Author Topic: HAMMER A3-31 mobility back saving setup  (Read 2128 times)
Offline TomGadwa1
« on: July 04, 2014, 05:25 PM »
This is my setup to eliminate the poorly executed johnny bar setup that HAMMER thinks is a mobility solution. Not only dose the johnny bar have poorly executed geometry on the design for maneuverability but it also is very stressful on ones back whilst trying to situate the unit in the shop. Therefore after after using the johnny bar and stressing my back each and every time I used the darned thing I came up with what I feel is a definite improvement. I will admit that SAWSTOP's professional base inspired me to use a hydraulic lift, thus the use of a bottle jack I had laying about. A few cranks of the lever and the HAMMER is safely raised into a position such that it can be moved with little if any stress to the woodworkers back!!! Once in position the valve on the bottle jack is opened and the HAMMER comes down for use on its stable feet and back wheels. When done with the unit it is easily raised once more for movement to its stowage area. Of course I should mention that I used my Domino 500, CXS, T15 and KAPEX in the construction of the lift mechanism.
http://www.youtube.com/watch?feature=player_detailpage&v=X-Pe_fLMY0s
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Offline Picktool
Re: HAMMER A3-31 mobility back saving setup
« Reply #1 on: January 01, 2016, 07:42 PM »
@TomGadwa1 , is it possible you have some closeup pics etc of that lifting setup?
Are those footmaster wheels? Looking to do something similar when I get
me hammers come march. Should be able to move the K3 also right?
Thanks  :o
Well Dogey
Offline ben_r_
« Reply #2 on: January 10, 2016, 12:15 AM »
Nice! How about some drawings or plans on how you built it!?
