Poll
Question: Spanners to change blade on porter cable 6 1/2 inch circular saw  (Voting closed: March 10, 2012, 05:05 PM)
Spanner for p.c. Saw - 0 (0%)
Total Voters: 0
Pages: [1]   Go Down
  Print
Author Topic: Porter cable  (Read 1343 times)
Davej
Online Online
« on: February 29, 2012, 05:05 PM »
Hi, hope someone can help , I have inherited a porter cable 6 1/2 inch circular saw but no spanners to change blade , have tried to contact P.C. directly but being in uk can't register to ask them, saw is in immaculate condition but blade is past its best ( not even tct ! ) would appreciate any help as to the size of spanner to go behind blade, model no. is 346-1 , type 2 , serial no. A 14387 , any help greatly appreciated , thanks , Dave
I dont mind growing old but i refuse to grow up
Kev
Online Online
« Reply #1 on: February 29, 2012, 05:17 PM »
http://www.chasdayco.com/mm5/breaks/PorterCable/20030225152110_315-1.pdf
This PDF references the wrench models you need to find.
A quick search showed "no longer available from the manufacturer" - so it will be a hunt !
Sites like this could be an option ...
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/346-1/
Hope this helps.
Kev
Scott in San Diego
Offline Offline
« Reply #2 on: February 29, 2012, 05:38 PM »
Are you able to use a common box end wrench (spanner) or a socket?  Probably Imperial size around 1/2" and lefthand thread.
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« Reply #3 on: February 29, 2012, 05:40 PM »
My P-C 346 takes a 1/2" wrench to change the blade.  Hope this helps.
 Smile
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Davej
Online Online
« Reply #4 on: March 01, 2012, 09:07 AM »
 Thanks for your replies , seems the spanner I need is the jackshaft spanner , outer bolt is 5/8" so no problem with that one , looks like I will have to make my own for the shaft  Smile , as its 1 1/8" and very slim , tried the old method of a piece of timber between blade and base but didnt work as everything rotated but the blade .
Scott in San Diego
Offline Offline
« Reply #5 on: March 01, 2012, 09:21 AM »
Porter Cable router wrenches are 1 1/8" and rather thin, flat stamped steel.
Sparktrician
Offline Offline
« Reply #6 on: March 01, 2012, 09:40 AM »
Why not use the shaft lock plunger?
 Smile
- Willy -
Davej
Online Online
« Reply #7 on: March 01, 2012, 12:03 PM »
My saw doesn't have a shaft lock as its rather old , bit like me  Smile , but in much better condition than I am !  Managed to make  a temporary spanner to get blade off so happy days, interestingly the blade had a knockout for diamond shaped arbor .
Pages: [1]   Go Up
  Print
Jump to:
