Author Topic: Osmo Oils for Interior and Exterior Use - Video Review  (Read 29500 times)
Offline leakyroof
Re: Applying OSMO Polyx Oil
« Reply #30 on: April 24, 2014, 12:54 PM »
I just bought some OSMO Polyx Oil to try out on some Oak plywood shelves.  I found this OSMO guide to applying it on furniture:
http://www.osmona.com/pdfs/install/osmo_polyx_furniture_application.pdf
What is interesting is that they specifically say:
- Work into the wood; do not paint on the surface.
- Remove excess finish from surface while still wet.
This aligns with advice from other sources to work in the oil with a white scrubby (I'm going to try white Vlies on my RO150) and then wipe it off.   If anyone is interested, I'll post the results in a few days.
Regards,
Dan.
Thanks Dan, looking forward to some pictures and more thoughts when using Osmo oils.
Offline Peter Parfitt
  • Magazine/Blog Author
Re: Osmo Oils for Interior and Exterior Use - Video Review
« Reply #31 on: April 24, 2014, 01:05 PM »
I have made a video about PolyX and do encourage people to wipe off the excess. I have found that several thin (wiped off) coats produce the best results.
Here is the PolyX video:
Offline leakyroof
« Reply #32 on: April 24, 2014, 01:47 PM »
  Very nice Peter. Thanks for sharing that. How long have you had the desk in use?  How is the Osmo oil finish holding up for you[ wine spills included.. [wink]]   I think it's funny for me about Oil Finishes.  I started with them when I was just getting into Woodworking, had some feeble success but was lured away by other finishes. And now, I'm back to researching them all over again and learning lots of great technique that I missed out on all those years ago.
 I also think that there's been a large uptick of Consumer interest in Oil finishes in the past 5 years.
 I find more people asking me about them than in the past.
« Reply #33 on: April 24, 2014, 02:45 PM »
I think the desk has been in use for 18 months or so - it looks as good as it did at the beginning. The same is true of a set of side tables that really do get abused - including plenty of red wine when I am not careful.
I used to teach French polishing and that has influenced my usage of PolyX - thin coats wiped off, let it dry and then another thin coat.
I think that oils have become popular because of the great improvements and range of products. Osmo have brought out an new version of PolyX with a slight glossy finish. I will be testing it soon and may use it on the walnut pedestal desk that I am making.
I have 3 or 4 videos on YouTube describing the desk construction and have another 2 or 3 to go.
Offline jmbfestool
« Reply #34 on: April 29, 2014, 04:08 PM »
I posted the other day how much I use to love Osmo but after using it for 8 years or so now and found it doesn't stand the test of time I have come to dislike the product.
I bring this up again because oddly my mate came up to me randomly said how he thinks osmo is crap.  I asked why and like me he has used it for many years and has gone back to jobs to find the product hasn't lasted.  He even said one client applied osmo every year to his door once my mate fitted it and it still went grey and mouldy.
He spoke to a painter and the painter has said he's stopped using it because the product doesn't last.
 Like I said before I have and seen many floors applied with osmo which after a year have worn off.
Yet I have used other products which have lasted much much longer.
Now my mate contacted osmo and they said you should use a osmo primer.
Now either osmo dont give proper instructions with their product or their products are just rubbish.
I always read the instructions on the tin and do as it says.
*********************************************************************** [thumbs up]UK members click me
Offline amt
« Reply #36 on: April 30, 2014, 04:42 AM »
I have been using Osmo for 2 years on Guy Ashley's recommendation. I have had no problems with any of it but will follow the manufacturer's directions when it comes to a maintenance coat. The outdoor oils are a great improvement on everything that I have tried over the last 40 years. Also, I no longer use polyurethane on anything. I will also avoid French polishing from now on as I think that the new PolyX Gloss is going to give a far more durable finish.
Offline Gjarman12
« Reply #37 on: July 13, 2017, 09:23 AM »
Does anyone else have some thoughts on Osmo vs surfix? I'm making some outdoor furniture out of cedar and cypress and considering trying either the outdoor surfix or Osmo 410.
A small perk for me with the surfix would be getting the other finishes in the kit to try on some other projects.
Offline leakyroof
« Reply #38 on: July 13, 2017, 10:03 AM »
  I'm still not sure if Surfix isn't actually Osmo Oil rebranded for Festool.
 But, I have used Surfix Outdoor Oil and while it doesn't have any longer life for UV protection over other Oils rated for Outdoors, it does seem to prevent Black Mildew or Mold discoloration over some other products that I've used in the past.
 And I'm in a fairly Northern Climate, if you have more Sun, you may need to reapply it or Osmo Oils more often if the UV degrading is more severe for your area.
 Once a year to twice a year was what I was experiencing depending on how much Sun my outdoor stuff was getting.  Rain didn't seem to be a factor, which was nice since I DID have Black Mildew with other oils in the past.
  Supposedly, Tung Oil products aren't as liable for that Mildew Discoloration compared to Linseed Oil products, but a lot has to do with the additive packages put into an Oil mix.  That makes a big difference compared to a 'raw' oil applied with nothing more than a solvent to help penetrate the wood surface.
Offline deepcreek
    • TimberFire Studio
« Reply #39 on: July 13, 2017, 02:49 PM »
Definitely not.  Two different products.
Joe Adams
TimberFire Studio
Houston, Texas
Offline leakyroof
« Reply #40 on: July 13, 2017, 02:56 PM »
  Did we ever find out who's providing the Surfix Oil for Festool?
Offline Gjarman12
« Reply #41 on: July 14, 2017, 08:06 AM »
I think the surfix has a recoat time of six hours, while the Osmo is 12 from my online reading. If that's true, they would appear to be slightly different.
