Pages: [1]   Go Down
  Print
Author Topic: Small Air Compressor  (Read 4387 times)
Tinker
Offline Offline
« on: March 25, 2012, 02:14 PM »
My one year old 10 gal 1-1/2 hp Craftsman had slipped a gasket.  I flipped my own gasket.  That was the forth compressor of that make I had gone thru in seven or eight years.  Each one had suffered a different problem. With each breakdown, I examined the break and decided I had better get a bigger compressor; so back to convenient Sears I went.  At some pint, I would find a size that would have the capacity to fit my needs fit my needs.  I had hoped this latest would do the job for me, as I no longer had any crew other than myself.
Aside from the fact that my neighbor occasionally called me late in the evening to tell me my compressor was keeping them awake, and the fact that I could not seem to find fittings that kept the joints airtight, the tool seemed to be working ok.  I just lost a lot of air due to leakage along the lines.  The only fitting that was tight was at the impact wrench.  No matter how many times I went back to Sears, I could not stop that air.  When the line from the pump to the tank blew out, I inspected and decided the necessary repair would not solve the problem without reaming out the cylinder port and creating a whole new problem.  I had to take a different tack.
Enter ToolNut.
I had recently visited the ToolNut store in Yorktown Heights, NY to look over their supply/display of Festoys.  While there I had noticed several makes of air compressors.  Their display signs out in the front of the store advertised an expertise in air tools for the building trades.  My infallible comprehensive reasoning told me that anybody carrying a full line of Festoys  just had to have the good sense to carry good quality in their other lines.  I investigated, thru the toolnut.com website, their line of air compressors and whipped off a couple of E-mails.
Along with immediate replies to my E-mails, I made several phone calls and headed for Yorktown Heights, a little more than a half hour drive.  I had planned to purchase their Rolair VT 20 2hp wheeled compressor, but upon looking over that machine and the much smaller JC 10 1hp 2 gal compressor. I decided to take my chances with the smaller unit,  I was not sure if it could handle my needs, Sean Ackerman and Doug, one of his store sales men, had both advised me to go with the VT 20.  The main drawback they felt was my use of an impact wrench for tire repairs and removal and reattaching blades on my large mowers.  The big factor for me was weight.  With sometimes debilitating back problems, weight, or lack there of, is often a deciding factor for me.  The VT 20 was mounted on a wheeled frame, so it should be easily moved around in my yard.  It seemed to be a little out of balance when straightened up for rolling around, so I felt it would be parked in the barn and almost never moved for use anywhere else.  The JC 10 I could pick up and carry with one hand.  I liked that.
After discussing my thoughts with Doug, I decided to take the smaller machine.  My idea was that when I was ready to work, I could hook up the small JC 10 to my old ten gallon air tank and I would have plenty of reservoir to handle my impact wrench.  Doug thought that might work and agreed that if it did not work, I could bring the tool back and replace with the VT 20.  The stipulation was that I should not spend a lot of action with the JC 10.  If it did not work for me right away, “…don’t get it scratched and dirtied up with use.”  That seemed fair to me.
Fast Forward to my shop:
I read the directions for any surprises to be found as soon as I got home.  No special problems that aren’t part of the territory of compressor land, so I started the machine up.  It took all of a little less than 55 seconds to achieve full air.  That was the extent of my first trial run for that evening.
TEST #1 The following day, I got home early in the afternoon and decided to give a full trial.  The first thing I did after starting the tool was to set the air controls to maximum recommended settings by building up the air and adjusting with the switch on.  It took only a minute to set the control.
The next stage was to hook up a 20’ hose and get out my impact wrench.  No problem there.  I had no leaks at the pump, a new sensation that seemed never to be the case with my previous several units.  The connection was tight, as it was also at the hammer end.
I backed my trailer up to the barn and started loosening lug nuts.  With just a short brrrrr on each nut, I had three nuts loose before the JT 10 went into action.  I continued until I had all six nuts loosened.  Without stopping, I spun all six nuts completely off of the bolts, all the time, the compressor kept its silent pumping.  I guess at this point, I was probably getting very discouraged as I was afraid I might need to invest in a hearing aid to know whether or not the pump was running.  That pump is even quieter than any of the oil type compressors I have had.
Once all of the nuts were completely off the rims, I reset by hand all six to just catch the ends of the threads.  By the time I had one or two nuts ready to go, the pump was already up to full air.  Once all nuts were ready to go, I proceeded to zap away with the impact wrench.  Each nut was spun til it made contact with the rim and then I went right to the next. By the time I got to the third nut, the pump had gone back to work.  I just kept zapping away until all nuts were snug against the rim.  I then went around to each nut for a final zap, going twice around all six nuts.  The next step was to get out my breaker bar to make sure the nuts were all tight.  They could have been a little tighter, but I had not allowed the pump to get up to full pressure.  I tightened all of the lugs to about what I usually set them by hand.  Once satisfied all nuts were tight, I attacked once more with the impact wrench.  With just a quick Brrr to each nut, I was able to take each nut up just a little tighter.
The verdict:  For the toughest job I will put the compressor to.
   Speed of operation      adequate for my needs (I barely have a rest)
   Operational pressure      more than adequate
Silence of equipment       I cannot hear it over the crickets I hear all the                      time  day after day after day.
Satisfaction to this point  Total
TEST #2  The next test would be to loosen the nuts for my large mower blades.  The mower had not had a blade change since late last fall.  I do not change blades every couple of days when doing fall cleanups as I do when mowing thru the spring, summer and early fall.  I had also run the mower for about two weeks of early spring cleanups.  I usually have some problems with tight blades and for first blade change in the spring, I nearly always find it necessary to resort to the old breaker bar.  Sometimes I even need to put an extension pipe onto the bar so I can have enough leverage to break the nuts loose.  I made sure I had both bar and pipe handy along with the block of wood to hold against the blades as I work the nuts loose.  I was very much delited when the impact wrench proved sufficient for all three blades.  I needed neither breaker bar nor extra wrench.  One blade required three zaps to break it loose, but the rest came loose with the first contact.  That has never happened with the first blade change in the spring.  From there on, it was only routine to put blades back on.  I only zap them up to about 15 lbs of torque.  A piece of cake.
The verdict:  Disappointment?  No way.  Rolair Compressors are top quality
This morning, I went out to the barn for something unrelated to work.  As I walked past my trailer, I noticed it had a flat tire.
TEST #3   I thought this was the best time to put that little compressor to its final test.
I had picked up some new hose fittings.  When I noticed the flat tire, I replaced the old leaky fittings on my 30 foot air hose that had always leaked since day one.  Once the fittings were tightened to satisfaction, and attached the 30 foot hose to the 20 foot hose I had been using, I cranked up the new toy and listened for air hissing.  Well, as much as my crickets noises in my ears would allow, I could find no leakage.  I dragged my extra hose out to the tire and pressed air tool to valve and started pumping air.  It took about 7 seconds before the pump ran low and started pumping.  I backed off with the air tool and waited about fifteen seconds for the air to come back to full.  I then hooked back onto the valve and just continued for about 30 seconds after the pump came back on.  In total time of pumping/waiting/pumping/waiting etc, etc, it took about three minutes to get the tire up to 60 #s of pressure.  There was not enough air in the tire to register when I started.  Some of you might want to know the tire size (215-75-R16   load range E for trailer use only)  Three hours since filling with air, the tire is still full of air.  I think the reason it went flat was because I had checked the air the day before and it is possible the valve core had stuck.
The Verdict: filling a tire with air is the toughest job for a small air compressor. It took me about three minutes to fill my trailer tire to 60#s.  I cannot expect a 1hp compressor to do any better than that.  I checked by hand all parts of the compressor to determine if any over heating. Warm but not hot. For such a small compressor, I did not really expect such performance.  I have had oil type compressors that made more noise.  Larger compressors that were no faster (for my work)  (It doesn’t take much to keep one man busy).  For such a small machine, the Rolair JC 10 is a Mighty Mite.  Bonus:  Made in USA
The specs are:
Horse power      1hp
RPM            1725rpm
Cylinders         2
Cu ft of displacement   5.3
CFM @ 90 PSI      2.35
Tank capacity (gallons)   2.5
Shipping Weight      39#s
For my needs as a one man operation, the JC 10 is very adequate.  I can run my 500# impact air wrench all day.  I can handle my necessary bolt/nut loosening projects as well as with any other compressor I have had.  It took about 3 minutes, using 50 feet of hose, to fill a completely flat trailer tire to 60#s pressure.  I think it might take at least 10 or 15 minutes to fill one of my truck tires to 50 or more #’s, but the pump is fast enough to get air pressure to a point I can get the three miles to my closest repair station to get the tire fixed.  The site literature suggests the compressor can keep up with one air nailer.  I do not doubt that.
I am sure there are situations where two nailers could be kept busy with certain framing situations where the impacts might not come in such rapid succession and short hose situations.  Not in every situation.  The machine might not keep up with shop needs where two or more impact wrenches are required, but I see no time lost where one wrench would be in use.  Heavy truck work would be a big problem, but for my one ton trailer and 1/2 ton pickup truck, the tool performed well beyond my expectations.
At only 39 pounds weight, the machine is perfect for me and my bad back.  It is fully portable and also very easy for me to hide away totally out of sight in my very open barn when not in use.  With a small generator, I can now load the compressor onto the front seat of my truck and take air to the site to a broken down machine.  There will be situations where that will be of great help and can cut my labor expenses enough that one breakdown will go a long way towards the JC 10 paying for itself.
Like any undersized machine, the JC 10 has limitations.  I just do not foresee serious limitations for my operation.  The machine is mightier than it looks.
Note:  This tool was not given to me for testing.  I paid for the tool from ToolNut with the primary advice from them that it probably is too small for my needs (specifically for operating an impact air wrench).  However, just like any other kid, it is sometimes hard to get me to listen to good advice.   Poke
Tinker
Wayne H. Tinker
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #1 on: March 25, 2012, 02:48 PM »
Thanks for the review Tinker.
I, too, have the small JC-10.  I absolutely love mine.  I doubt that it could be the go-to compressor for a pro, but as a hobbyist, it has done everything I asked.  Only time I have to wait is when I have been using it as a blower to clean out the shop.  Best of all, it is amazingly quiet - and not a peep from the wife or neighbors!
I just assumed it couldn't run an impact wrench - thanks for setting me straight.
Ken Nagrod
Restricted
Offline Offline
« Reply #2 on: March 25, 2012, 03:07 PM »
So Wayne, this wouldn't work for you?  primitive compressor
Tim Raleigh
Offline Offline
WWW
« Reply #3 on: March 25, 2012, 03:25 PM »
Where's the rest of that bagpipe? Wink
mastercabman
Offline Offline
NORFOLK,VA
« Reply #4 on: March 25, 2012, 03:43 PM »
I too have the JC10 Roll-air.And not only the compressor is great but the warranty service is one of the best.
A little over a month ago i was doing some finish up work.Took the comp. inside the house,plug it in then went back outside to my truck got a few more tools and back to the house(about 3-4 minutes)and the compressor was still running Huh?
Checked the drain valve,try to listen to any leaks,nothing like that.I noticed that the gauge was at about 50 psi and just holding while still running.Turn it off,drain it and started again.Same thing.So i put the compressor back in the truck.
Later i decided to inspect the unit to see if there is something i can do to fix the problem.I took one of the cylinder head off and there it was, a broken intake valve.I emailed roll-air and asked if they could just send me the part and i would install it so that i wouldn't have to ship it anywhere.So they did.They were very nice and very fast at shipping the part.
So i get the part,replace it and plug the unit in.It's running and it is pumping.It's doing good just about 90 psi.Then the motor bogs down and stops at about 95-100psi. I tried again and same thing!  Sad
At that point there's got to be something more serious.So back to emailling Roll-air.Again very helpful and they gave an addres of a local tool repair shop.I take it there and they told me to check with them in a few days.Few days goes by and called them.They telling me that they could figure out the problem and they even had roll-air technician on the phone and still could not do it.So roll-air told them to ship the unit so that they could work on it.
2 weeks goes by and Roll-air shipps back a NEW compressor to the repair shop.
Got it home and will be putting to work this week!!
Roll-air service has been very,very good!!!!!
Tinker
Offline Offline
« Reply #5 on: March 26, 2012, 04:47 AM »
Ken,
I do have a compressor that is over 100 yrs old.
When THE BOSS & I were first married, she had told me her mother had a bellows from her grandfather (My wife's grandfather) who had been a shop foreman in an iron foundry in Germany.  Being that I was a mason contractor and designing and building fireplaces, I was especially interested in fireplace tools.  My wife told her mother of my interest and she would like very much if her mother would give me those old bellows for Christmas or for my birthday.  I knew nothing about that part and come our first Christmas together, there appeared a package under our tree from MIL.  I did not have a clue as to what it was, but my wife was beside herself with excitement.
Once i opened the package, my wife went into tears.  There in my hand was a fireplace bellows.  Not the ancient bellows from Opa, but a typical bellows anybody could pick up from a tourist shop.  I was a little put out at the same time, but said nothing other than normal talk meant to calm my wife.  When our children were 4 and 6 years old, we went to Germany to visit my wife's family.  One of the first things she did was to go into the attic to search for that old bellows.  When she finally found it, she told her mother she was taking it home with us.  Her mom had not given the bellows to me because "...it was alt and rough and dirty..."
We got it home and cleaned the leather, but left the wood as rough as we had found it. We think her grandfather might have made the bellows himself.  The wood is very rough and unfinished and the leather is very thick, much thicker than i have seen on any other bellows.  I used it for 23 years while the only heat in our house was a woodstove.  We no longer use the stove unless there is a power outage, but that old bellows is safe, right there beside the stove.
A little more info, not necessarily related to this thread, but it does help to explain my MIL's attitude. When we first went to visit Germany, my wife had wanted to show me the old buildings in her town and elsewhere in her home area.  I was so excited to see the ancient architecture, I could hardly wait to get out and around.  Of course, my wife had not seen her mom and sisters for several years, so we felt obligated to go where they wanted to show us around.  For the first few days, the only sights they wanted to show us were the new buildings.  Those were not especially works of art, but more necessary replacements for buildings that had been bombed out during The War.  We were sort of hustled past the "alt biltingks".  They were "ukgly".  Her mom just could not understand how exciting it was to me to be looking at those hundreds of years old buildings and churches.  We finally had to put out feet down and make it clear that we were far more interested in the oldest architecture.  We could see new buildings anywhere in America. By the time we had visited a few more times, the folks finally understood, or tried to understand.  I don't think MIL ever fully understood our interest in the old buildings.
MIL never came close to understanding why I liked that old and rough bellows, but I won't part with it.
Tinker
Wayne H. Tinker
Tim Raleigh
Offline Offline
WWW
« Reply #6 on: March 26, 2012, 10:05 AM »
Wayne:
Great story.
BTW, always wondered about those craftsman compressors.
Now I am happy I have shied away from them.
Tim
Tinker
Offline Offline
« Reply #7 on: March 26, 2012, 11:08 AM »
Tim, I have had four of them. The first and the quickest one to go was the only oil type and 1-1/2 hp with three gal tank. It lasted a year and a half.  Next was oilless the same size. that lasted about one month longer than the first.  Then i got a 1-1/2 hp oilless with 5 gal upright tank.  that held up a couple of years.  Then I got the 2hp oilless with ten gal tank. That lasted around 1-1/2 to 2 seasons.  I did not even look for the sales slip to see if there was a warrantee.  It is so poorly made, it is not worth even thinking of trading either up or down.
I guess i was thinking the way to go was to get a bigger compressor and sooner or later, I would find one that would hold up. In picking up this tiny Rolair, I have a one horse oilless with a 2.5 gal tank that is silent, portable and it seems that my air leakage at the tank has been solved.  I did not replace the hose fitting at the tank.  You can draw your own conclusions about how that leakage problem was caused.  If you can find a Rolair, i am pretty sure it will be a good one.  you can see a difference in the over all construction.  It just looks stronger.  And that low RPM motor means, IMHO, that the machine should last a long while.
Tinker
Wayne H. Tinker
andvari
Offline Offline
« Reply #8 on: March 26, 2012, 11:14 AM »
I love these customer service stories. That's how you really find out what to buy.
live4ever
Offline Offline
« Reply #9 on: March 28, 2012, 03:05 AM »
I also got the RolAir JC10 recently.  My main motivation was to replace my similarly sized (but very LOUD) Craftsman.  I've been planning to build a venturi veneer press for a while, and since the air compressor needs to cycle on periodically during a press, I wanted a compressor that would be as quiet as possible.
As stated, this thing is extremely quiet.  And the build quality is excellent as well.  Very pleased.
My Green Addiction:  TS55 | ETS150/3 | RO90DX | DF500 | OF1400 | RAS115 | KS120 | LR32
Sean Ackerman
Festool Dealer
Offline Offline
Festool Dealer near NYC - 10,000 sq feet!
WWW
« Reply #10 on: March 28, 2012, 12:28 PM »
Them be some real good boys over at Rolair.  Very kind, very genuine folks.
What was the final diagnosis out of curiosity?
John Stevens
Offline Offline
Ardmore, PA
« Reply #11 on: March 28, 2012, 11:35 PM »
Thanks for the compressor review, and thanks for another of your great stories.
Regards,
John
What this world needs is a good retreat.
--Captain Beefheart
Vindingo
Offline Offline
« Reply #12 on: March 29, 2012, 01:35 AM »
How does the JC10 do in cold weather?
My hitachi will not start at all if it is under 40F
Tinker
Offline Offline
« Reply #13 on: March 29, 2012, 11:42 AM »
I have only had my Rolair a little over a week.  Altho the temp was all the way down to 28, it had no problems pumping up a flat tire so i could drive it to the shop for repair.
If you are ever worried about the effect of cold weather, it is light weight enough you can store it in the cab of your truck.  You can take it inside the warm house.
If you are rally worried, you could even take it to bed with you  Shocked  Poke
Tinker
Wayne H. Tinker
hrrb
Offline Offline
« Reply #14 on: March 29, 2012, 11:51 AM »
Tinker
Hmmm...how loud does it snore? How many dB?  I just want to compare it to my wifes snorring before bringing it to bed Big Grin
/Henrik
andvari
Offline Offline
« Reply #15 on: March 29, 2012, 11:57 AM »
Tinker
Too much information.
mastercabman
Offline Offline
NORFOLK,VA
« Reply #16 on: March 30, 2012, 07:28 PM »
Don't really know at this time.I will try to contact them and see if they can explain what happen.
Tinker
Offline Offline
« Reply #17 on: March 31, 2012, 07:46 AM »
Tinker
/Henrik
dB's           practically silent.                  Advantage?
warmth     practically cold running        Advantage/Disadvantage      Your choice
Vibrations  very minimal                       I'll leave that one alone         Scratching Chin
Tinker
Wayne H. Tinker
Tinker
Offline Offline
« Reply #18 on: May 08, 2012, 04:19 PM »
Another way I just put that little monster to good use.
The other day, I started loading mower, blowers and trimmers on the trailer for the days fun and games.  i was staring real early to beat the rain for that day and I was not sure i could get the tire repaired so early in the morning.  I usually have spares on the shelf, but I was using my backup mower which gets used maybe one or twice a season. I had no spare for that particular tire.
i put some air into the flat and then loaded the compressor into the front seat of the truck.  This time of year, my front seat is full of bags of grass seed.  That little compressor sat very nicely right on top of the grass seed.  By noon time, the tire was again soft, so i just ran my air hose out the door of the truck and drained some air out of the tank, and Voila! i was good to go the rest of the day and fixed the leak on my way home.  I now keep the compressor on the front seat of my truck, fill the tank in the morning, carry an air hose and 50 ft 10 ga, cable with me all the time.  For most flat tire situations on the job, it should suffice quite well.
Tinker
Wayne H. Tinker
Pages: [1]   Go Up
  Print
Jump to:
