Zacharytanner
Offline
Location: Upstate New York...Adirondack Mountains Member Since: Nov 2009
« on: May 26, 2012, 02:44 PM » |
Hi Guys, My old Stihl 031 was laid to rest today and in the middle of 5 Cedar trees I was taking down along my driveway...Well I had to go buy a replacement and went with the Stihl 290 as I use in for yard work and fallen trees on my property. Seems like a good little saw. I have a 16 in bar and it worked nicely. Any of you guys using this saw and what are your likes / dislikes.... Usually I ask B4 buying but no time today as it is a holiday weekend and my local dealer is closed Sunday and Monday.
Thanks, Frank
Festool Kapex KS 120EB w/ 4 Blades Domino DF500 Set Domino DS Systainer 4,5,6,8,10 TS55 w/ FS1400 and FS2700 Rails MFT/3 with Accessories CT33E D36 Tradesman Trion PS300 Jigsaw RTS 400 EQ Orbital Sander RO 125 125 Abrasive Systainer with , 60,80,100,120,220 Grit Festool paper 2 Systainer Carts Festool T18+3 Kit CXS Kit with Centrotec Wood Bits ETS 150/3 150 Abrasive Systainer Festool Toolie RO 90 RO 90 Abrasive Systainer OF 1010 Router
Frank
RonWen
Retailer
Online
« Reply #1 on: May 26, 2012, 03:02 PM » |
You can't go wrong with Stihl.
Zacharytanner
Offline
« Reply #2 on: May 26, 2012, 03:14 PM » |
Side note..... My old saw was so old it didn't have a chain brake and I have never used a saw with it...I like that feature
Frank
Frank
tjbier
Offline
« Reply #3 on: May 26, 2012, 08:48 PM » |
The 029/MS290 is a good saw, also Stihl's most bought one due to it's price point. With proper care it will last you many years. It is a "calmshell" motor, meaning the jug doesn't come off the crank case you have to split the case to rebuild the saw (new piston, rings, crank bearing ect.). That is the saws downside, but like I said take care of em and they will go for a long time ! Congrats on new tool day
Tom- ps, I read these.
Tim Morris
Offline
« Reply #4 on: May 26, 2012, 10:16 PM » |
My 290 is about three years old. My only real complaint was the weight when topping stuff out so it's 180 "little brother" is only about a year and a half old.  You can never have too many toys tools. Seriously they are a great pair. I own several other Stihl products no complaints what so ever.
General Contractor
Kevin Stricker
Offline
« Reply #5 on: May 27, 2012, 12:00 AM » |
I have a MS361 that has seen quite a bit of use in the last 4 years I have had it. Easy to maintain and reliably starts cold. Tough to clean pine sap/chain oil/ wood pulp once it has crystalized so I try to clean it up and sharpen the chain before I put it away. I have taken down at least 100 trees and also heat with wood so it was a good investment. Living in the mountains of Colorado on 3 acres means there is always some tree work that needs to be done.
Hoover
Offline
« Reply #6 on: July 15, 2012, 07:00 AM » |
Either Stihl or Husqvarna, you'll be fine. I have a Husqvarna 359. Great saw, lots of power.
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #7 on: July 15, 2012, 08:00 AM » |
My Stihl MS 192 C-E has worked out quite well for everything I've asked it to do.
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
NuggyBuggy
Offline
Location: Toronto, Ontario, Canada Member Since: Mar 2010
« Reply #8 on: September 24, 2012, 11:30 AM » |
You can't go wrong with Stihl.  Unless the Stihl comes with a flippy cap
“I am on a drug. It’s called Charlie Sheen.”
RonWen
Retailer
Online
« Reply #9 on: September 24, 2012, 11:41 AM » |
awdriven
Offline
« Reply #10 on: September 24, 2012, 11:56 AM » |
I assume you're talking about the recalled gas cap? I don't think that was used on any of the chain saws.
If we're talking about the same thing - Stihl sold a number of machines that came with a gas cap that had a little cam lever that would be used to seal the tank closed. Some parts of the original cap swelled or distorted so the caps became very problematic to operate properly. There was eventually a recall and Stihl replaced the caps with ones made of updated material. I had two affected machines that were fixed and the caps have since been OK.
Tim Malyszko
Offline
Webster Groves, MO
« Reply #11 on: September 24, 2012, 09:15 PM » |
I have the updated caps and still hate them, especially on the backpack leaf blower. Too often I think it's closed and latched just to nice it fall off and spill gas down my leg. Other than that, I LOVE my Stihl tools.
Stokely
Offline
« Reply #12 on: September 25, 2012, 01:08 AM » |
My Stihls are great machines. I've got two chainsaws and weedwacker, two of them are 10 yrs old. But I've had to replace gas caps as well as bar chain oil caps on them. Plastic parts mind you. That said, I can't replace body parts but I'm confident in the saw's ability to handle the trees/wood I throw at it.
NuggyBuggy
Offline
« Reply #13 on: October 08, 2012, 09:43 PM » |
I have the updated caps and still hate them, especially on the backpack leaf blower. Too often I think it's closed and latched just to nice it fall off and spill gas down my leg. Other than that, I LOVE my Stihl tools. I asked my Stihl (Canada) dealers about the recall and they said there was no such thing...perhaps it is a US thing. Like Tim, I have spilled many a liter of gasoline from my backpack blower (BR600) thinking the darn cap was closed. I dread refilling it because after opening the fuel tank, I know I will be spending 5-10 minutes sitting on the ground trying to get the cap closed properly... and when I do, I am never really sure how I did it, just that I don't dare trying to do it again. I've got two other Stihls (a weed whacker and an MS250) that have a different style of flippy cap and never have a problem, as well as two big 076es that have old-style caps and hence never have a problem like that either. If one goes to arboristsite.com you'll find that the Stihl flippy cap is sort of a running joke.
Peter Halle
Global Moderator
Offline
« Reply #14 on: October 08, 2012, 10:14 PM » |
I can attest to the fact that there was a recall here in the US for the cam action caps. I got a replacement for mine.
SRSemenza
Global Moderator
Offline
« Reply #15 on: October 10, 2012, 11:59 PM » |
Yup, me too on the recall. I have a 260 saw and a trimmer, both purchased about the same ti me. The recall only came through for the trimmer.
Festool Service 800-554-8741
