James Watriss
Offline
« on: August 03, 2009, 09:11 PM » |
So, there are three in the lineup, with various configurations and combinations available in sets.
The impact driver is remarkably not bad for a 10.8V tool.
There's a small, no frills, very compact, but slow drill/driver. It works, but slowly, so I wasn't too impressed. IT has a hex shank, which I dig, but decent hex drill bits, while available, are not the norm. I think this is better used as a screwdriver, personally.
Then there's the drill. 2 speeds, more weight, and an actual 3 jaw chuck. Not too shabby. It's not going to win any power contests in my shop, I'll tell you, but for general use, it works. I will say that it's entertaining in a 10-year old humor sort of way to stick one long hex shank bit into the chuck of this, and the other end into the impact driver, and pull the triggers on both, to make a most godawful racket.
I own a C12 and a T15+3. The T15 is awesome, and my C12 will eventually go on eBay, I think. But my day job is in a fiberglass shop, doing all manner of odds and ends, and one of the most convenient things about these drills is that I can just chuck them in my tool box with room to spare. They're as big as they need to be, and no bigger. No bottom of the handle battery bulge, etc. And while they're big enough to do most day to day stuff, they're not big enough to arouse anyone's envy or interest... and will therefore be, I think, even more useful. The most important feature of any tool, after all, is that you still have it.
More as it comes, Tool stop has a kit with the impact and the better of the two drills in a SYS-1, which looks very cool... I'm currently trying to get my hands on it. There's also a Bosch version of the multimaster in a systainer, and in a combo kit, that has my eye, but not my money... yet. I want to see how these 10.8 batteries hold up long-haul.
erikfsn
Offline
« Reply #1 on: August 03, 2009, 09:42 PM » |
I've been using the Makita 10.8 drill/impact combo for around 6-8 months now. I also have a couple of their 18 volt lxt drills. I find that I reach for the 10.8 volt more often than the 18 volt. I like the size and weight for ease of use. Most of the time they have what it takes to do the job. When they don't I up the voltage.
quietguy
Offline
« Reply #2 on: August 03, 2009, 10:47 PM » |
I have been a little disappointed in the Bosch 10.8v (now 12v) series of tools. Below are my impressions of the tools I have used -
I-Driver - Great tool. Just the right blend of size and flexibility to be extremely useful.
Hex-Driver - Very handy, but not as well executed as the Milwaukee (and probably the Makita) offerings. 2-Speed Drill - Another great tool. Very compact and balanced for "tool-belt" work. For the most part, I use it for pilot-holes and counter-sinks. It won't replace a larger driver-drill, but is also very handy.
"Multi-tool" - haven't tried it, and don't plan to. I don't think it could replace my Mulit-Master.
Impact Driver - pretty much useless for construction and woodwork, bu would probably be great in certain scenarios. It just turns too slow for most of my undertakings. Compared to my 12v Makita impact, this thing is a wimp.
One thing that is a little hard to quantify is the size advantage that these compact tools provide. I can stick the Milwaukee or Bosch hex-driver in my tool pouch, and never know it was there (very slight exaggeration).
EcoFurniture
Offline
« Reply #3 on: August 03, 2009, 11:32 PM » |
I have been using two of the bosch drivers every day for almost half a year now. First what I like about them: 1. price is affordable 2. lightweight and small in size 3. build in LED light helps in dark corners 4. enough torque to build cabinets
What I don't like: 1. The RPM is to slow to use them as a drill 2. The batteries are already not holding their charge for long anymore! 3. You can't "stand" them up
Would I buy them again? Well I don't know. I have them now, therefore I have to use them... But I will certainly save up some cash for a festool drill.
Charimon
Offline
Tool and Tile Junkie
« Reply #4 on: August 08, 2009, 11:50 PM » |
I have been using the Makita 10.8v for about 8 months What I like: 1. Price; $128.00 for the pair. This is the scale that I weigh all other cordless tools. Is (fill in the blank) tool 2, 3, or maybe even 5 times better than this pair for what I do? Haven't found anything that is yet. 2. Size; both guns, batteries, charger, Festool hand sander, 9"Chanel locks, and Kreg vice clamp fit into a Sys 1 3. Power; the impact has 800+ inch pounds of force and the drill will handle 1"spade bit enough to do 97% of anything I may want it to. 4. Ergonomics; when I lay it down, it sets on rubber- no scratching finished surfaces. It is lightweight, small, all the controls are easy to get to, the led light is automatic when the trigger is first pulled( before the chuck begins to turnl), over all it has a great "feel". 5. Durability; I barely respect my Festools, these get no love shown them at all, still they have preformed with out any problems, that is all I can ask of any tool. What I don't like: 1. 1/4" hex chucks; Now I have to find drills, reamers, thread chasers... to fit the drill (luckily many companies are making their tools in this format) 2. Capacity; is limited to 1/4" hex. Now my sds rotary hammer does double duty for larger drilling chores (purchased a sds chuck $35.00) 3. Battery life; Because there are two tools in the kit and I often use both tools on a given task, I am always running out of batteries. What would ideal: This system with three batteries and a chuck on the drill for under $200. This would be the perfect setup for most remodelers. Getting them to understand that this is what they really want is a different issue  . Additionally, it would be great if all 10.8v tools could interface. I would really like to run a couple of Milwaukee's tools with my system I know a pipe dream  Thanks Craig
« Last Edit: August 09, 2009, 12:32 AM by score0matic »
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
jonny round boy
Online
« Reply #5 on: August 09, 2009, 04:58 AM » |
Additionally, it would be great if all 10.8v tools could interface. I would really like to run a couple of Milwaukee's tools with my system I know a pipe dream  I saw the Milwaukee 10.8V range at a dealer a few months ago, including the really cool fibre-optic camera inspection thingy (that's the technical name!). I'm not 100% sure, but I think the Milwaukee batteries are exactly the same format as the Bosch, and they are interchangeable. From his comments below above (!), I think mwhafner has both Bosch and Milwaukee Li-Ion tools - maybe he could confirm this?
« Last Edit: August 09, 2009, 05:00 AM by jonny round boy »
quietguy
Offline
« Reply #6 on: August 09, 2009, 10:32 AM » |
From his comments below above (!), I think mwhafner has both Bosch and Milwaukee Li-Ion tools - maybe he could confirm this? You cannot use the Bosch batteries on the Milwaukee, or vise-versa. The configuration is a little different.
Beverin
OfflineMember Since: Sep 2009
« Reply #7 on: September 10, 2009, 11:08 AM » |
To James Watriss: I bought the Bosch Multimaster version Installer kit for 179, it actually comes with a 12V battery and I do not want to miss it any more! it saved my life quite a few time in different situations (I run a solid surface fabrication and cabinet business). It is great to cut off baseboard if you want to install cabinets etc.
Same here for the Bosch angle drive 10.8v... what a tool for small cabinets! My batteries are two years old now and still have enough Power to last thru a normal installation... I believe BOSCH is second to only festool...
Chrippler
Offline
« Reply #8 on: August 25, 2010, 08:47 AM » |
I have to say I'm sold with Bosch, I love 'em. The only problem i've had with them is battery life... Been through a fair few batteries, but now know a way to combat it! They seem to last 100x longer if you make sure you fully drain the battery each time you fully charge it. So once you've charged it you need to wait till it cuts out before charging it back to full again and you'll get much longer life out of your batteries! (You probably already know this...) I got my latest Bosch stuff from Tool guru... www.toolguru.co.uk.
justinmcf
Offline
Location: Gold Coast, Queensland, Australia Member Since: Nov 2008
Queensland Builder
« Reply #9 on: August 25, 2010, 05:21 PM » |
hi chrippler.
when you state that you fully drain the battery each time. are you talking about ni-cd, ni-mh or li-ion batteries?
dont forget that this is not recommended for the newer li-ion technology as it will actually damage the battery.
only ni-cd batteries are to be completely drained before recharging.
justin.
WarnerConstCo.
Offline
« Reply #10 on: August 26, 2010, 05:11 PM » |
I hate all the 10.8/12 V mini tools.
I bought the bosch and makita one's, used them for a month, got my c-12 and they have been collecting dust ever since.
IMO, they are worthless.
Ken Nagrod
Restricted
Offline
« Reply #11 on: August 26, 2010, 07:52 PM » |
I've been using the "mini" tools for the past three years. Started with the Bosch 10.8 volt T handle driver and the right angle driver. At first I loved them. Great for doing smaller stuff, especially the hard to reach areas like inside small cabinetry, screwing in drywall behind a radiator. Found a major problem with the Bosch 10.8 batteries on a union job I was on. The guys were depending on me to get the cabinetry screwed in because the big stuff wouldn't fit. The apartment building didn't have the heating system operational yet and it was about 40 degrees F. My Bosch minis acted like they were dead or just about dead even though I had charged them fully the night before. So while everyone's waiting for me, I'm on the phone with a Bosch engineer trying to get answers. I was told the chemistry for their 10.8/12 volt minis isn't the same as their larger batteries and can't take temps below approx. 50. Now I was ticked. This was before I owned the C12 with accessories. I had to warm the batts up in my pockets constantly until the heaters warmed up the kitchens enough. Bought the Milwaukee 12 volt tools and NEVER had a problem. They do go slower in cold weather, but they still work. The Makitas are just as reliable, but those are the only brands I have experience with in the mini category. I use the Milwaukee 12 volt stuff most of the time, because of the compact size. Otherwise my C12 or my 18 volt tools.
Dovetail65
Offline
« Reply #12 on: August 26, 2010, 07:57 PM » |
I love my Makita mini's two for 99.00 and I can leave them for months and not charge them and they take a charge easily. I mean what do you want, they are not useless I never had a situation they didn't work. If the task is to tough I just pull out my Panasonic. I just don't get the 500.00 cordless drill thing. Believe me I drop big coin on a lot of tools, probably more than most, but a drill/screwdriver? Not for me. The bits and screw tips are far more important than anything else.
« Last Edit: August 26, 2010, 08:01 PM by nickao »
Frank-Jan
Offline
« Reply #13 on: August 27, 2010, 04:24 AM » |
hi chrippler.
justin.
The bosch lithium ion batteries have protection built into the battery, so it will just shut down completely to avoid damage to the batteries, instead of gradually becoming weaker. But mostly manufacturers claim it shouldn't harm battery life if you charge the Li Ion batteries sooner. @ WarnerConstCo.: You could get the flashlight for the bosch batteries, I personally like it a lot, it's fairly compact, rugged, has a belt-clip and is very bright. Since the tool is gathering dust, this way you can at least put the batteries to use.
« Last Edit: August 29, 2010, 04:49 PM by Frank-Jan »
WarnerConstCo.
Offline
« Reply #14 on: August 28, 2010, 05:41 PM » |
The flash light is in the case gathering dust as well.
GhostFist
Online
« Reply #15 on: October 09, 2010, 10:01 AM » |
I use a Bosch mini 12v daily. It drives slower than standard sized drills but is ultra portable and great to have in your pouch as opposed to looking for where you left your 18 last. If I have to do any ladder work it's the perfect size. I've never been a fan of belt hooks for drills as I find they snag on things.
For a smaller sized drill its got some decent power I recommend! The millwaukee is also nice, good to have a battery indicator, something not present on the Bosch. I find the Bosch batteries charge quick enough that it's not really an issue though.
aloysius
Offline
« Reply #16 on: December 06, 2010, 03:42 AM » |
What about Metabo's version. Their cordless tools are as good as most others on the market: perhaps not as high tech as some (panasonic et al), but they're usually very robust, and have premium quality accessories, chucks etc. They also have the industry's best warranty: 3 years on both the tool AND batteries, even for pro use! Now that's confidence!
Pete Pedisich
Offline
« Reply #17 on: December 06, 2010, 11:18 AM » |
I find the quick-change hex bit holder on the Bosch does not hold most bits tightly. Most of mine, from McFeelys, HD, etc...have too much wobble when fully seated. A good bit more than my Panasonic 12v impact gun. This means drill bits of any length wobble unacceptably. 2" screw-driver bits are not a problem, and since that is 90% of what I use it for, it has been the drill I reach for first. Maybe on the newer version with 2 speeds they have fixed this. I have tried the Makita version and it seemed better in this regard.
jmbfestool
Offline
« Reply #18 on: December 06, 2010, 04:02 PM » |
EdL
Offline
« Reply #19 on: December 08, 2010, 12:48 PM » |
I think your results will be much different if you did that with the newer Bosch PS41 impact driver. I've got both the PS40 & PS41, there is no comparision between the 2. My PS40 doesn't get used much anymore.....
Ed
jmbfestool
Offline
« Reply #20 on: December 08, 2010, 04:22 PM » |
Ed
Seen as u have both can you do a video comparing both? Prove to me its a lot better. Jmb
EdL
Offline
« Reply #21 on: December 09, 2010, 11:03 AM » |
I can time them....but thats it. No way to do a video.
Ed
EdL
Offline
« Reply #22 on: December 10, 2010, 12:31 AM » |
Well, I borrowed a camera with video, I tried, just not good enough to run an impact with each hand and not have one blow off the screw, sorry. Next time I'll use hex head screws, harder to screw up. FWIW, I ran all I had, used the 'ol onethousandone, onethousandtwo count routine..... Material: 2 pine 2x4's clamped to the bench Screws: #9x3" long, no pilot hole, started by hand, appx 1/4" (6mm) in Results: Bosch ps40, 10 seconds Bosch ps41, 5-6 seconds Milwaukee M12, 8 seconds Old DeWalt ni-cad, 12 volt, 4 seconds Just for shrits & grins, Bosch ps21, 7 seconds. Maybe I can get a compentent assistant, try the video thing again. Pathetic as it my be, I did upload my attempt. Ed
Alex
Online
« Reply #23 on: December 10, 2010, 04:25 AM » |
But you can't compare drills to impact drivers. JMB compares two drills of two different brands. It's no use to mention impact drivers in relation to this.
Frank-Jan
Offline
« Reply #24 on: December 10, 2010, 06:14 AM » |
The ones JMB compared are impactdrivers aswell.
jmbfestool
Offline
« Reply #25 on: December 10, 2010, 06:51 AM » |
My video shows two impact drills of different brands not drills. I have used the little Bosch drill it's even worse than the impact impact Bosch I am using in the video if I can get hold of it again I'll do a video of that aswell. The makita drill isn't very good either it drains the battery very quickly and has no power really. That's why I didn't bother with the drills they rnt even worth taking out of the box. Jmb
Ken Nagrod
Restricted
Offline
« Reply #26 on: December 10, 2010, 07:11 AM » |
JMB, I'd like to see you do a video comparison between two Yankee screwdrivers with those same screws.
Festoolfootstool
Offline
The trouble with Bob is its all about Bob
« Reply #27 on: December 10, 2010, 07:33 AM » |
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Alex
Online
« Reply #28 on: December 10, 2010, 01:18 PM » |
Oops, my mistake.  Dunno why, but I thought they were drills.
jmbfestool
Offline
« Reply #29 on: December 11, 2010, 09:11 AM » |
JMB, I'd like to see you do a video comparison between two Yankee screwdrivers with those same screws.  Trust u 2 come out wiv a silly comment  I'll think I'll pass on that any way lol Might do festool t15 vs something I own as you know the small Bosch and makita impact and small makita drill Also milwueakee m18 impact and drill Jmb
