Author Topic: Woodpecker Rule Stop and Ruler Combo  (Read 8122 times)
Offline OXCanada
« on: January 01, 2017, 09:52 PM »
Hi - I am looking for a way to quickly and repetitively mark out mortises and tenons as well as other layout marks for furniture building.
I was thinking about getting the woodpecker rule stop and ruler to do this. That way I can mark using the end of the rule for a depth stop marking and the sides of the ruler as well. Right now I use a combo square to do the majority of my layouts.
Anyone have any experience with these or any suggestions for the best tool for the job?
Offline neilc
Re: Woodpecker Rule Stop and Ruler Combo
« Reply #1 on: January 01, 2017, 10:04 PM »
I use their Paolini stainless 6" ruler.  It's one of my favorite tools.  Great for marking mortises or setback gaps for many woodworking tasks.  ideal for setting the guide rail a consistent distance from the edge of a piece of wood as well.
Paolini Pocket Rule - 6"/150mm Aluminum
Shipping Nov 2016.
$32.99
It's a one-time tool, but suggest you call Woodpeckers as they often have some available.
neil
Online RobBob
« Reply #2 on: January 01, 2017, 10:15 PM »
Offline lunchman
« Reply #3 on: January 02, 2017, 09:54 AM »
If you can find them (they were a Woodpecker OTT), their T- squares would be ideal.
http://www.woodpeck.com/ottonepctsquare.html
I have the TS-3 and TS-6 and find that I use these constantly, especially when marking lines for Dominoes. I also find I make use of the holes quite often to scribe layout lines.
Offline PreferrablyWood
« Reply #4 on: January 08, 2017, 08:18 AM »
I'm going Starrett 100mm double square, 150 combination and 300 combination squares for that type of work.
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline OXCanada
« Reply #5 on: January 09, 2017, 12:49 AM »
Thanks everyone!! Appreciate the info
Offline them700project
« Reply #6 on: February 15, 2017, 03:02 PM »
Ive been using this for such things I got the 6" one
Offline ben_r_
« Reply #7 on: March 08, 2017, 05:52 PM »
I use this:
Czeck Edge Ruler Stop
plus this:
Sterling Combination Square Rulers (scroll down)
That stop looks just like the Woodpeckers one.
