Author Topic: JESSEM Table Saw Miter Gauge  (Read 14874 times)
Offline ChuckM
Re: JESSEM Table Saw Miter Gauge
« Reply #60 on: June 11, 2019, 11:08 PM »
In the sawblade manufacture thread, a sawblade video is shared. I noticed that the sacrificial fence on the mitre gauge was installed on the end of the gauge, not on the face. I will study it further to see if it is a better way of attaching a wooden fence for the mite-r ii when received.
Offline gary_va
« Reply #61 on: June 12, 2019, 08:09 PM »
...the sacrificial fence on the mitre gauge was installed on the end of the gauge...
This intrigued me so I took a look. Turns out the wood end-piece is not sunk into the blade. It's odd shape suggests it served some other purpose and they just leave it installed.
299003-0
Great video nonetheless, 'How It's Made' grabs like 315 hide glue and they're extremely addictive!
FYI - in Youtube videos, "spacebar" and/or "K" on your keyboard will Pause and "<" and ">" (don't press shift) step forward and backward frame by frame...very handy for analysis and screen captures.
Offline ChuckM
« Reply #62 on: June 12, 2019, 08:47 PM »
Thanks for the detective work, Gary.
I have yet to receive my Mite-R, and have no clue if such idea is good or even possible. If I have had any unusual findings, I will post them here.
Offline Mario Turcot
« Reply #63 on: June 12, 2019, 09:14 PM »
The Jessem Miter Gauge is built to receive a front sub fence. If I'm not wrong the t-bolts are part of the package. It is doable to put a end zero clearance but like Gary highlite with his picture there was a gap. Perhaps it's to prevent the sawstop safety to trigger?
Mario
Offline gary_va
« Reply #64 on: June 12, 2019, 09:40 PM »
...If I'm not wrong the t-bolts are part of the package...
They provide two 1/4–20 flat head screws (#3 Phillips) and two square nuts.
« Reply #65 on: June 13, 2019, 09:44 PM »
Thanks for confirming. I had a look at the manual and sacrificial fence part. The fence need to be 2" 1/2 high and between 22"-25" long. Do you thin it would be doable to extend that fence over the extension? I mean if you have a 3/4" fence, the extension is no more in-line with the fence. To rectify, one could simply add a small ~2" long mini fence to the extension. You think it's possible?
Mario
Offline gary_va
« Reply #66 on: June 14, 2019, 12:13 AM »
Quote
...one could simply add a small ~2" long mini fence to the extension.
Yes, one could engineer a gap-filler to align the face of the extension bar with the face of the 3/4" sacrif. wood.
Two design drivers are present:
1. The extension's square-nut channel is on the back side, not the front like the main fence
2. The gap is larger than 3/4" by the thickness of the extrusion plus a bit more; something close to an additional 3/32"
A three-piece design similar to the flip-stop seems viable. Even simpler would be cutting an extension-bar sized dado in a large block sized so you could slide the gap-filler over the extension bar wherever you wish.
« Reply #67 on: June 14, 2019, 04:57 PM »
Thank you Gary
Finally  [big grin]
Mario
Offline jellyroll
« Reply #68 on: June 22, 2019, 09:33 AM »
I continue to be pleased with their customer support. The miter gage arrived on schedule, assembly was easy, and I’m very please with both the design and the execution. They provide 4 small hex wrenches for assembly and if future adjustments are needed. There’s a tiny 3/32” hex wrench extender which is not necessary, but aids in  tightening and loosening 2 set screws.  They sent a part that appeared to be almost identical to the extension but actually must be a part from something else they manufacture.  I called them, they answered on the first ring, sincerely apologized, and two days later the correct hex extension arrive via UPS.  The correct part is the smaller diameter part in the photo.
« Last Edit: June 22, 2019, 09:41 AM by jellyroll »
