Author Topic: Nova drill press  (Read 7716 times)
Offline Rollin22Petes
Nova drill press
« on: July 30, 2017, 07:20 PM »
Can somebody who has one of these tell me how tall it is. I have searched but can't find it's height I'm going to buy one and have a upper cabinet I need it fit under Thanks.
Offline jbasen
Re: Nova drill press
« Reply #1 on: July 30, 2017, 08:03 PM »
The drill press is 70" tall.  I think you will really like it.  Powerful, very quiet, and I now have the discipline to change the speed depending on the drill bit and wood because it is sooooo easy!
« Reply #2 on: July 30, 2017, 08:58 PM »
Thanks a lot. It really came down to the Nova or Powermatic. The Powermatic gets mixed reviews at almost the same price but the only negatives I heard of on the Nova was it's very low audible beep and not being able to take small diameter bits. Neither is of much concern to me plus the Nova has a lot of added features over other offerings in the same price range.
Offline jbasen
« Reply #3 on: July 30, 2017, 09:10 PM »
The beep volume is definitely an issue.
My plan, when I get around to it, is to purchase one of these from Lee Valley to take care of the issue of not being able to handle small drill bits
http://www.leevalley.com/us/wood/page.aspx?p=75987&cat=1,180,42334
Hope this helps
Offline Bob D.
« Reply #4 on: July 30, 2017, 09:42 PM »
Hope this helps
I have been debating over the Nova or the PM2800b also. Both are available at my local Woodcraft and are on display. The Nova is shorter than the PM. The table is not as nice for woodworking as the PM table, no so easy to replace insert is a concern for me. Yes it can be replaced but PM has a square piece of Masonite or MDF that you can make a couple dozen from scarps, the Nova is round and a little more work to make or you have to buy them. Might seem minor but still. The PM comes with a fence the Nova does not.
There are some reviews on the Teknatool site worth reading. Every one of them complained about the low volume of the warning beep and that the chuck will not tighten up on anything smaller than a 3mm bit. I think I'm going to give it some more time and see if the competition comes up with anything to challenge Teknatool. So far no one has brought out a lathe like the DVR-XP. I've had mine for about 6 years now and love it.
http://www.teknatool.com/product/nova-voyager-dvr-drill-press/
Online online421
« Reply #5 on: August 02, 2017, 09:35 PM »
A woodworking store near where I live (2 mile) has the Nova drill on display.
Its a nice drill if you do a lot of repetition work.
Griggio Unica400
Felder AD951
Masterwood OMB1V
SCM 5 RCS1100
Casadei FV110
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, CT36, LEX3
JLT 190BM2, JLT 79K10
Danfoss VLT 2880
Sicar TOP6
« Reply #6 on: August 02, 2017, 11:28 PM »
That's so true!
I've been using the Nova DP to drill hundreds of holes in aluminum and tapping many of them.
The features I use the most are the function keys that instantly change speeds and the digital depth stop.
While the Nova DP is supposed to have a tapping function (one of the main reasons I bought the machine) in my experience it only works correctly about 10 percent of the time. But when it does it's kind of a miracle it's so cool.
The basic features of the Nova DP can be used as a work around for the flakey tapping feature. I simply set the digital depth stop and at slow speed the tap stops instantly when the quill has traveled the specified distance. I have set one of the function keys to be a forward/reverse switch and when I touch that key the tap backs out.
I did upgrade the machine with a keyless chuck and a cross slide milling table. The chuck allows use of a wrench to tighten taps enough to withstand reverse motion. It holds smaller bits than the standard chuck. I also swapped the long table elevation crank for a wheel. It makes changing the table height swifter and smoother.
With the above very productive setup I was able top complete the project myself. With any other DP I would have had to sub-contract much of the work which would have cost more than the Nova DP cost.
Offline egmiii
« Reply #7 on: August 03, 2017, 12:22 AM »
Would you mind sharing a link to the replacement chuck? Seems to be a common complaint and many might find your suggestion useful.
Offline Bob D.
« Reply #8 on: August 03, 2017, 04:32 AM »
I'd be interested in the handwheel info in addition to the chuck you chose.
« Reply #9 on: August 03, 2017, 06:55 AM »
I think this is the keyless chuck I have.
I bought a  zinc hand wheel from McMaster.
 If the link doesn't work it is 6" in diameter with a 1/2" un-threaded hole. The hub had to be drilled larger to fit the stub. The stub is poorly formed and not an exact size. I used a fractional bit (can't recall size) to make a tight fitting hole. I didn't secure the wheel well enough when drilling and the hole became ragged but that maybe improved the fit. With the help of a hammer the soft zinc was moved out of the high spots resulting in a very good fit.
« Last Edit: August 03, 2017, 07:01 AM by Michael Kellough »
« Reply #10 on: August 03, 2017, 11:12 AM »
Here's another keyless chuck option...Albrecht. They come in a number of sizes and mounting configurations. Some have diamond coated jaws to bite into hardened tooling/shafts.
No matter what make the chuck is, you'll also need a pair of wedges to remove the chuck. There's a minimum drill size for all keyless chucks, usually around 1/16" diameter. So if you're using a drill smaller than that, you'll have to remove the keyless and replace it with the keyed chuck.
The removal wedges are purchased for whatever Jacob's taper is needed. The 2nd picture below shows #3 wedges above the Albrecht keyless, while #2 wedges are lying on the drill press table.
« Last Edit: August 04, 2017, 09:47 AM by Cheese »
« Reply #11 on: August 03, 2017, 11:20 PM »
The LLAMBRICH chuck has an integrated shank so you just use the simple triangular steel piece included with the DP to strike the top of the shank through a slot in the quill.
Offline Bob D.
« Reply #12 on: August 04, 2017, 05:47 AM »
Hmmm, I wonder would my SnapOn tie rod end fork work?  [blink]
JK, it hasn't seen use in a number of years and was just trying to justify
its existence in my tool chest along with my other outdated or obsolete
automotive tools. Ya know, stuff like the special Ford upper control
arm adjusters for doing front end alignments, only needed for early 70s
Fords, Mercurys, and Lincolns or a fan belt tension gauge.  [unsure]
Offline abates
« Reply #13 on: September 04, 2017, 08:55 AM »
I bought the nova on a whim and while it is a very nice drill press, I think the depth stop feature is oversold.  First let me say, I love how quiet it is. And the power is nice. I use the speed setting frequently now.  I never did like to change the belt on my old DP.   Mind you it is not a metal working drill press, but it has enough power for what I do (professional woodworking). Also, it has virtually no run out.  That part is impressive.
Now for the depth stop.  I can't even hear the beep.  But honestly, since the press stops itself, the beep may be redundant.  However, the press stopping itself is really annoying.  I haven't figured out how to start it back up in reverse so generally the bit is stuck in the work piece unless I clamp it down, which of course kills the productivity of the feature.  I don't know, perhaps it is nice, I guess I don't see the difference between that and the old manual depth stop.  I would buy it again, if for no other reason that the sound level, the zero clearance to a wall, and the direct drive.  I always prefer direct drive on anything.
« Reply #14 on: September 04, 2017, 11:19 AM »
These 2 items are directly from the manual, maybe they'll help out unless you've already tried to work with them.
 Sounds/Warnings – This toggles various sound settings.
 Set Depth Reached – List of actions for the user to select from on what to do once the set depth has been reached.
If these don't help, I'd suggest you contact Teknatool directly. As this drill has a tapping feature that allows it to reverse just like a Tap-Matic would, there must be some way of enabling the reversing feature to work with the depth sensing feature.
Support:
http://www.teknatool.com/support/#
Manual:
https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/19001497568/original/833%20Voyager%20Drill%20Press%20Manual%20FINAL%20version%208.Nov.2016.pdf?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJ2JSYZ7O3I4JO6DA%2F20170904%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170904T145914Z&X-Amz-Expires=300&X-Amz-Signature=25ffbdbb378b763a7cf5b59b4224956e5ac3d128745ba8e61dadbc0e0032d270&X-Amz-SignedHeaders=Host&response-content-type=application%2Fpdf
Offline Bob D.
« Reply #15 on: September 04, 2017, 10:06 PM »
When I emailed Nova about the audio level they said they were
looking into increasing the volume level but no promises or any
estimate of when or if it would happen.
I have mixed feelings about the motor stopping once the set depth
is reached. As you noted this could leave the bit jammed in the
workpiece and could lead to damage to the work withdrawing the
bit. At the least it may be a hit on productivity.
Now if you could program the depth and the DP automatically advanced
until the set depth was reached then withdrew the spinning bit you'd really
have something. But that would probably be another $500 on the retail price.
I remember working in a pipe fab shop in the late 70s we had a big DP which
you could set it to advance the bit and stop by itself. You had to set the depth
stop manually and as the quill advanced it would contact the stop lever which
caused the quill to raise up and the drill motor would stop once it was fully
retracted. I don't remember who made it but it sure beat pulling on the handle
all day drilling 7/8 anchor bolt holes in 1" plate for pipe supports. The Buffalo
punch was more fun for banging out a big batch of holes.
« Reply #16 on: September 04, 2017, 11:14 PM »
That's the reason I suggested that the OP contact Nova. This drill press operates 80-90% of the time on the response from software.
It understands reaching and acknowledging proper drill depth, it also understands automatically reversing the spindle when a limit has been identified. Consequently it's relatively easy to connect the 2 functions to produce the desired result. They'd be fools to charge $500 for this simple functionality.
« Last Edit: September 04, 2017, 11:46 PM by Cheese »
« Reply #17 on: September 05, 2017, 08:47 PM »
Instead of watching the drill spin into the work watch the depth display and just stop advancing when you get to your depth. You do have to properly "zero" the right part of the bit to the work before you start.
Offline Bob D.
« Reply #18 on: September 05, 2017, 09:50 PM »
That's how I do it now. I wouldn't like the bit to stop turning at the bottom of the hole.
Offline abates
« Reply #19 on: September 30, 2017, 10:15 AM »
So I figured ou the reversing mode of the depthstop feature.  Even still, the bit stops at the bottom of the hole (and not instantly, but runs down if you know what I mean).  But the reversing feature helped out quite a bit.
« Reply #20 on: September 30, 2017, 10:21 AM »
So the drill doesn't just come to a halt, rather it slows down and then reverses direction, is that correct?
Offline abates
« Reply #21 on: October 02, 2017, 09:41 AM »
Yes that is correct. of course that means that you can overshoot the depth if you are not watching the digital readout.
« Reply #22 on: October 02, 2017, 03:25 PM »
This DP does requires a small behavior adjustment on the part of the operator.
Just watch the digital depth readout, something not possible on any many other DP's.
On the other hand, just like nearly all other DP's, there is a mechanical depth stop so you can use that instead of watching the DRO. But, like nearly all other DP's the mechanical stop is crude.
« Reply #23 on: October 03, 2017, 09:16 AM »
I'll go along with that, the only drill presses that I know of that actually have a decent depth stop is a Clausing 15/20 and a Powermatic 1200/1500.
Offline bkharman
« Reply #24 on: October 03, 2017, 09:01 PM »
I looked at (and played with) the Delta 18‑900L and it has a really, really nice depth stop system. Hard to explain, but it has above and below stops and each are micro-adjustable. It, and the Nova are tops on my list. Still haven’t pulled the trigger but both are nice machines.
Oh, and the rubber band swapping for speed changes is also dirt simple on the Delta. It is the only one that I thought was easy.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline Bob D.
« Reply #25 on: October 03, 2017, 09:04 PM »
Those nuts used on the Delta and other make DP depth stops are available rom McMaster-Carr.
Also from Grizzly for a lot less:
http://www.grizzly.com/products/Quick-Threaded-Stop-Collar-3-8-16-/G7317?utm_campaign=zPage&utm_source=grizzly.com
« Last Edit: October 03, 2017, 09:17 PM by Bob D. »
Offline bkharman
« Reply #26 on: October 03, 2017, 09:06 PM »
Thanks Bob. I figured they might be but the Delta stop plate was about the most robust I had seen. I am sure the combo makes for a quality “true” stop.
Cheers. Bryan.
Offline ben_r_
« Reply #27 on: October 06, 2017, 11:51 AM »
Thats not the same as the depth/height stops that came on my Delta. Those dont look nearly as solid or nice looking. See attached image.
Offline Bob D.
« Reply #28 on: October 06, 2017, 11:07 PM »
I agree. I have seen the stop nuts on the Delta and like them.
The ones I pointed to are similar but not as nice, same for the
Grizzly variants.
Years ago I made a crude one from a shaft collar that fit my DP
and a thumb screw in place of the set screw. It works and is
fairly quick to adjust, and no complaints since it came from
parts in the junk box.
« Reply #29 on: December 25, 2017, 05:09 PM »
Well it took me a little longer than I thought but I finally got the Nova drill press about a month ago and on sale so I guess the wait worked out. So far I have really enjoyed using the drill press but I noticed the other day my shop radio won't work correctly with the drill press plugged up they are on the same circuit. Not really a big deal I can move the radio to a different location and use another circuit just seems odd to me have any of you guys had similar issues whether it was a radio or some other device. I'm guessing it has something to do with the electronics within the drill press.
