Author Topic: Poor Man's Hammer Finger Board  (Read 3105 times)
Offline patriot
    • Wood Working By Design
« on: August 23, 2017, 10:55 PM »
I got myself in a situation where I had to have a finger board for my new Hammer and this is what I came up with. Actually, the finger board proper was not the issue, how to attach it to the slide was the real challenge.  Luckily, I came up with a solution for that as well. Here are a few shots of the new finger board.
267577-0
I had to bond up several 1-inch boards to get the real estate I needed to make the feather board.
267579-1
Here is the finger board and all of the 5/16-inch hardware.
267581-2
Here it is in use.
267583-3
Above image shows a 5/16-inch screw and a cross-dowel in the slide groove.
267585-4
This is a shot of the 5/16-inch screw and cross-dowel.  I think a bolt would work just as good I just did not have one, but was glad to have the SS screws.
I have no doubt someone could improve on this or already has.  Thus far, my rig has worked perfectly.
P.S.  I forgot to add that the fingers are 3-inches in length and approximately 1/8-inch thick.
« Last Edit: August 23, 2017, 11:01 PM by patriot »
'If you don't know where you're going, any road will get you there' Lewis Carroll
Offline derekcohen
    • In The Woodshop
Re: Poor Man's Hammer Finger Board
« Reply #1 on: August 26, 2017, 10:31 PM »
I do like that you have made your own. Did you consider using a T-bolt?
Offline bigmoguls
« Reply #2 on: August 27, 2017, 11:18 AM »
Looks very similar to the featherboard that comes with shopsmith.
It is funny to read "poor man" and "hammer" in the same sentence  8)
Offline patriot
« Reply #3 on: August 27, 2017, 11:33 AM »
@bigmoguls
Somebody is paying attention.   [big grin]
Offline deepcreek
    • TimberFire Studio
« Reply #4 on: August 27, 2017, 12:51 PM »
I use a Magswitch magnetic featherboard.  Works great!
Amazon Link - http://a.co/aHLQmGl
Joe Adams
TimberFire Studio
Houston, Texas
Offline patriot
« Reply #5 on: August 27, 2017, 02:04 PM »
@deepcreek
I could be wrong, but I believe that those require a ferrous surface to work.  The Hammer slide is aluminum so it would not work on that.
Offline grbmds
« Reply #6 on: August 27, 2017, 03:03 PM »
No reason to buy one when you can make it! (Sometimes my reason is I just want it fast and don't want to spend the time figuring it out.) Great job!
Randy
Offline patriot
« Reply #7 on: August 27, 2017, 03:54 PM »
@grbmds
Thanks for the thumbs up.
In truth, I kept putting this task off until the very last minute.  Ripping stock is something that I have very little experience with since my original (and only) TS was a Craftsman Contractor's model whose rip fence was an accident just waiting to happen due to its very poor alignment which I could not improve on.  The Hammer's rip fence, on the other hand, is a joy to use, but one which I take a great deal of caution with.  However, I would not use it until I had a working feather board. Now, both ends of my board are equal in width after being ripped.  Who woulda known?  [thumbs up]
Offline ChuckM
« Reply #8 on: August 27, 2017, 05:29 PM »
The Poor Man's approach is always a welcome exercise regardless of what is made. And the satisfaction can not be measured against money spent.
Cost-wise, of course, shop-made accessories are not necessarily the best when the labour time is taken into account. For example, you can get this for just $22 Cdn or so at LV:
http://www.leevalley.com/en/wood/page.aspx?p=60022&cat=1,240,45884,60022
Even less if this works: http://www.leevalley.com/en/wood/page.aspx?p=30069&cat=1,240,45884
Assuming your labour rate was $13.60 Cdn (min. in my province) and your knob supplies were a few bucks, you saved nothing to a cup of coffee after an hour's work.
If the surface is ferrous, no solutions are better than the magswitch versions, which are restricted by the mitre gauge slot. I use a hybrid approach: the wooden finger boards ($2 each from an estate sale) plus the magswitches that had been lying idle in my shop.
« Last Edit: August 27, 2017, 05:35 PM by ChuckM »
Offline deepcreek
    • TimberFire Studio
« Reply #9 on: August 27, 2017, 10:49 PM »
@deepcreek
You are 100% correct.  I didn't think about the Hammer slide being aluminum.
Joe Adams
TimberFire Studio
Houston, Texas
Offline Bob D.
« Reply #10 on: August 28, 2017, 04:35 AM »
ChuckM, do you always place your featherboards as shown in the photo?
I have kept the featherboard in front of the blade so as not to pinch the
workpiece around the blade because I thought the blade might throw it
up in my face.
Offline J0hn
« Reply #11 on: September 13, 2017, 10:06 PM »
Don't you have clamps that attach to the slot in the slider?
I just use my regular Kregg fingerboards.  Remove the hardware and let the clamp hold it in place - they have a nice flat service.  That way I can also use them on my other machines
https://www.amazon.com/Kreg-PRS3020-True-FLEX-Featherboard-Pack/dp/B000VRML5Y
Offline patriot
« Reply #12 on: September 13, 2017, 10:48 PM »
@J0hn
I like those fingerboards. Will they fit in the Hammer slider slot?  I can't tell by looking at the product images on Amazon.
Thanks for the info.  I appreciate it.
Offline J0hn
« Reply #13 on: September 13, 2017, 11:08 PM »
Maybe I didn't explain it very well
I don't use the slot - I use the clamps that fit into the slot to hold the fingerboard.  You probably could use a T nut like you did with your home made version, but I find this way a lot quicker/easier because I usually keep one of my clamps in the slot.
Here is an example that I just rigged up to show you what I mean
« Last Edit: September 13, 2017, 11:14 PM by J0hn »
Offline patriot
« Reply #14 on: September 13, 2017, 11:17 PM »
@J0hn
I bought  these Kreg clamps, but I found that when I tightened them down the board slipped.  I think that whatever board I clamped down using these clamps would have to have sandpaper glued to it to keep it from slipping.  So for this reason, I did not use the clamps and built my own featherboard.
That's one heck of a clamp you have. I've never seen anything like it.
Thanks for the feedback.
Offline J0hn
« Reply #15 on: September 13, 2017, 11:28 PM »
I am not that familiar with Hammer - I know that every little thing is 'extra and cost $$$$$$
I found this pic of one of their shapers with a similar type clamp for their slider
Offline patriot
« Reply #16 on: September 13, 2017, 11:37 PM »
You're right about that. [big grin]
Thanks for all the info.
Offline HarveyWildes
« Reply #17 on: September 14, 2017, 02:20 AM »
Before or after you've made the purchase?
