Paul Franklin
Offline
« on: March 02, 2011, 08:08 PM » |
Has anyone had a chance to play with Mirka Ceros sander yet.
I am looking for a new sander, my ES125 just gave up on me the day after the recon tool sale, go figure. And my RO125 is making some weird noises.
I know the Ceros is more money.
Cheers
Paul
Dan C
Offline
« Reply #1 on: March 02, 2011, 09:07 PM » |
I have had a chance to test them out. Great sander, if you have ever used pneumatic. The feel is so close and the control is outstanding. They can be aggressive or delicate depending on abrasive and settings. The best part, was the Mirka rep had them hooked up to his trusty Festool CT! Just a little odd to see that bright yellow systainer!
Paul Franklin
Offline
« Reply #2 on: March 03, 2011, 02:04 AM » |
Thats what I am interested in, I have not used an air sander, but the form factor looks comfortable.
Anyone else?
Cheers
Paul
Chris Has Flair
Offline
I make sculptural furniture.
« Reply #3 on: March 03, 2011, 02:33 AM » |
Gee, Paul. I just saw the ad in Fine Woodworking and came here to ask that exact question. It looks like the 125mm and 150mm CEROS sanders cost $499 while the RO125 costs $514.25 and the RO150 costs $635.25 (all Canadian prices).
I've used the Mirka discs previously and they work really well, even on my Makita with the stock pad. I like the low weight/balance point and the video shows some interesting features. I got a laugh at how at the end of the video they say to switch off the tool, switch off the transformer, unplug the tool, and unplug the transformer... all to change the disc!
Dan,
Do you recall if the Mirka rep had the sander hooked up directly to the CT, or was an adapter needed?
Dovetail65
Offline
« Reply #4 on: March 03, 2011, 02:34 AM » |
Wow, this model is expensive. http://www.amazon.com/Mirka-Compact-Electric-Random-Orbital/dp/tech-data/B004JUJ7SIIt looks really easy to grip. The more I find out about these the more I want to try one. * Half the size and weight of traditional electric finish sanders * Powerful brushless DC motor * Variable speeds from 4,000 to 10,000 rpm * Vacuum-Ready using multi-hole backing pads with hook and loop
« Last Edit: March 03, 2011, 02:41 AM by Dovetail65 »
Alex
Offline
« Reply #5 on: March 03, 2011, 06:34 AM » |
It is probably so expensive because it comes with its own separate transformer. The sander itself runs on 22 VDC so you can use it for wet sanding.
fdengel
Offline
« Reply #6 on: March 03, 2011, 07:35 AM » |
Gave up on you how? Do the brushes need to be replaced?
Alan m
Offline
« Reply #7 on: March 03, 2011, 08:44 AM » |
if you are happy with the festool i would send it in or give the guys a call. Shane has the numbers in his signiture.
junk
Offline
« Reply #8 on: March 03, 2011, 08:45 AM » |
Heard about these sanders a year ago and have been waiting for them to hit NA. The real nice thing is while they are expensive, the price is the same both sides of the border. Trying to arrange a demo.
John
Dan C
Offline
« Reply #9 on: March 03, 2011, 11:06 AM » |
Chris- It was hooked directly to the CT. As you can see in Dovetail's pic there is a round hose adapter, and that fit the standard CT hose without issues. It is really a great sander and the feel/comfort is the best electric sander I have ever used.
bionicus
Offline
« Reply #10 on: March 03, 2011, 11:26 AM » |
Just for clarification -- Does the adapter accept the rubber CT hose end, or do you need to thread it onto bare hose?
Dan C
Offline
« Reply #11 on: March 03, 2011, 11:55 AM » |
It used the rubber end- no modifications needed. Mirka intentionally made their Ceros work with other manufacturers dust collection (Festool specifically). Also no accident it is in a systainer.
jakiiski
Offline
« Reply #12 on: March 04, 2011, 04:54 AM » |
The local auto-paint shop had this and they let me try it. It was very low-profile, the Festool sanders are much taller. It's also VERY quiet with the smaller RPMs. The price delta in Finland at least with that one and the ETS 150/3 for example is around 75-100 euros, not more. Might be bigger in the US, but that's only because your Festools are some 30% cheaper than ours...
- J
billg71
Offline
Location: lost in the NW Atlanta 'burbs Member Since: Nov 2010
« Reply #13 on: March 04, 2011, 08:10 AM » |
Well I hope it's a great sander, I just ordered one...  First time I ever thought "Maybe I should save some money and buy a Festool.."  I'll let you guys know how it works. Bill
"Born to fish, forced to work..."
RonWen
Retailer
Online
« Reply #14 on: March 04, 2011, 08:56 AM » |
Well I hope it's a great sander, I just ordered one...  First time I ever thought "Maybe I should save some money and buy a Festool.."  I'll let you guys know how it works. Bill Okamisan in Japan has had one for several months and loves it -- that says a lot because he is very critical about the sanders he uses on his exquisite furniture. Not to speak out of place but he doesn't care much for the Festool sanders he's tried.
Eco-Options
Offline
« Reply #15 on: April 06, 2011, 04:13 PM » |
I am considering selling my ro150 to get a ceros. Does anyone here own both? I'm wondering if I'm doing the right thing or not.
I seldom use the rotex mode. I use the palm sander to make floor samplesnbut mostly it's used to remove edger marks prior to staining a hardwood floor.
I have carpel tunnel in both wrists and would love a powerful one handed sander.
Www.ecooptionshardwood.com
junk
Offline
« Reply #16 on: April 06, 2011, 04:57 PM » |
I had a 3 day demo of the 5" Ceros and if I could only buy one sander that would be my choice. I have a RO125 and ETS150/3 as my main sanders that I use every day. The Ceros in my opinion could replace the RO125 for aggressive and fine sanding. The ETS150/3 is still my favourite finishing sander, it was noticeably smoother than the Ceros 5". For some really aggressive sanding I put on some Abranet HD and did the old rough cut lumber to satin finish that you can do with the Festool RO's. I personally can't afford one right now but it's on my want list. Definite 9 out of 10.
John
Eco-Options
Offline
« Reply #17 on: April 06, 2011, 05:09 PM » |
Thanks for your insight.
Mirko
Offline
Location: Vancouver, British Columbia Member Since: Jan 2007
« Reply #18 on: April 06, 2011, 05:43 PM » |
I have the RO 125 and RO 150, recently I purchased the Mirka from Dan At Ultimate tools. I did some tests and found that there is a time and place for each, for example: When I sand veneer tape off panels, the RO will cut it off faster and leave a flatter surface, where as the Mirka will follow the surface. The Mirka seems to sand the areas beside the veneer tape first then once the tape is off, you are left with a faint wave on the panel. Same thing happens on a stile and rail door, the RO will flatten better and quicker, for final sanding and prep the Mirka, just out performs in both speed and quality, even the Abernet sand paper is much better, out lasting The Festool brand by about 5-10 times. Abernet keeps the cut/bite much longer. Once it is flat the Mirka is hands down better, no swirls and a very fast sanding speed, I can buzz 320 grit over a sanding sealer coat on a 24" x 16" panel in about 5 sec. with no trace of swirls anywhere on the subsequent coat. When using the Mirka, its as if you are using a air sander, very light, comfortable and lightning fast, although very quiet comparatively. Hope this helps.
jonny round boy
Offline
« Reply #19 on: April 06, 2011, 06:04 PM » |
Mirco, Is this behaviour a result of the hardness (or otherwise) of the pad, rather than the action of the sander? Would the Mirka do a better job taking off the veneer tape with a different pad?
Eco-Options
Offline
« Reply #20 on: April 06, 2011, 06:06 PM » |
Do you think changing the pad would help? Maybe a softer pad
Edit Beat me to it jonny!
« Last Edit: April 06, 2011, 06:08 PM by nehardwoodfloors »
Mirko
Offline
« Reply #21 on: April 06, 2011, 07:22 PM » |
I'll see if I can get harder pad. I checked both machines and they have about the same soft/hardness, I really think the RO series sanders have different mechanics, I have always compared them to beltsanders when in Rotex mode.
Mirko
Festoller
Offline
« Reply #22 on: April 07, 2011, 03:06 PM » |
I saw and held one at my loca dealer today and I am quite amazed how light and comfortable it felt. Especially for non horizontal work it must be perfect.
The fact that we live at the bottom of a deep gravity well, on the surface of a gas covered planet going around a nuclear fireball 90 million miles away and think this to be normal is obviously some indication of how skewed our perspective tends to be. -Douglas Adams-
Eco-Options
Offline
« Reply #23 on: April 08, 2011, 06:16 PM » |
Anyone know if the 8mm orbit ceros is going to be available in the u.s.?
bustedbolt
OfflineMember Since: Feb 2007
« Reply #24 on: April 15, 2011, 12:43 AM » |
I tried one at a trade show, and its got very nice torque. nice power. VERY VERY VERY smooth feel. I just love every brushless motor I used. like a turntable playing a record. I thought the festool was as good as it gets but was wrong.
However the power inverter crap is just a little too big to want to bring it along to jobs. hence, keep the 150ets.
Also I immediately noticed that the hose outlet is so low (whole thing is shorter than the ets150) that the hose gets caught up on the edge of anything you are sanding. the extra height on the festool is more mobile. I guess you might just get used to it and adjust.
m hamlyn
Offline
« Reply #25 on: May 01, 2011, 11:31 PM » |
I just bought one of Friday and just love it! Light weight, quiet and very powerful. I hooked it hook up to my CT22 and almost zero dust. I was looking at an RO 125 and I have to say I'm so glad I pickup this.
Chris Has Flair
Offline
« Reply #26 on: May 03, 2011, 01:08 AM » |
I've got the 6" Ceros and have used it for a few hours so far. In the past, I've rarely used sanders so perhaps my expectations are unrealistic, but I've been experiencing more vibration than I expected (using 100-180 grit). How are the ETS sanders for vibration? Are any random orbit sanders actually vibration free or close?
Kevin Stricker
Offline
« Reply #27 on: May 03, 2011, 02:47 PM » |
What speed setting are you using it at. I find the top speed gives some vibration but the others are great. Top speed has similar vibration to a Rotex but is much easier to handle. The ETS 150/3 probably is a bit smoother, but at it's top speed it is only comparable to mid range on the Ceros as far as effectiveness.
While i have only been using mine for a week I believe that in mid grit ranges ( 80 - 220) it blows the Rotex out of the water. It is much easier to handle so you can be very precise with stock removal and it glides over the surface in finish sanding. I was balancing it on a 7/8" face frame and using it on vertical panels to remove stock, two things that would be very challenging to do with my RO125 without some dishing or edge rounding. At the top two speed settings it really is similar to a rotary mode sander, when you turn it off you can see the pad spin for a long time. While I have not done any polishing yet I am sure it is up to the task.
Dust extraction is comparable with a Rotex, you will get some spin off at top speeds. It seemed my ETS150/3 had better extraction, but it was doing the same work in twice the time. I sold it to buy the Ceros and am not disappointed in my decision. Now I just have to test the Ceros at finish removal with lower grits, if it passes that test the RO125 is going up for sale as well.
Chris Has Flair
Offline
« Reply #28 on: May 03, 2011, 04:29 PM » |
Hi Kevin,
I have been using the Ceros at top speed. I will try dialing it down.
One neat thing I learned by accident is that the sander can be used to create a faceted surface much like that left by a block plane when rounding over an edge. Very cool!
Alex
Offline
« Reply #29 on: May 03, 2011, 04:42 PM » |
Hehe, NO WAY!
