Author Topic: Makita LS1019L miter saw mini review  (Read 34848 times)
Offline Duane Franks
Re: Makita LS1019L miter saw mini review
« Reply #60 on: June 25, 2018, 03:12 PM »
Does anyone know if Makita has addressed the blade tracking issue? There is a local supplier who has these on sale for $449 ($100 off) and I am looking at this saw as a possible addition to my shop. Thanks, Duane
Offline RKA
« Reply #61 on: June 25, 2018, 03:18 PM »
Nothing that I've read about yet.  Seems like it's in the hands of the end user for now.  Where is this local source?  I've been keeping an eye out for a friend in the market for a SCMS and haven't seen a price that good yet.
-Raj
Offline jpmeunier
« Reply #62 on: June 25, 2018, 04:02 PM »
Has anyone seen a zero clearance insert available for this saw? If not, I guess I need to make a template.
Offline JYip
« Reply #63 on: June 25, 2018, 04:28 PM »
I bought this saw recently. The table was flat and the fence was square. However, like most others, the bars that the saw head travels along are not parallel. I discovered this when I had a cut mark on a board and was lining the mark up with the laser line. As I pulled the saw head back towards me, I noticed that the laser line would move laterally relative to my pencil mark. The final cut was not square. I decided to just return the saw instead of trying to align the bars.
Hope this helps.
Jeff
« Reply #64 on: June 29, 2018, 07:53 PM »
RKA, Sorry for the late response. The local supplier is Jerry's Home Improvement in Eugene, Oregon. I think the price is good until 8PM pacific time today, but may be worth a call to their tool department @ (541) 689-1911.
Offline RKA
« Reply #65 on: June 29, 2018, 09:55 PM »
Thanks!  Your on the other coast but hopefully someone else can benefit!
-Raj
Offline tewic
« Reply #66 on: April 15, 2019, 06:43 AM »
I just got a LS1019L as well. Seems like Makita still has the same issue with the slide being slightly off, even though the blade is square to the fences, on new unites.
I've tried loosening the screws on part #169 as suggested, but I'm unsure on how I actually adjust the rails. With the screws loose (even tried screwing them all the way off), #169 is still as fixed on the rails, as with the screws tightned. I haven't tried applying more force, as I'm unsure I'm actually doing the right thing.
When the screws are loose, is #169 supposed to be adjusted to an angle, or pulled forward/backwards. Or is it the rails that should be pulled or adjusted to an angle?
Offline RKA
« Reply #67 on: April 15, 2019, 07:35 AM »
@tewic It take a bit of force to realign the rails.  Once the screws are loosened, slip a 1x2 between the rails and use that to twist the rails so to speak.  Which way?  Try one direction with a small adjustment and see if it’s better or worse, then you’ll know.
-Raj
Offline tewic
« Reply #68 on: April 15, 2019, 08:08 AM »
Okay, so the rails need to be twisted/adjusted in relation each other, and not both in relation to #169 or their mount on the back of the stand.
I actually thought it was the blade that was not square to the rails, and thus when you square the blade to the fences, the rails are not square to the fences.
Offline tewic
« Reply #69 on: Yesterday at 04:00 AM »
I did as @RKA suggested and it actually worked. After half an hour of trail and error it was almost spot on. Thank you so much!
One thing I noticed. When twisting it one way, if I twisted it slightly too far and wanted to twist it just a tiny bit back again, it was prone to going back to it's out of factory position. I'm curious to see if after some time of use, if it will slowly slip back to the misaligned position, or if the bolts on #169 will keep it in place.
