Author Topic: HVLP - 3-Stage or 4-Stage  (Read 7649 times)
« on: May 22, 2010, 08:12 AM »
« Last Edit: March 10, 2013, 11:19 AM by sawdustinmyshoes »
Offline dsweetser
  • Adirondack, NY USA
Re: HVLP - 3-Stage or 4-Stage
« Reply #1 on: May 22, 2010, 11:57 AM »
I purchase the 3stage Fuji. I am very pleased with it's performance. I have sprayed latex thinned with flotrol, oil based thinned with paint thinner, which I am painting a cedar square picket fence. It's great getting in behind the rails & gate X bracing. I have sprayed water based General Finish with good results. I do need more practice, but well worth the investment. I did purchase additional tips, #3 & #5. Good luck. Don
Don
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #2 on: May 22, 2010, 04:28 PM »
I have the Fugi Q4, would would never conceder anything less than a 4 stage. My next choice would be the Apollo but nothing smaller than their 1025.
For latex paint an HVLP system is not the best answer, with a pressure pot they are not to bad but still not the best way to go. If you do get a pressure pot get a 2 gallon minimum, that way you can just insert a 1 gallon can in it. You do not have to clean the pot as the paint stays in the original vessel.
I have all of the Fugi tips and you still need Floetrol to get it to layout properly.
I much prefer a pressurized gravity gun, easier to clean.
For latex an air assisted airless pump (very costly currently) or a conventional airless is your best bet. If you only need to spray latex once in a while you may want to conceder renting or buying a small airless.
The gun is the most important part of the system, the better the tips and gun the better the finish.
Here is a pretty extensive thread from JLC on the subject of sprayers;
http://forums.jlconline.com/forums/showthread.php?t=48892&highlight=hvlp+spray+guns
Offline NVA_WW
« Reply #3 on: May 22, 2010, 04:39 PM »
The new Fine Homebuilding has an article about exterior painting.  Compares sprayers and doing it by hand.  I just got in the mail about 2 hours ago, so I haven't read it.  If you plan to paint exterior stuff like a fence and deck, I would not go with an HVLP.  I have the Fuji Q3 for furniture and I absolutely love it.  I've done everything from shellac to milk paint (General brand thinned by about 10%).  I'll post an update when I read the FHB article.
Offline aga
« Reply #4 on: May 22, 2010, 08:20 PM »
If you decide to go with Fuji gravity new style gun and 3M PPS, the right angle adapter is #24.
I purchased my gun from Roger Phelps (highly recommended) but he does not sell PPS system. Purchased mine from TCP Global. #24 adapter was about $20. You will need a pressure cup and liners. I went with mini pressure cup. If you need part numbers I can most likely find my invoice and advise.
Offline HowardH
« Reply #5 on: May 23, 2010, 08:58 PM »
+1 on Phelps Refinishing.  Great service.  Love my Q4.  Highly recommend the gravity gun as well.  The regular 1 quart gun gets in the way a lot.
Howard H
mft1080, Trion, MFT/3, T15, OF 1400, RO150FEQ, TS55, RTS400, CT22, CT36E, 800, 1080, 1400, 1900 rails, CSX, Vecturo, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE
