Author Topic: Laguna 14 SUV Precision Pro Fence Mount  (Read 1804 times)
Offline TomGadwa1
« on: May 28, 2018, 07:27 PM »
A long time ago I purchased a Laguna Driftmaster fence. The fence itself is quite robust and very accurate as well. However the mounting system that Laguna included with the fence looks crummy and is difficult to set accurately. Therefore I was inspired to design a superior mounting system for the Driftmaster. Thus was born the Precision Pro Fence Mount. It is fabricated out of 3/4 inch thick aircraft type 6031 aluminum and anodized blue to match the other anodized parts on the saw. It has elevation adjusting set screws that facilitate the setting of the fence to be perpendicular along its full travel across the table of the saw. It is super stable and looks tons and tons better than the stock mounts that came with the fenceDriftmaster Link
« Last Edit: May 28, 2018, 10:15 PM by TomGadwa1 »
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Offline blaszcsj
Re: Laguna 14 SUV Precision Pro Fence Mount
« Reply #1 on: May 28, 2018, 08:22 PM »
Do you have pictures of the mod?
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline TomGadwa1
« Reply #2 on: May 28, 2018, 08:42 PM »
Click on the link at the end of the text for some video of the fence!
Offline firecycle
« Reply #3 on: December 07, 2018, 01:44 AM »
Where can I purchase one of these?
Offline TomGadwa1
« Reply #4 on: December 07, 2018, 09:06 AM »
It would be available through me. I have each one CNC milled out of the 3/4 inch aluminum. After mill work is done the piece gets anodized blue to blend into the styling of the Laguna 14SUV. I have been enjoying using my saw more than ever since I incorporated this into my unit!
Offline firecycle
« Reply #5 on: December 07, 2018, 11:46 AM »
I would love to have one, I simply cannot get the fence square...do you accept PayPal? Could you message me on here and I can get you my contact information?
Offline firecycle
« Reply #6 on: December 09, 2018, 02:40 PM »
How can I contact you to purchase one?
Offline TomGadwa1
« Reply #7 on: December 09, 2018, 07:47 PM »
Greetings sir! I can be contacted via email address: fsbtgjh@earthlink.net. My cell is 210-385-7538. The first thing to do is to measure the distance for the mounting holes on the table, it should be 16.50 inches on center. The support studs for the fence bar should be set to the distance of 15.75 inches on center. This is just to make certain that your saw and fence are the same dimensions as mine. Once that is verified the process can begin. Understand this is a custom made CNC milled piece of aircraft aluminum which is anodized for long service life, i.e. it ain't cheap!! If your still intrigued by the idea of a mount that can be accurately adjusted and that will hold that adjustment long term then let us proceed!
