt more when you apply real pressure on them, they are quite a bit more slippery. And reaching for the XL would (for me, anyway) translate to: I need to cut large diameter stuff regularly and often - and I think a real bolt cutter would be way better suited for that. The CoBolt is just like a SAK - it can cut a lot of different diameters and even piano wire up to 3.2 mm - but it's the pocket version of a bolt cutter. Doesn't mean it's not serious business - as you will see. :)
Next: angled or straight. Straight all the way for me. Why? I have never come across something where I would have needed a angled cutting head because whatever it was couldn't be cut with a straight head. And, I feel like you're giving up power/control with the angled head. But like I said, this comes purely from never needing a angled head. One thing maybe: If you need to cut something off flush, than the angled version would be superior
The notch/recess: It's both, heaven and heck. Heaven because it really does make cutting larger diameter and hard material easier, heck because, depending on the material/hardness it will not cut through. So if it's really hard material and cracks easily you can go through in one attempt, if it's rather soft and it bends before it cracks - you will have to re-place whatever you're cutting to the front portion of the head and cut through in a second attempt. You will see this in the video :)
As you found out already, all of them are high leverage diagonal cutters. :) I have honestly no idea what they mean by fencing in this context.
Lets start with my short picture/video review :)
Here's the video link: http://sendvid.com/5iw6fdtd
From 00:00 - 00:09 I'm trying to cut a 6mm machine screw (steel, galvanized and blue chromated) in the front portion of the head.
From 00:09 - 00:16 I switched to the notch/recess and cut it with significantly less force as you can see.
From 00:23 - 00:25 I pre-cut a 4mm (A2) Spax in the notch/recess
From 00:25 - 00:28 I finish the cut in the front portion of the head. (This is what I meant with rather soft stuff being "heck" in the notch/recess, it will not cut through)
From 00:29 - 00:32 I cut a typical framing/roofing nail
From 00:33 - 00:35 I cut another, smaller nail. Typical "does it all/ all-purpose household nail"
From 00:36 - 00:42 I cut another machine type screw, somewhere around 4mm.
From 00:43 - 00:59 I cut another typical wood/all-purpose screw, again because these are rather soft, you can see I need to change from notch/recess to front portion of the head. Of course you can prevent that by simply cutting in the front portion of the head and not using the notch/recess on rather soft material.
Pictures:
The 6mm machine type screw:
The Spax:
The "mess" I've made ;)
Jaw/cutting edge shot - as you can see, absolutely no dents in the edges. And this was of course used before. But you can also see that the notch/recess is quite serious in depth, which explains the "trouble" with softer materials.
So, I'd say you'd be best suited with the 72 32 200 I have :)
Hope this helps! :)
Some more information on the Knipex CoBolt XL (10" / 250) Version can be found here, it's pretty new: http://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1367&groupID=2430
Kind regards,
Oliver
« Last Edit: March 19, 2017, 11:20 PM by six-point socket II »
Offline SRSemenza
Re: Review/introduction to: Knipex CoBolt // compiled information
« Reply #1 on: March 20, 2017, 09:04 AM »
Thanks Oliver,
    There are a bunch of different models of these Cobolt cutters to sort through.
     I think there are probably a lot of items such as this that aren't exactly woodworking tools but may still be very useful for woodworking and related projects. Especially those that are in the home improvement DIY category. The focus on FOG tends to be on woodworking due to the nature of Festool tools but they certainly get used for many types of projects. I like to get info on tools that relate going the other direction as well.
     A small pair of bolt cutters could be very handy.
« Last Edit: March 20, 2017, 09:07 AM by SRSemenza »
Offline DrD
  • I might not be fast BUT I sure am slow
« Reply #2 on: March 20, 2017, 09:19 AM »
@SRSemenza
Seth, are they available in the US?  WHere?  And how much do they cost?  Looks like something handy to have.
Thanks,
DrD
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline SRSemenza
« Reply #3 on: March 20, 2017, 09:31 AM »
@SRSemenza
Thanks,
DrD
   Ebay, Amazon, KCtool, Chadstoolbox,  Currently best price and 10% off at Chads.  But if you want free shipping Chads is slow.  Depending on the model $45 - $80. Differences -- grip style, spring /no spring, recess/ no recess, length 8" / 10", angled head.
« Reply #4 on: May 15, 2017, 01:09 PM »
I have the angled blue/red handle Knipex Cobolt as well as the older - red handle - straight version.  Both are great cutters.
However, I much prefer the angled version as it is way easier to flush cut / near flush cut nails and screws. The angle really does help cutting more flush and gives a little leverage against the surface.
It really cuts thick nails easily and does a quick job of even hefty screws. Together with the Neji-saurus Engineers pliers there isn't much I can remove very quickly with these two alone. :)
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
« Reply #5 on: May 16, 2017, 01:24 PM »
Thank you for a great write up! Forgot to mention that in my previous post.
Also I need to add that the red handle bolt cutter I was referring to is a Bahco bolt cutter. The angled Knipex is a better cutter but the Bahco cutter is alright. I have had trouble with some Bahco cutters since they moved production from Sweden to Portugal (and now China as far as I know) - the steel is not properly hardened and I have had cutters break.  [mad]
Knipex I trust.
Offline SRSemenza
« Reply #6 on: June 25, 2017, 11:21 PM »
I ended up getting the angled , comfort grip, spring, no notch, 8" model 71 22 200.
     18ga, 15ga brads = no problem, easy snip , snip , snip.
     Same for electric fence wire (not sure of gauge) and finish nail #4 and #8.
     8d and 12d galvanized nails a little effort but easy cutting.
     up to #10 machine screws no problem.
     GRK R4 wood screws #6 easy, #8 some effort but no problem, #9 a two hander but cut it. #10 hard to cut in fact i used two hands and went from two directions and didn't get through.... decided not to push it any further to make the cut. Maybe the notch version would cut the #10 ?
      Zero damage visible on cutting edges, no light showing through closed cutter edges.
      I would definitely recommend the comfort grip models based on the amount of squeezing required to make some cuts. I have not tried the regular grip but I can tell that I am glad I went with the comfort grip. There is a 10" (250mm) version available but currently only in regular grip. The longer handles would be easier to get two hands on but I think not having the comfort grip would be a big offset to the better two handed use.
« Last Edit: June 25, 2017, 11:27 PM by SRSemenza »
Offline SRSemenza
« Reply #7 on: July 26, 2017, 03:12 PM »
Looks like Knipex has introduced a new flush cutting Cobolt to the line. Completely flush , no bevel on the bottom side of the cutter.
    https://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1367&groupID=2476&artID=35193
Online Cheese
« Reply #8 on: July 26, 2017, 03:59 PM »
It should be noted that this is for soft materials only, from Knipex:
For the flush cutting of soft materials, e.g. plastic, aluminium, copper, lead
Precision cutting edges for soft material
Offline Trevin
« Reply #9 on: July 26, 2017, 04:21 PM »
Great cutters Oliver!  I have had one for a little while now and they are GREAT.  Cuts through most metals, screws, nails, etc easily. I like the fact that they are so small too.  Love Knipex!  Wera too!!
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline SRSemenza
« Reply #10 on: July 26, 2017, 05:35 PM »
Yes, so they are different in that respect. But up to 6mm on those materials. And should do it with ease based on what the regular models will cut.
