Author Topic: Miter saw recommendations (other than Kapex)  (Read 7143 times)
Offline Naildrivingman
« on: August 25, 2018, 11:03 PM »
I own a Kapex and I am pleased with it, so this is not intended to be an anti-Kapex thread.
I am interested in what others are buying for general purpose utility miter saws. Although I love my Kapex, it is for trimming only. I can’t justify putting it through the rigors of utility work, knowing that that the constant loading unloading may compromise the accuracy. Additionally I can’t justify the expense of another Kapex for utility work.
Previously I have owned Hitachi and currently my utility saw is a Makita (both 10”).  The Hitachi was a fine utility saw (unfortunately it was stolen), but the Makita has not proven to be so.
I’m interested in brand and model reviews from others.  What works, what doesn’t.  What’s weak, what’s not. Oddly, I am considering the 15” miter only Hitachi, but I would be unable to bevel stock wider than 4 3/4” with that saw.  I am not opposed to a one way bevel either.  I do think I would like to stay away from a slide saw for utility work.
Thanks.
Dance with who brung ya...
Offline lwoirhaye
Re: Miter saw recommendations (other than Kapex)
« Reply #1 on: August 26, 2018, 12:17 AM »
Miter saws have become so competitive on pricing many seem to fall short of what furniture makers want in the tool.   I think it's a quality control issue.  I've seen a lot of complaints about lemons in recent years.   Some designs like the articulated arm used by Bosch seem most suitable for carpentry due to play in the mechanism.   Out-of-flat and square base and fence castings have also been reported.  Even the recent iteration of the venerable 8-1/2" Hitachi sliding saw doesn't generate as much enthusiasm as the older models did.
I would buy one from a local dealer, take it home and give it a good going order.  If it isn't up to spec, take it back for an exchange.
« Reply #2 on: August 26, 2018, 01:11 AM »
I should have been more specific. I have definitely ruled out the Bosch articulating saw...too many pivot point give me concerns for long term stability.  The current Hitachi slider is not nearly as good as the model I had before.
I guess that leaves DeWalt and Makita. As I posted, my current utility saw is a Makita and I’m not impressed with its durability. The new model may be different. I would consider recommendations from owners of the most recent iteration.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #3 on: August 26, 2018, 03:25 AM »
I believe the question is really "...other than Kapex 120"...…
I too continue to be very happy with my KS120. It was part of my first Festool purchase and I spent a long time researching which tools to buy. The Bosch Glide came second in my research but I have since seen so many at shows and on display that it might not reach second if I were to start again.
Festool UK lent me a KS60 in April 2017 so that I could make a video about the new machine. My personal conclusions were that it was not good enough for me to sell my KS120 and pocket the difference but if I did not have the KS120 then it would be my first choice. The 60 mm maximum depth of cut might not suit some users but its 60 degree mitre and bevel (in both directions) would really help me.
« Last Edit: August 26, 2018, 03:46 AM by Peter Parfitt »
Offline Bullterrier
« Reply #4 on: August 26, 2018, 04:03 AM »
Certainly here in the UK the yellow saws are by far the most common sight on sites for roofing, stud walling etc and for trim in new builds. Usually with an accompanying dust plume unless the site manager is insistent re dust collection. The dual option of battery and mains adaptor on one saw seems to be a major point of consideration recently here given many sites have no contractor power supply (so battery or personal/shared 110v genny are the options).
Where the utility work is to happen matters too.
Off topic but expanding on Peter’s post my view is that innovation is needed for long accurate bevels for those of us without a large table saw. An area that exposes the slightest weakness in build and technique for slide mitre saws and in setting accuracy and particularly wobble and  technique for the TS55/75.
Offline SouthRider
« Reply #5 on: August 26, 2018, 06:54 AM »
Several years on my Bosch Glide saw with no problems from the articulating arms. They are robust and smooth. I did bend a fence when cutting a piece of trim too short and it was sucked out of my hand and took off like a rocket (black thumb nail too).
I absolutely love the saw, except for the dust collection, which is weak at best. It's best built into a bench with auxiliary dust collection.
You didn't say if this is to be shop based or mobile.
Many love the heavy Bosch for shop use, the ultra light Makita for mobile. Dewalt is the workhorse contractor grade utility saw. The Makita also seems to be the preferred jobsite trim carpenters saw, while the Dewalt is most often being used by framers, fence contractors, etc.
Here the Kapex is an expensive oddity, and not really used at all.
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline SilviaS7
« Reply #6 on: August 26, 2018, 07:25 AM »
I'm just a DIYer and very new to woodworking, but I recently purchased a Porter Cable 10-inch folding miter saw (model number:  PCXB115MS).  It folds up very compact so it's nice for storing away as space to work is a premium at my house.  I've used it to cut around 50 pieces of baltic birch plywood so far in various thicknesses, and with a nice Diablo blade it has worked very well for me.  It even has a nifty laser sight, which surprised me considering it's a pretty inexpensive tool.  It may not be up to the demands of someone using it for a living, I don't know as I haven't used it that much, but I've been pleased with the quality of the saw compared to the price (also using a nice, context-appropriate blade helps a ton).
« Reply #7 on: August 26, 2018, 09:10 AM »
This saw will be for mobile use almost exclusively.
« Reply #8 on: August 26, 2018, 10:55 AM »
Did you consider a Milwaukee mitre saw? I've owned 3 of the older Milwaukee versions and they gave me over 20 years of service before I picked up the Kapex. Over the years I used them for everything from aluminum and 4x4's to cutting pavers with a diamond blade. I never had an issue with any of them.
I haven't looked at the latest versions but I've heard good things about their new battery model. That may make transportation easier as it only weighs 28#.
https://www.milwaukeetool.com/Products/Power-Tools/Woodworking/2733-20#sp-specs
Offline Dick Mahany
« Reply #9 on: August 26, 2018, 11:16 AM »
Wow...5 year warranty to boot !
Offline rst
« Reply #10 on: August 26, 2018, 11:36 AM »
Milwaukee's warranty service is great.  I had a older 18v vac that would take both the new style battery and they're original lion battery platform.  After rattling around in the van for a couple years it would no longer run with my old style batteries.  My warranty had run out about 30 days earlier but they gave me a brand new one.  I also sent my impact back and they again sent me a a brand new Surge.
Offline Peter_C
« Reply #11 on: August 26, 2018, 11:45 AM »
Cordless going forward for a jobsite miter saw is the way to go. Makita offers their new miter saw with AWS which means it will trigger their cordless AWS dust extractor. Milwaukee cordless saws have good reviews, and I am people are happy with the yellow cordless saws too.
« Reply #12 on: August 26, 2018, 11:47 AM »
Received that 7-1/2” M18 two days ago. So far no dust made but can confirm that it is very easy to carry and the led lit cut line indicator looks promising.
« Reply #13 on: August 26, 2018, 11:54 AM »
Good to know about M’s service. Have an M18 2703 that may need a new chuck. Tapped several thousand m8 holes in 8020 stuff last year and the chuck is cranky.
Offline rst
« Reply #14 on: August 26, 2018, 02:02 PM »
I too bought the new Milwaukee chopper, not much heavier than my 8 1/4 skillsaw.  Trying to convince myself that I really don't need the new tablesaw.
Offline ProCarpenterRVA
« Reply #15 on: August 26, 2018, 06:12 PM »
DEWALT DWS780 https://g.co/kgs/Uh1GtR
I've been using this saw for a long time. It's a workhorse. Dust extraction is just fair.
Sent from my Pixel XL using Tapatalk
Offline glass1
« Reply #16 on: August 26, 2018, 08:27 PM »
as a big fan of the new makitas which i would recommend as an alternative to the kapex, but as a stable mate to the kapex I would get the dewalt 790 not the 780. the 790 on batteries has more power and smoother start up and is a great knock around saw.
Offline online421
« Reply #17 on: September 01, 2018, 08:26 AM »
If you dont move your mitre saw around and money is not an issue, I highly recommend Omga.
the entire saw and components are made of cast iron. the only plastic are the blade guard and the on/off button.
Yes it is very pricey but it will last 100 years.
My first Omga was a T50 350, bought it from a gentleman who has retired, and then I upgraded to their twin mitre saw version.
For a standard T50 350 I think the starting point is $4300 USD.
« Last Edit: September 01, 2018, 08:30 AM by online421 »
Griggio Unica400
Felder AD951
Masterwood OMB1V
SCM 5 RCS1100
Casadei FV110
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, CT36, LEX3
JLT 190BM2, JLT 79K10
Danfoss VLT 2880
Sicar TOP6
Offline waho6o9
    • Garage Door Handyman.com
« Reply #18 on: September 01, 2018, 09:11 AM »
1L 300
$1,394.00
SKU: 93121700
Omga has a cost effective one as well, it's 230 volts.
https://omgainc.com/product_detail.php?cid=2&scid=&sku=93121700
284622-0
« Reply #19 on: September 01, 2018, 03:15 PM »
1L 300
$1,394.00
SKU: 93121700
(Attachment Link)
Thanks for posting that. I had seen this company once before, but couldn’t remember the full name. I have it bookmarked now.
Offline waho6o9
« Reply #20 on: September 01, 2018, 03:38 PM »
You're welcome
« Reply #21 on: September 02, 2018, 02:40 PM »
1L 300
$1,394.00
SKU: 93121700
(Attachment Link)
I’ve researched as much as I could online. The two starter models seem like exactly what would suit my utility needs.  Unfortunately, the power supply can’t work well for a portable saw. I plan on contacting the company and inquire about a 120V machine.  One can hope.
Offline online421
« Reply #22 on: September 02, 2018, 11:36 PM »
1L 300
$1,394.00
SKU: 93121700
(Attachment Link)
You can also consider Elumatic(Germany) or Yilmaz (Turkey). both good saw, but I think Yilmaz may not be as good as Omga or Elumatic in terms of quality.
Griggio Unica400
Felder AD951
Masterwood OMB1V
SCM 5 RCS1100
Casadei FV110
Ceccato CDX 12
Holytek DC006
Danfoss VLT 2880
Sicar TOP6
Offline kingdarb
« Reply #23 on: April 08, 2019, 08:48 PM »
I have the Dewalt 780.  It is a workhorse, lots of power, and the fence is square to the blade.  Though the dust extraction isn't as good as the Kapex, it can cut as nicely as anything else with a good blade installed.
Offline Jiggy Joiner
« Reply #24 on: April 09, 2019, 04:10 AM »
Thanks.
No offence meant but, I cannot see the logic in buying an expensive saw, and being worried about using it for utility work, in case the accuracy is compromised?
I am currently mulling over a new miter saw, and I really do want to buy a Kapex 120. I’m only hesitating because of the doubt I have after hearing first hand and reading of a few of them failing.
If I do make the leap of faith, the saw will get well looked after but, used in all of it’s capacity.
Most of my tools apart from the workshop stuff, see site work daily, and are none the worse for the experience.
Just a thought but, I’d use the saw you have, and spend the money on something else.
According to Festool, the 120 is more than capable, and very durable for all the purposes it was designed for?
Unless if course you have the new toy tool urge?  [tongue] ;)
Offline vkumar
« Reply #25 on: April 09, 2019, 11:23 AM »
Skilsaw is introducing a worm gear miter saw that looks quite promising.
Here is as review on it.
Vijay
Vijay Kumar
Offline gunnyr
    • https://www.instagram.com/compassfinecarpentry/
« Reply #26 on: April 09, 2019, 10:35 PM »
Why not an HK?  I use my for everything from framing to fine trim carpentry.  I keep 18 and 36 tooth blades for cross cutting as well as a panther blade for ripping.
We used my HKC55 to install these beams last year.  The HK allowed us to bring the tool to the work.  Can you imagine trying to wrestle those beasts on a miter box?
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|PRO 5 LTD|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
